So, what should my ignition coil ohm out to?
Old Sep 18, 2005 | 08:44 PM
Pneumatic_Tire's Avatar
What should a good ignition coil Ohm out at? Just want to test it. Gonna replacing ignition parts just cause I am ****. I'm gonna get new wires and ignition module and distributor cap. Maybe a Ignition coil too, but only if it tests out bad. Also, what brands do you guys like? I used to get Accell stuff for wires and what not. They seem to be really good. I will probably get a AC Delco cap and ignition coil. I'm not trying to upgrade over stock Ignition.
Old Sep 20, 2005 | 09:59 PM
90rocz's Avatar
Re: So, what should my ignition coil ohm out to?
Less than 50 ohms..Accel coils are good, better than stock, also use Accel Super Stock wires, they have a spiral wound steel core putting much more energy at the plug. Make sure the cap and rotor have Brass inserts not aluminum..
Kempster
Jul 7, 2020 11:00 AM
markzzzz
Aug 17, 2015 11:08 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Cam28_boy
Aug 6, 2002 08:40 AM
