Whats the best fuel to use for 86 TransAm ??
Old Nov 17, 2005 | 01:28 AM
GTA086's Avatar
Hey everyone,
What kind of fuel do you think is best to use for a 86 transam GTA in terms of octane??
I live in Australia. The car sais "Unleaded fuel only". And weve got the standard 91 octane unleaded.
Then theres the 95 octane Premium Unleaded, and also the good stuff which is the 98 Octane Shell Optimax etc
What do you recommend??
Any help would be great.
Cheers
Old Nov 17, 2005 | 04:17 AM
amean94ta's Avatar
Re: Whats the best fuel to use for 86 TransAm ??
any of those will work most premium here is 93 so you have good octane there, dont run any leaded fuel it will harm the cat and o2's
what are the prices you pay for those grades there? by the gal or litere?
Old Nov 17, 2005 | 06:26 AM
91-Z28-L98's Avatar
I'm running 87 octane on my '91 Z28 with no knocking. As long as you aren't running with high compression or boost get the cheapest octane rating available (87 or above of course).
Old Nov 17, 2005 | 03:41 PM
cc89formula's Avatar
98 octane out of the pump? wow...i cant find anything over 91 here...
Old Nov 17, 2005 | 09:25 PM
LesPaulGoth's Avatar
With no timing advance, I run my car on 87 octane with no problems. Now that the price of gas has dropped substantially though, I might just advance the timing again and run 93. =D
Old Nov 18, 2005 | 04:01 AM
GTA086's Avatar
thanks guys...
At the moment in Australia we are paying about AUD$1.15/litre of regular unleaded petrol (91 octane). Add another 15c for the 98 octane top stuff fuel.
Cheers,
Dave.
Old Nov 18, 2005 | 09:40 AM
respectirocz's Avatar
heres the question
is the octane rating measured the same over there?
Old Nov 18, 2005 | 01:39 PM
ws6transam's Avatar
Originally Posted by respectirocz
heres the question
I dont believe Australian octane ratings are the same as US octane ratings. When I lived in AU, I thought that every pump was selling race gas at first. Then I wised up and discovered that the british units were different than the American units of octane measurement. You'll need to do the research because it's been so long that I have forgotten the details.
Also, you need to specify what kind of engine you have in your '86. They didnt make a GTA in 1986. Do you have the tuned port or the carbuerated engine? If carb, is it a 305 H.O. or an LG4?
The 305 H.O. (with its 9.5:1 compression ratio) will require the mid-grade or premium due to its agressive timing table , the TPI ( 9.5:1 compression ratio) will be happiest with mid-grade, and the LG4 (I think its 9.5:1 compression ratio but with much less engine timing) can run any old gasoline just so long as it pours down the fillter neck without chunks.
Old Nov 18, 2005 | 09:16 PM
Doc99SS's Avatar
Simply run the lowest octane fuel which allows no detonation. You do not make more Hp with higher octane fuel. You only make more Hp with higher octane fuel if that octane prevents detonation.
Old Nov 20, 2005 | 08:41 AM
Oddball's Avatar
I thought of jokingly saying "use gasoline" but figured I'd get a dope slap.
My IROC uses 87 just fine.
Old Nov 21, 2005 | 03:46 AM
GTA086's Avatar
Hi mate,
Yeah Ive got the TPI engine, not the carby. I believe its the LB9 engine which is what I decoded with the VIN number.
Cheers
Dave
Old Nov 24, 2005 | 07:44 AM
Crovax WS-6's Avatar
well first off if you have an 86 trand am its NOT a GTA. 87 is the first year for the GTA.
secdonly you can run the midrange of fuel on the car and it shouldnt cause any ill effects. but i can tell ya right now that i ran 100 (american rating) octane in my 87 GTA 350 and it did absolutely NOTHING. i ran the exactly same times as i did with 93 in the car.
Old Nov 28, 2005 | 01:12 AM
89_Irocz's Avatar
HEHE here in South Carolina we can get 105 Octane at the pump, for about the price as midgrade...Lucky Us!!!
Doug Harden
29
Jul 30, 2003 07:05 AM
dreamer1q
Aug 29, 2002 07:47 PM
stavos
Jul 22, 2002 07:38 PM
