best trans for a tpi
Old Oct 19, 2005 | 01:43 AM
Runin2Nite's Avatar
lookin to have a mid to hi 11 sec tpi next yr with a dfi. i seen some cool lt1 trans's but what can i put in a 3rd gen to hold. i like the 700r4 cuz the OD but i hear there not strong enough even wen built. i seen a trans that had a b&m shifter on it in a lt1 and to shift it you would slam it back. so i guess it was kind of like a manual trans with out having to clutch. it looked pretty fun to drive.... any idea of what this **** was??
Old Oct 19, 2005 | 07:05 AM
Dave89IROC's Avatar
Re: best trans for a tpi
odds are he was running a 700R4 or a 350 Turbo
there is nothing wrong with a 700R4 if built right, it is just as strong , if not stronger, then a 350 Turbo when built right
Old Oct 19, 2005 | 11:41 AM
KnightRider350's Avatar
I agree. A built 700R4 can take plenty of abuse. If you were expecting to dip into the 10's or single digits, I'd say you should be looking at a TH350/400, but a well-built 700 should handle 11's just fine.
If you go to summitracing, and look at B&M shifters, there are many to choose from. The most common one in f-bodies is a Megashifter.
Old Oct 19, 2005 | 11:58 AM
91Z-28's Avatar
T56 all the way man, only reason to stick to an auto is if you are a religious drag racer.
Old Oct 19, 2005 | 04:45 PM
Runin2Nite's Avatar
i had my buddys camaro witha t56 i hated it, the ***er kicks sideways to easy. i had plently of other man cars that were fun dd's but not for the weekend/race car
Old Oct 19, 2005 | 08:16 PM
90rocz's Avatar
A modified 700R4, especially if it's an Auto now. There are many books and articles in mags about building them up, or you can buy one for under $1500.
You'll need: a 2800 stall converter, Corvetter servo, a Racing Master rebuild kit, governor weight kit, good tranny cooler, improved tranny pump, hardened drum, hardened input/output shaft etc....
To go that fast reliably, I'd buy one with a warrantee, like B&M or TCI etc.Hi-Po trans cooler(bypass the radiator) and a 2800 stall, Zexel style posi, 3.42-3.73 gears, cast rear cover/girdle .
Old Oct 20, 2005 | 06:15 PM
fratsit's Avatar
www.pro-built.net
I got one and love it. Street/Strip 700R4 with a Vigilante 2600 stall converter. Call and talk to Dana, he'll help ya even if you dont buy from him.
Frat
Old Oct 20, 2005 | 09:12 PM
Chode89's Avatar
I'm running 9's on my 700R4 and am really happy with it. Got it Done by Finish Line Transmission in Scahumburg, IL.
dfarr67
Apr 10, 2015 07:44 PM
capebuf
Jan 13, 2015 07:22 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
