What track times and numbers should I expect?
Old Aug 27, 2005 | 09:47 AM
FMFRacing88's Avatar
Hi, I have an 88 Firebird Formula and heres my set up:
-355 fully fordged bottom end
-Eagle crank, eagle 6" rods, and JE pistons
-comp cams xtreme energy hydraulic roller cam 230/236
-comp full roller 1.6 roller rockers
-AFR 195cc street heads with 68cc combustion chambers
-MAC 1 3/4 headers
-Holley Stealth Ram with 58mm BBK throttle body
-Accel #30 injectors
-Custom prom by LS Racing chips
-compression around 9.8:1
-Rockland T56 with SPEC stage 3 clutch
-Spohn torque arm, lower control arms and brackets.
-And for right now Nitto 555 street tires.
I was just wondering what kind of track times and dyno numbers I should be expecting with this setup and if anyone has any similar setups and what numbers there putting down. Also any suggestions would be appricated.
Old Aug 27, 2005 | 08:19 PM
89TramsAmGTA's Avatar
Re: What track times and numbers should I expect?
A lot of factors go into the time and MPH in the quarter mile. One of them is how well you can get the power to the ground. I suspect your car is capable of mid 12's and around 110MPH.
Old Aug 27, 2005 | 08:28 PM
Kwiksilverz28's Avatar
What rear gears do you have. Step up to 3.73's or higher....
Old Aug 27, 2005 | 10:18 PM
I have a 9 bolt rear so it has the stock 3.27 gears rite now.
Old Aug 27, 2005 | 10:46 PM
The 9 bolt is stronger, but I dumped it in favor of more readily available parts. Upgrade the gears when you can....
Old Aug 30, 2005 | 09:23 PM
Pneumatic_Tire's Avatar
Somewhere in the high 13's/low 14's I'd guesstimate. Only 1 way to tell, Get her on the track and lay some rubber.
Old Aug 30, 2005 | 10:39 PM
I think ur prediction might be alittle off lol...I ran low 14s(14.0) with my stock L98 and 700r4...seems like alot of people r telling me its capable of mid 12s with decent traction...i guess we'll have to wait and seee.
Old Aug 31, 2005 | 12:15 AM
Runin2Nite's Avatar
You think ur gonna be faster or slower than a 12? thats a awful low comp. ratio on that motor you should throw a kit on it, jus my .02. i think u might be lower if you can drive the t56. my buddy was throwin 13's on mild 355 and a few nuts and bolts.
Old Aug 31, 2005 | 09:36 AM
IROCZZ3's Avatar
I also say at least mid 12s at over 113, if everything is tuned right, you can hook, and if you can drive. I think you should run at least 3.73 gears out back also.
I ran low 12s with your same cam, intake, and compression ratio on a 350. But I used AFR 190s, 24lb injectors, 3.50 gears, and an automatic w/3500 stall.
Old Aug 31, 2005 | 07:08 PM
I was reffering to the prediction of high 13s/low 14s Yeahh my goal was to hit at least a 12.5 with this setup...u think its possible with the terrible 3.27 gearss.
Old Aug 31, 2005 | 08:31 PM
Runin2Nite's Avatar
Your runin a whole different car rite now man. u did 14.0 on a tuned set-up. this thing might feel like a rocket beeing manual and turn out to run like a dog wen u get up to the track. being a good driver and knowing were to launch that puppy is gonna be ur key.
Old Sep 1, 2005 | 01:50 PM
Zepher's Avatar
With some really sticky tires, I don't think you'd get down the track very fast at all.
I'd guess mid 12's as long as everything is in tune.
350-370rwhp
Old Sep 1, 2005 | 02:37 PM
doug791's Avatar
only thing i question about the setup is the heads. I'd be willing to bet there is a reason AFR stopped making the 195. Because on a 350-383 sbc the 190's if i understand correctly wont have any problem supporting 400-450 hp, and if youre running a 400 you need the AFR 210's, i think thats the next step up i forget.
Anyways i think you just might end up with a little bit of a surprise and with torque numbers lower then you expect because the heads just flow too much for the motor. Could be wrong tho.
EDIT: other thing i was thinking, stock TB is 52mm right? If youre going to dyno the beast i would be curious to see what it pulls with the bigger TB vs the stock one.
Old Sep 1, 2005 | 03:23 PM
Zepher's Avatar
stock TB is 48mm.
Old Sep 1, 2005 | 05:02 PM
AFR stop making the 190cc heads not the 195s....I dont think they flow too much for the motor as its not meant to be a low end torque moster it was built more for top end power...Im also going to have it dyno tuned soon along with getting some M/T street radials.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Feffman
Oct 9, 2015 05:42 AM
GRN96WS6
Sep 8, 2002 10:45 PM
teedoff59
Aug 8, 2002 01:36 AM
