Possible ignition problem
Old Oct 18, 2005 | 04:19 PM
91-Z28-L98's Avatar
Yesterday I had issues with my 91 z28. After I would turn the key to crank the engine it would do nothing for about half a second then crank. It did this several times, then later on it stalled out flat on me while idleing and did not want to start for a minute later (though it would crank). I had no rough idle before that. I'm thinking its an ignition switch problem, but it may also be a VATS problem. What do you guys think?
Old Oct 19, 2005 | 08:13 PM
90rocz's Avatar
Re: Possible ignition problem
Couple of ideas...pick-up coil in distributor, or ignition module failing under heat soak.
Old Oct 20, 2005 | 06:22 PM
91-Z28-L98's Avatar
I haven't had a problem with it since, but I haven't driven it a significant distance since then. I don't think its the distributor pickup coil since that wouldn't cause the 1/2 second no crank issue. Ignition module under heat soak sounds more and more like the correct diagnosis.
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
