Is the fuel pressure relieved or not?
Old Nov 11, 2005 | 06:09 PM
'86 350's Avatar
Hey. I'm changing the fuel fliter in my car. It used to be a 2.8 FI V6, but it's now been swapped out for a carbed 350. I run a fuel pressurre regulator a foot or so before the carb. Now although I run a fuel filter up near the carb, I also run one in the position of the stock V6 one underneath the car. I also still use the pump in the tank (hence the fuel pressure regulator).
Last time I unhooked my lines from my car and stuff and pulled my carb off, I needed to "re-energize" the fuel pump or something because when I went to go start the car it wasn't getting any fuel. I now have my intake, carb, etc off again to replace the head gaskets. I'm also changing the fuel filter that's in the line under the car. My question is, am I going to get blasted with 30psi (or whatever it was for the FI V6's) or am I all set to pull off the lines and just have it drip a little bit of fuel?
P.S. I can't release the pressure or anything though because pretty much everything is out of my car, otherwise I'd turn it over and just empty out the fuel.....
Thanks, Brandon
Old Nov 11, 2005 | 06:14 PM
NastyTA's Avatar
Re: Is the fuel pressure relieved or not?
put a rag around the fitting and break it loose.
Old Nov 11, 2005 | 11:05 PM
'86 350's Avatar
Wow, I don't know if the fuel line is siezed onto the filter or what! I've been trying to get either the output or inlet side loose for about 15 minutes and I can't. I've sprayed WD-40 on both and let it sit and then tryed and still nothing. I can't get it loose at all.
I'm putting enough strength to the point where I'm starting to get a little uneasy and afraid I'm gonna break and/or strip something.
Do you guys know if these filters (or any filters) are reverse-thread? I tried that too (just with less force because I didn't want to tighten if it wasn't) and it didn't seem to budge that way either.
Any idea?
Old Nov 12, 2005 | 04:18 AM
Dave89IROC's Avatar
normal thread, just tight, they suck when old
Old Nov 12, 2005 | 01:31 PM
91-Z28-L98's Avatar
If your fuel lines are disconnected at your carb, I don't see any reason why there would still be high fuel pressure at the fuel filter, but put a rag over it just in case. As for the siezed threads, try liquid wrench or PB blaster. They work a bit better than WD-40.
Old Nov 12, 2005 | 02:56 PM
'86 350's Avatar
Allright, I'll see if I can pick some of that stuff up today.
Old Nov 12, 2005 | 10:56 PM
'86 350's Avatar
Damnit. Allright well I didn't have time to get down to the local Napa today, so I decided to just go ahead and shoot it up with some more WD-40 and try to get it off. Well I thought I was getting it off and then I started to feel my mechanics glove get soaked. So I dropped the wrench and looked at what happened. It turns out that I snapped the fuel line and it never budged from the filter.
So my question is, how hard is it to change the fuel line in one of these cars granted I have one of those little tubing bender things for brake lines? Are there any other tools I'd need?
**** I'm pissed.....
Old Nov 13, 2005 | 02:18 PM
'86 350's Avatar
So my question is, how hard is it to change the steel fuel line in one of these cars granted I have one of those little tubing bender things for brake lines? Are there any other tools I'd need?
Old Nov 13, 2005 | 06:31 PM
Dave89IROC's Avatar
what condition is the line in about 12" to 18" inches away from the filter?
the reason I ask is that they sell repair kits just for situations like yours, b ut, you need solid line a little way up the line
Old Nov 13, 2005 | 08:56 PM
'86 350's Avatar
It looked fine to me when I was under the car. It was dirty, but there were no signs of gas leaking or anything. Could you link me to one of these kits?
Old Nov 14, 2005 | 02:31 AM
Dave89IROC's Avatar
http://www.midwayautosupply.com/manu...m%20Components
second page(use the arrow, not the number), near the bottom, most auto parts stores should carry it
Old Nov 14, 2005 | 02:54 PM
'86 350's Avatar
Okay thank you very much man, I appreciate all the help.
Old Dec 6, 2005 | 05:49 PM
'86 350's Avatar
****, I got another problem. I finally got around to going to finish this (car was down to short block) and After I ahd snapped the line going into one side of the filter. I used some PB Blaster on the other side, went to take it off, and it ended up snapping that end too. It's really not worth buying 2 different fuel line repair kits. I was wondering, this is originally a 2.8 FI V6. Is there any way I can run a nylon line over the metal ends and hose clamp it (I'd bypass the filter 'cause I got one up front)? I'd really like to not have to buy the fuel line repair kits. I wouldn't mind that much if I had to do it bend my own fuel line, but I heard it's a pain in the ***, plus I don't have the tools.
Will the nylon hose work, or do I have to make my own line? If so, what tools do I need, and how time consuming is it?
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
