Starting Problems!!
Old Oct 21, 2005 | 06:43 PM
xTxHxRx1xCxEx's Avatar
Question Starting Problems!!
I just got a 89' IROC-Z 5.7L mint all stock except for 4.33 gears out back has 107,000 on it. Ive had it for 3 weeks now w/ no problems, but yesterday I drove it in the morn for 5min parked it, came back 4hrs later turned the key and NOTHING. It has all the power for lights radio and headlights but nothing happens when i turn the key. I have cleaned the batterie terminals and tryed jumping it(maybe not have enough juice), I also took out the starter and had it checked(could it be the key???). I have no idea what is causing it from starting as i am new to chevy (mostly old mopar guy) but i always wanted a IROC so now i have one but it stoped working!!!! Anyones ideas or imput would be a great help.
Old Oct 21, 2005 | 07:36 PM
KnightRider350's Avatar
Re: Starting Problems!!
If I'm not mistaken, an '89 should have VATS. Does your ignition key have a small chip on it? My '89 RS suddenly stopped turning on---everything was fine, as in your situation. Ended up bypassing VATS. Thirdgen.org has an article on how to bypass it. I'd give it a try and see if it fixes the issue.
Old Oct 21, 2005 | 11:38 PM
90rocz's Avatar
A dead cell in the battery will allow low amperage lights etc to work, but will NOT turn the starter...have it checked.
Old Oct 22, 2005 | 12:32 PM
Thanks for the help, it was the key. Just got some resistor and all good now. Thanks again!
Old Oct 23, 2005 | 01:21 PM
Not a problem. Good luck.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
