Sway Bar questions.
Old Sep 12, 2005 | 11:01 AM
Rage's Avatar
Sway Bar questions.
Im looking at purchasing some new sway bars, but I wanted to check with you guys and see what kind/size would be the best all around. If you can recommend a brand and size that would be very helpful. Thank you.
Old Sep 12, 2005 | 11:35 AM
Z28SORR's Avatar
Re: Sway Bar questions.
The best all around bar is the one that came on the car. why are you changing, for what purpose? Drag, street/strip or track?
Old Sep 12, 2005 | 11:37 AM
Rage's Avatar
I dont have any. They were removed my the previous owner because the bushings wore out, and he got tired of hearing it rattle. I guess he didnt realize that you can buy them at O'rielly's.
Old Sep 12, 2005 | 04:35 PM
fratsit's Avatar
Try spohn.net
I just bought a 1 inch rear sway bar for my '99 and its a very nice pice. I'm right in the middle of coating my wheel wells, rear subframe, and rear axel with POR-15, then I will be installing it.
One only has to compare the stock sway bars with an aftermarket and you will soon see why the stocker with rubber bushings is inferior.
Like Z28SORR asked, however, what are you planning for. Just a daily driver, 1/4 mile, or twisties.
Frat
Old Sep 12, 2005 | 05:11 PM
Zepher's Avatar
TDS makes some good parts,
we used their bars on my friends car.
http://www.top-downsolutions.com/ind...4e8fb0bfe520ed
Old Sep 13, 2005 | 10:13 AM
Z28SORR's Avatar
Even if you deside to go with stock replacement, at least get the "Poly" end link and bar mount bushings not the stock rubber ones.
Old Sep 13, 2005 | 12:11 PM
Rage's Avatar
I occasionly go to HRP and drag race, but the car is still my daily driver and although I do want a good bar for drag racing, I do not want to compromise awesome handling. I guess Im just looking for that middle ground. Also, the Polyurathane (sp) bushings you speak of, I've great things about them, but I've also heard they squeak excesively. Is this true?
Old Sep 13, 2005 | 04:56 PM
fratsit's Avatar
I've never had any problems with mine squeaking. Just lube them up and you are good to go. Dont get too lube happy, however.
Spohn has a nice sway bar set for $295.00. Front and rear with bushings.
http://www.spohn.net/product.cfm?productid=1311
Frat
Old Sep 14, 2005 | 03:20 PM
Rage's Avatar
Does this come with everything I need or is there in install kit needed? I dont not have any of the mounts because the previous owner removed them and who knows where they are at now.
Old Sep 14, 2005 | 07:37 PM
fratsit's Avatar
Rage,
You should have a small bracket mounted to the rear subframe on the driver and passenger side. If not you will see two holes in the subframe. You will also need to get the U-bolt, brackety, and screws to hold the sway bar to the axel. I would suggest calling Spohn and explaining your predicament. You can also hit a junkyard and pull the brackets yourself.
Man I wish I had a digital camera. I have the *** torn out of my '99 right now....I could take pictures of everything you would need. Sorry.
Call Spohn....they know all the right terminology for the needed brackets.
Frat
Old Sep 17, 2005 | 12:21 PM
Tru2Chevy's Avatar
I would save some cash and just get a set of stock WS6 bars (36mm front/24mm rear). Grab some energy suspension bushings and endlinks, and just unbolt the endlinks on the front bar when you wanna go drag racing (to allow better weight transfer).
- Justin
Old Sep 17, 2005 | 12:47 PM
fratsit's Avatar
- Justin
That would work, too. Put a nice slathering of POR-15 on 'em and you'll be set.
Old Sep 17, 2005 | 02:00 PM
Rottluver's Avatar
- Justin
Those are HUGE!!!!!!!!!!!! What year/s were those stock????? I have LARGER then stock bars on my 02 WS6 and they are 35/25
And yes I know he is referring to 3rd Gens, I am just curious since my stockers were 31/21.
Old Sep 19, 2005 | 01:56 AM
iansane's Avatar
I think all ws6 cars after 87 came with the 36/24 combo. My 91 has 'em and so did my 87. How stiff are stock 4thgen spring rates?
Old Sep 24, 2005 | 07:49 PM
Rottluver's Avatar
My stock springs were mush..........I got a set of SLP Eibachs and it firmed up nicely.
