1 piece vs. 2 piece rear main seal
I am trying to install an M5 into what was an A4 car. The flywheel that I got with the tranny to do the swap with has a smaller bolt pattern than the flexplate that I just removed. The flywheel has a GM1 in raised lettering in the steel. I'm trying to find a flywheel that will work. Is the one that I have a 1 piece seal flywheel and I'm trying to install it into a 2 piece main seal block? The engine is a crate 350 from GM about 3 years old. Any assistance in finding the proper part is appreciated.
Thanks for any assistance.
Re: 1 piece vs. 2 piece rear main seal
Originally Posted by masiroc566
You cant install a 1 piece flywheel into a two. Your best bet is to call the dealership...get a part number, then order from gmpartsdirect.com
yeah if he wants to spend 3 times what he should be able to get one for. Check ebay and check thirdgen.org classifieds.
That's what I'm trying to find out, do I have a 1 piece seal flywheel and that is why it is not working? If I order a flywheel for a SBC from earlier than '86 I'll be fine?
Thanks.
Thanks.
http://www.racewithjw.com/index1.html
I had the same problem when I did my T5 swap. It was out of an '84 and I put it in an '88 so I needed a different flywheel. It was a huge pain in the *** to find one. Advance auto wanted $280 and I couldn't find one used. I wish you luck my friend!
so you are installing a manual trans?
what size clutch? what size is the flywheel you got with the trans?
It looks like it is a 10.5 inch clutch. I figured out that it is a 2 peice motor. I ordered and got a flywheel that matches up.
Thanks for all the help.
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
bossco
Nov 29, 2014 10:18 AM
