Lt-1 swap into 1991 RS
Old Oct 13, 2005 | 07:16 PM
jacobd59's Avatar
I need to know if i can use a 700r4 with a computerized 1994 lt-1 and Does the rear end of a 1994 bolt on to a 1991 Or do i have to make new mounts??
Old Oct 13, 2005 | 07:46 PM
90rocz's Avatar
Re: Lt-1 swap into 1991 RS
I'd swap in a matching '94 tranny and take advantage of being able to dial in shifts with a programmer when you tinker with engine settings.
Old Oct 14, 2005 | 07:15 PM
92LT1RS's Avatar
Please, PLEASE do some searches here and over at thirdgen.org. You will quickly find all of the information you need and not be asking the same question that comes up once a week.
Also, for a quick general guide, check out my website, www.geocities.com/texaslt1/lt1swap/swap.html
To answer your questions, yes, you can use the 700R4 but you'll be better off using the 4L60E that comes with the LT1. If you do want to use your 700, you'll need a '93 throttle body to be able to attach the kickdown cable. You can also use the 4th gen rear, you'll just have to modify the e-brake cables a little bit and your stock wheels will get moved out 1" each side.
Old Oct 14, 2005 | 08:47 PM
Dyosis's Avatar
I agree. Messing with the governor on a 700r4 is a HUGE PITA!
G-BODYT56
Jan 14, 2022 11:14 PM
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
Tarizza
Sep 20, 2015 03:26 PM
