Hot Mods?
Old Oct 21, 2005 | 05:37 PM
Johnny's 89 IROC's Avatar
Lightbulb Hot Mods?
does Anyone Have Any Ideas For Keeping The Stock L98 And Adding Some Hot Mods After I Bore It 30 Over Cause This Motor Is Worn Out.
Old Oct 21, 2005 | 11:52 PM
90rocz's Avatar
Re: Hot Mods?
The Usual:
1)fabricate cold air inlet tubing(like 8"ducting from hardware...)from behind fog lights.
2)K&N filters
3)Air foil
4)grind the obstruction off just behind the throttle blades.
5)relocate the MAT sensor
6)large tube runners
7)24# injectors
8)cam
9)port the stock heads, or have a "Pocket Port Job" done, and a GOOD 3-angle valve job is CRUCIAL.
10)New valve spring a must!
11)1.6 ratio rockers
12)headers
13)Custom tuned Chip
Old Oct 22, 2005 | 11:06 AM
NastyTA's Avatar
Re: Hot Mods?
what do you want to do with the car?
Old Oct 22, 2005 | 02:34 PM
Re: Hot Mods?
I've Got Headers And 3 Inch Exhaust All The Way Back I Want To Get About 400-425 Hp I Ride A Motorcycle Daily So Not Real Worried About Gas Its Just A Weekend Driver. Also Whats The Difference Between The Vortec Heads And The Normal Centerbolt Heads For My 5.7
Old Oct 22, 2005 | 06:44 PM
NastyTA's Avatar
Re: Hot Mods?
Stroke it, make it a 383. A good set of aftermarket aluminum heads, matching cam, mini-ram intake, and have it put together by someone that knows what they're doing.
dkred94z
Aug 20, 2015 03:09 PM
Devinfoote87
Jul 30, 2015 09:54 AM
jbc3
Jul 28, 2015 12:24 PM
Xiantyl
Jul 21, 2015 05:42 AM
CARiD
Jul 7, 2015 08:19 AM
