engine swap - bracket problem
Old Oct 7, 2005 | 03:12 AM
Unix's Avatar
Hi,
I'm busy doing a V6 to V8 and automatic to manual swap on my 3gen Camaro.. The V8 (305 ci. TBI 1989') is already in the chassis but i've got a problem with the serpentine system. I don't have the V8 AC bracket (which also holds the tensioner!) , i deleted the AC system and i need a way to connect the tensioner to the block. Is there any way to connect the tensioner to the block without the original AC bracket? Are there any aftermarket brackets for this purpose?
Thx for any info !
Old Oct 10, 2005 | 11:53 PM
masiroc566's Avatar
Re: engine swap - bracket problem
You can try http://www.marchperf.com/ . They might have something that will work for you. Otherwise you may just have to go with the bracket and get the A/C delete pulley.
Old Oct 11, 2005 | 12:53 AM
83_z_fan's Avatar
Just a thought but how about a shorter belt altogether? Just skip where it runs to the ac altogether.
Old Oct 11, 2005 | 03:18 AM
Unix's Avatar
http://web.camaross.com/forums/showthread.php?t=402239
HectorM52
Jun 23, 2016 08:42 PM
rocketman051894
Jan 30, 2015 03:23 PM
HectorM52
Jan 16, 2015 10:21 AM
cmdeshon
Jan 4, 2015 11:15 AM
siguy
Nov 27, 2014 10:07 AM
