Changing cam in car
Old Aug 26, 2005 | 09:21 AM
bmillington's Avatar
Changing cam in car
I'm about to change my cam while it's in the car. Any tricks or things I should watch out for. I don't have to disconect the condensor do I? Thanks for any info.
Old Aug 26, 2005 | 01:08 PM
Tru2Chevy's Avatar
Re: Changing cam in car
If you are very careful you won't have to disconnect the condensor, but you will have to move it out of the way a little bit. The fans and radiator will have to come out first.
What cam are you installing?
- Justin
Old Aug 26, 2005 | 01:37 PM
ZZ4 cam
Old Aug 28, 2005 | 01:17 AM
2 z28s's Avatar
just pull the block, much easier to do it this way, alos u can paint it
Old Aug 28, 2005 | 01:22 AM
Bristol's Avatar
Just the obvious stuff. Intake, waterpump, fans, rad timing cover etc. Its not really all that hard. Just curious though...I never knew a 1LE could come with AC.
Old Aug 28, 2005 | 06:02 AM
The B4C package comes with A/C and a radio along with a lot of other performace stuff. Making tthe 1LE and B4C the ultimate combo.
Old Aug 29, 2005 | 10:01 AM
Phantomfe3's Avatar
im not sure if its the same on your motor since yours is a 350 TPI and mine is a carb 305 but i had to take my intake manifold off and valve covers to loosen the rockers and pull the pushrods out to take the lifters out, but im not too keen on which motors were roller motors, yours probably is, i have no idea, someone else should chime in on this
but i know youll need to take your distributor out too
Old Aug 29, 2005 | 02:44 PM
Bristol's Avatar
Ya. The intake needs to come off...rockers need to be loosened and the pushrods pulled so that the lifters can be removed.
Old Aug 29, 2005 | 06:44 PM
Runin2Nite's Avatar
can u put a cam in and run well woth out modifing the ecu??
Old Aug 30, 2005 | 01:19 PM
Tru2Chevy's Avatar
Depends on the cam, but any cam will benefit from tuning.
- Justin
parkers Z28
Mar 11, 2016 08:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Queens94z28
Nov 20, 2014 06:03 PM
