one little wire..
one little wire..
hey i found this 1 little wire...wondering where it goes...its right next to the est timing bypass wire
heres a pic..
http://memimage.cardomain.net/member...1_115_full.jpg
please tell me its something important (hopefully something to do with the ignition or something)....b/c im running out of ideas on this ignition problem im having..
heres a pic..
Re: one little wire..
That's the fuel pump test/prime connector. It's just what you use to check the fuel pump and wiring if you suspect something is wrong with either two. You would just apply 12 volts to that connector and the fuel pump should run.
chris4813
Oct 27, 2012 06:04 AM
SmokeyBlaZe
Jan 8, 2010 03:04 PM
