View Full Version : Forced Induction
- engine break-in, with or without boost?
- My formula in GMhightech magazine...
- Ebay Find
- Delteq & Rev Limiter?
- 85mm Ls1 Style Maf 5 Wire Calibration Needed
- Took the TC76 w/MPS Wheel out for a couple of 3rd gear passes tonight...
- Vortech V2 SQ S-trim on a 383?
- P600B gave up.....turbo?
- What PSI spring are you running in your Turbo BOV?
- Just dyno'd with new blower
- started a turbo project
- Head Stud sealant??? Help, QUICK!!!
- Finally have boost
- 3" Blow Off Valve Piping. WTB?
- Rear mount turbo, and regular turbo ???s
- Superchaged LT1 in a 1st Gen?
- Help!! Coolant loss and now its found but makes no sense???
- Well.. =( car is for sale. Turbo 5.3 T/a
- Castrol TWS Motorsport 10W-60
- Starting Gap on Autolite 103's for 15lbs boost?
- I need a CHECK VALVE, which one?????
- What header gaskets?
- blowby with sts...poss pcv issue?
- boost on stock crank and rods.
- turbo set-up for LT1 besides sts?
- Blue Smoke on Decel and Downshifts
- Will my D1SC get louder?
- How about this Lingenfelter cam?
- Madman Alt relocation with turbo?
- need lots of help
- Max Valve overlap for F.I.?
- Track times for my car
- Got some work done
- tuning question (low boost/high boost)
- Belt Length with SDCE tensioner??
- Should the 45* elbow sit on the brake distribution block?
- Found my boost leak
- Anti-Surge system?????
- Selling my REALQUICK turbo setup
- Loss..96 TTA vs 07 TT c6...
- Bling Bling! Where to get colored silicone piping?
- Procharger filter location??
- Requiem for a turbo LT1
- What pulley to make 13-15lbs on a 383 with D1SC?
- CAM guru's---112 LSA on a 383 w/blower.
- Finally figured out what happened at the LTx Shootout
- Blower/bypass valve making different noise.
- Double pumper fuel pumps...Pressure question?
- 4 DEG. if Spark Retard at IDLE?
- Small quarter mile video
- 5.3 swapped into 96 T/a 56k warning
- Who did your tune?
- FPR Question
- wide band location with twins
- Where to put the driver side O2?
- T76 60# injectors at fault?
- ATI Super Damper Worth It?
- PCV System Check Valve
- Question on the sheet metal intakes for the FI cars...
- Weird O2 behavior (and they're new!)
- LT1 2 Bar Map Sensor Part number?
- Speed Density and stock MAP Sensor Tunes
- differences Between Turbo Trims?
- o2's and maf replacement recomendations?
- intercooler routing
- 96 Turbo ImpalaSS LT1 Video
- Got the car today(FINALLY!) Now, Diagnosis-Advice?
- F.A.S.T. standlaone system for you forced induction guys 4-sale
- Any one need injectors? 65#, brand new
- A sad day(parting out my setup)
- honest fuel milage
- Those Running RealQuicks Log manifolds(another question)
- intercooler difference
- Car not boosting, think wastegate problem
- Holy WOW STS are loud
- 1,000 RWHP Twin Turbo LSx
- Supercharger Sound/whine??
- help! car died and wont start!!!!!
- i-charger
- Hp estimate for a fi 383
- Opti vent
- Twin Turbo vid, Mid mount near Trans bell?
- intercooler
- supercharger experts
- Small teaser video
- Name that BOV!!
- PTK Install in progress... some questions
- 3.5" to 3.0" reducer, where did you find one?
- Vortech YSi users, a question for ya......
- The future of "LT1 Boost"
- Driving to dyno tune with new supercharger????
- Finally made a little progress - Now running out of gas
- Need some help from those with S/C LT-1s PLEASE!
- which oil scavange pump are you guys using
- trickflow sparkplugs
- overboosting like crazy
- Aftercooler leaks water into intake!
- Vortech heat exchanger replacement?
- Turbo Build - Pics & Questions
- Cheapest Way To ad 5LBS ob boost to my build?
- FMIC in the for sale section
- What gears for F1A 355
- How much would this throw off my sound FI tune?
- What are these holes in the compressor for?
- Countdown for my Turbo LT1 has begun..
- Post Pics/Links of your LT1 Intercooler routing
- Quick quest regarding PCV on Procharger setup.
- RealQuicks Hotside parts quality...
- PCV.. .what do you F.I. guys do to keep that from popping out?
- Looking for a shop near TN for Superchargerinstall/engine swap!!
- Wastegate vacuum signal tubing-What are you using?
- Cam suggestions 383 D1sc, AFR 210 LT4s ??
- Problems with Procharger D1-SC setup
- Procharger supercharger
- procharger belt
- Masterpower GT45??
- Some more recent vids of my car...
- Boost/pressure closing AC door?
- Need to get rid of some turbo parts.
- Kenny Bell 03 Cobra calling out my Supercharged LT1...
- turbo guys what speed stall? th400 perfered!
- this good buy
- Wanting a turbo need help plz
- Boost Guage
- new to boost
- Those running 'realquicks' log manifold...question
- Fast t56 guy's inside
- Which meth/water injection kit?
- What oil are you guys running?
- Whats limiting my HP/TQ - Intake, Heads, Cam, Supercharger?
- Magnuson LT1 First Trials Video!
- LT1 caprice turbo build
- How much flex is needed for turbo exhaust?
- Boost guage tap questions
- Fuel Pump Question
- ever foul plugs so bad the car wont start?
- Boost guesses?
- Ready To Mount Intercooler
- Turbo Long Block is ready at last
- goin boosted
- Turbo sizing for a 383?
- Ross Blower Piston
- New to the boost game
- whatcha think?
- Seafoam Q's
- Car bucking when going from Vac to boost
- Anyone ever upgrade from an ATI 2 to an ATI 3 core IC?
- Lil Procharger vid
- New to Camaros. Supercharger Question
- cross over tube size.does size matter is the ?
- Age old question (Deciding on piston)
- procharger bracket
- should i do it or not?? need help
- High impedance injecot limits
- Traction cont relocation kit IDEAS????
- Turbonetics HP66
- boost guage!
- Third gen supercharged 355 tech help...
- What BOV's are you guys using?
- How durable is your ceramic coating?
- Injector Size For E85
- My 355 Parts List
- Thinking about going from F1A to Single Turbo..yay or nay
- Help me decide on some Forced Induction combo ideas...
- inlet temps with air to air
- D1SC pulley for max boost without overspin.
- 3rd gen turbo pics
- Platinum plugs
- New best at the Shootout
- Is this bad?
- Idler arm? ProCharger
- Question on oil pump
- I know this has been beaten to death, but..
- Reflashing Stall?
- T 70 on 383
- APS twin results on 8 pounds of boost
- Turbo kit FOR SALE!
- thick copper exhaust manifold gaskets
- noob
- Procharger guys..Ever try using one of these Air filters right on the Blower inlet?
- which exhaust?
- Plug above filter?
- Viren Singh is a great guy!!
- Is this ABS or TCS ( in my way for procharger)
- Poll: SS and Supercharged
- Paxton SN2000 on LT1
- EGT Sensor?
- 2 bar map sensor part number?
- what cid is best for a blow thru set 370 thru 434cid
- laying over at 5000+ rpms...
- Turbo Ls1 Help
- Started my turbo build pictures..
- Now burning E85...
- How would you do it...turbo?
- Sneak Peek ! Magnuson LT1
- Will This Work?
- Turbo and Heat Protection
- how many turbo guys have an oil temp gauge and what temps ar eyou seeing?
- Found my problem (crank case venting)
- Which Crank?
- Another vent question
- Valve springs
- Fuel Setups with HP
- Evacuation Hooked up Wrong?
- stock tb and sc
- Pro charged ls1
- AFR 227+ Edelbrock LT4 intake gaskets? (F.I. 383)
- is 106mm turbo over kill for a 383 lt1/lt4
- Think I ran into a problem (drain related)
- Question for you vertical radiator guys
- Look what I found in my turbo
- LT1 SS Impala
- in 95 camaro lt1 w air buildup
- turbo install, questions
- Which H20 pump, CSR or Meziere?
- Getting close! (Long!)
- Camaro ls1 turbo kit
- What kind of MPG are you getting with 50# injectors?
- Running without the sc belt
- Stock motor vs iat vs #boost
- if you have used a mbc come in!!! Hallman Pro Kit or JoePMBC Pro-Z?
- Manny Kit for Sale
- Anyone running a F-2?
- Manifolds
- my turbo lt1 vs stroker supra
- O2's sensor reading while going WOT
- Anyone tune with megasquirt yet?
- Turbo and FMU
- So my car is slower now.
- Need 3.15 Pully Procharger.
- Turbo questions. Couplers....
- The Super Car!
- ProCharger Racers...
- Root cause of throwing belts?
- High compression and turbo!
- Test fitted these today...
- Afpr
- My progress pics of the last week
- can you reverse wire a fan?
- Want to put F1A on this 383, but its 11.8:1 and need heads!
- Where to find a stock LT1 crank
- Spark Plug Issue
- Build almost done -- HP/Torque guess
- Issus with my System
- update on my car
- Aeromotive AFPR
- Intercooler is mounted
- vertical radiator questions
- Procharger Oil Feed Kit??
- Help me choose a cam.
