So....I just bought and LT1/T56...
Yeah...I just purchased the combo and am anticipating putting it in. Does anyone have a web site or, anything that has "directions" or some help tips on the swap. My car is a TPI/ Automatic, so, I have quite a task before me. Any and all help would be just great. Thank you.
Re: So....I just bought and LT1/T56...
My overall plans for the car is to have a mid to high 12 sec car, that is still a comfortable daily driver but can be a fun toy as well. I do plan to freshen the LT1 up before the install. Doing a gasket rebuild, Optispark, tune up, timing chain, water pump. Things like that that are much easier to do while its out. I also plan on purchasing a set of headers for the car. Which brings me to my next question. Which headers do I buy? Do I buy TPI headers because they are shaped right for my car, or do I buy LT1 headers?
I have another question. Just how much easier is it to use a Painless wiring harness rather than the stock LT1 harness? Is it worth the $350 or so that Painless is asking for it? Those of you have used painless, and have also done the swap or a similar swap w/o it let me know what you think? I guess what Im getting at is, with the Painless harness, just how many man hours will that save me?
I did not use the Painless harness, but I would assume it would save a lot of frustration. Try a search in the engine swap section over at Thirdgen.org that should answer your question.
painless is a waste of money. i can make a harness in an hour it almost stand alone as it is you just need power and vats removed. you can im me for help im more than expierenced in it since i made a few. clark2002jc.
check out my website,
http://www.geocities.com/texaslt1/lt1swap/swap.html
its not anywhere near complete, but will give you a basic idea of what its going to take. The electrical is the most "difficult" part of the swap, but even then its not too bad, just depends on how you do it.
Also, if you even need a hand with the swap, let me know and I can head over there. Baytown is only about an hour from here and I'm always out there at HRP.
High 12's are easy to attain. I was running very low 13's with Heddman shorty headers, Hotcam, 1.6 rockers, and Nitto's with 3.42 gears. Do 3.73 gears instead, longtube headers, and maybe an XE230/236 cam and you'd definitely be running 12's. Probably could do it without the longtubes.
carguyshu
Jan 22, 2017 11:19 AM
jasonduaine
Apr 1, 2015 08:09 PM
