PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. MPT70 on a LT1?
  2. -4AN stainless steel braided the same as SS Hydraulic hose?
  3. FI Specific trans question
  4. wastegate/bov help
  5. How long have you had your boost?
  6. Waste gate on a Centrifugal Supercharger with adjustible boost...
  7. Most Popular Radiator for Stand Up use?
  8. What Size Injectors / Washed Cylinders??
  9. s/c or turbo
  10. (from VW to V8) need help/info about a paxton LT1
  11. 8-9psi with 10.2:1?
  12. "Designed for Stock Engine" claims...are they true?
  13. Help with LT1 Pistion selection....
  14. rear mounted turbo question
  15. STS Turbo Dealer In BC???
  16. Help with roots style sc on LT1
  17. New results. questions on gearing and my mph
  18. Idle messing with my head
  19. Supercharged LT1
  20. How much boost on LE2 kit? Stock internals.
  21. Anybody with a Procharger/Vortech have any regrets?
  22. Got it running, but have a couple of questions
  23. Track results...stock heads/cam T76
  24. Car as it makes boosts gets slower?
  25. Which is better?
  26. Supercharger advice wanted
  27. track results
  28. couple questions about my build
  29. Will this intercooler be too big to fit?
  30. Cartuning v6 Camaro Turbo
  31. magnacharger on formula
  32. Cylinder heads for a blown 383
  33. Looking for head suggestions
  34. m6 vs auto w boost
  35. Supercharged 383s
  36. Getting too old going to a smaller cam!
  37. What are you doing for Z28 FMIC airflow?
  38. evacuation system
  39. Plug Gap And Plug Type For Turbo!!!!
  40. What ignition box to use with Procharger?
  41. Map higher than baro air pressure?
  42. Opinions please
  43. Has anyone seen these?
  44. Timing on boosted LT1
  45. ? on differnt CI's for forced induction
  46. super charge a stock motor?
  47. Wondering
  48. LE2 355 with a P1-SC procharger?
  49. Just about done
  50. supercharger or prochager
  51. Powerdyne users might want to read. Replaced Filter?
  52. Got my intercooler on!
  53. Spoiled ProCharger P-1SC Model Specification label
  54. Got a LT1 Turbo cam you want to swap for a N/A cam?
  55. Slowly but surely.
  56. Is it possable to run 1 ext. + 1 int. wastgates
  57. Good IAT temps?
  58. Turbo Pistons from Eric at Victory arrive!
  59. INTMD8's LT-1 twin turbo system and Turbo/Blower long block FS
  60. Someone may need this
  61. Best heads for 383 twin turbo
  62. Which parts are "stressed"?
  63. crankcase ventilation please help!
  64. crankcase ventilation help please!!!!!!!!!!!!!
  65. Gauging Interest: LT1 Turbo Kit
  66. Daily Driver Rear Mount
  67. blowing coupler off of throttle body!!! anyone got a surefire fix
  68. procharger kit for sale
  69. Fans and Intercoolers?
  70. MAF location
  71. Cold Side-What bends/straights will I need?
  72. Pic of my Hot-parts...
  73. Question about emissions
  74. Why so harsh on the LT1?
  75. Twin-screw vs Centrifugal
  76. A-1000 Fuel Pump Elec Wire Up????
  77. LS2 with Magna Charger
  78. Procharger IC pics
  79. BOV or BPV? Interesting webpage
  80. Gotta quick question about turbos on LT1
  81. PTK closed down???
  82. Looking for anybody running a F.A.S.T on a blown LT1
  83. twin turbo or f2 procharger
  84. Spoke with STS on the phone today
  85. Centrifugal Showdown
  86. Way to check the alignment of the blower/crank pully
  87. Procharger Rebuild
  88. Supercharger question
  89. STS turbo spool noise...
  90. Powerdyne LS1 Tensioner Pulley?
  91. Dyno place needed
  92. IAT question
  93. Update on my turbo car's running progress
  94. Just got my F1A.....PICS!!
  95. F1A pricing
  96. I have a D1SC with 600 miles on it for sale
  97. Teaser vid of my turbo setup...
  98. A few questions about FMIC
  99. messed with shift points and got great results
  100. Need some help on a setup need advice and pics
  101. Went 8's today...video inside
  102. Single turbo exhaust parts.
  103. problem building boost with powerdyne
  104. LT1's weakness..?
  105. F1-A in a street car ?
  106. National LTx Shootout! KCIR- 4.19.2008!
  107. Best Turbo Piston/ring combo for my setup?
  108. F1a LT1 block grinding. Pic needed!
  109. picking out a turbo
  110. Need airflow for sc cars
  111. couple new bests and VID
  112. thinking about supercharging
  113. Pulley change to lower boost in a P600B
  114. s/c lt1 guys i have some questions for you.
  115. Where else can boost go?
  116. Thinking about a turbo kit again
  117. Clutch opinions....please feel free to post
  118. Pump Location
  119. Boost seems like it takes to long to reach.
  120. Bypass valve vacuum line
  121. Are 55 # to much?
  122. need some guesses...
  123. Anyone with ysi or cogs, please step in
  124. Forged LT4 385 boost it?
  125. 500rwhp on 6.5psi... any good?
  126. look what i get to play with....
  127. Lookin for a pulley
  128. Powerdyne LT1 pulleys: What's unique about them?
  129. E85?
  130. Procharged LT1 383, what injectors?
  131. A Few Questions
  132. Radical boost spike 41psi!!!!
  133. Anyone here of a electric supercharger?
  134. Supercharger for 1994 z28
  135. SDCE tensioner...replacement
  136. Crank/blower pulley issue
  137. gear ratio for boost
  138. Powerdyne on a LS1 F-Body question
  139. How adjust tension on sc?
  140. thinking about supercharging
  141. what do you use for.....
  142. Procharger MAF massager?
  143. How much RWHP can my 2 bolt lt1 handle?
  144. Oil in intake tubing
  145. My turbo vs my supercharger. Two different feelings.
  146. nitrous nozzle
  147. Which retard/ignition box for Boost?
  148. fuel issue
  149. two new bests
  150. Just listed PROCHARGER set-up for sale
  151. Help me out
  152. Where to get 10 rib Vortech pulley
  153. where can i find turbo manifold for a lt1
  154. Throttle body size and FI cars
  155. Supercharged SS...
  156. Speed density vs maf
  157. Airflow during datalogging with sc unit
  158. whats the difference?
  159. Need help putting together a shortblock for boost...
  160. Intercooling
  161. has anyone seen or got
  162. finally got the car out of the garage after 11 months!
  163. need a little help on a DIY TT
  164. Running VERY LEAN at part throttle...miss stumble
  165. whats a good turbo cam for my lt1
  166. P-1SC with Hotcam?
  167. Drivability & big injectors (questions)
  168. TT or buttmount
  169. cam help 224/236-114
  170. twin turbo pics
  171. LT1 turbo setup
  172. Intake manifold question.
  173. Ponder this air intake idea for a moment...
  174. Carb'd LT1 Turbo system question
  175. Placement for boost gauge fitting in intake.
  176. Returnless fuel systems as opposed to retuned ones
  177. T-trim in the future? Your thoughts?
  178. How NOT to modify your turbo
  179. Those who have moved radiator/fans forward
  180. Breather w/Built-In Air/Oil Separator (Crank Case Evac)
  181. Banks Twin turbo
  182. Blown SC motor - need rebuild advice! - 450hp target
  183. New Best!
  184. D1SC or F1A
  185. PLugs for boost
  186. Blown Cometic MLS head gasket
  187. plug gap from .38 to .30?
  188. supercharger
  189. My MAF DIED!
  190. supercharged
  191. BPV question
  192. running maf on pressure side?
  193. 383 help
  194. turbo or supercharger???
  195. R.I.P D1SC.. 56k BEWARE
  196. Turbo Coupler
  197. block for boost
  198. lost boost after intercooler install?
  199. Dual walbro setup
  200. Egr Tube
  201. Ported heads question
  202. Not making anywhere near the boost I should...ideas???
  203. Where's your guys fuel pressure at?
  204. Okay, kind of a odd question about FI, but please step inside to add your 2 cents...
  205. Supercharged question...
  206. i don;t know much about v8's new to them
  207. fuel presure regulator ?
  208. Who's run a STS on a box stock LT1/6-spd??
  209. Who is running a stock cranked stock rodded 355?
  210. tuning stock ECM and boost
  211. Mid mount Twin Turbos.
  212. procharger piping
  213. Adding N20 to my boosted 355..how big of a shot?
  214. boost went from 6 max to 3 1/2 max. What happened?
  215. 7" vortech crank pulley
  216. Radiator relocate mod ?'s
  217. Injector headache
  218. New Turbo Junkie, need help
  219. turbo question
  220. what supercharger is the best 4 95z28 !!!
  221. Final T-Trim/FMIC pics....
  222. ATI damper/ASP pulley
  223. twin turbo....?
  224. Will this EVO beat me??
  225. Is my d1sc broken?
  226. STS Tubro Question...
  227. A short start up video
  228. How do I contact Lonnie Pavits???
  229. Intake Temperatures
  230. procharger plus meth
  231. FMIC Vortech T-trim Camaro setup pics if curious..
  232. Pump gas vs. Torco 114
  233. Couple of Procharger ???'s
  234. Anybody replace their Bypass Valve with a BOV ?
  235. Precision Turbos On Sale Again!!
  236. abs delete with procharger?
  237. A/w intercooler water pumps
  238. Do i need an FMU with a tune?
  239. tension pulley for 12 rib belt
  240. 1 7/8 headers too big?
  241. Limit of stock crank & 2-bolt mains?...
  242. Procharger "Battle of the Outlaws"
  243. Little Dyno Vid
  244. mild boost twin t3 ls1? need help info and ideas.
  245. Opinion Time : Upgrade P1 or N2O
  246. 383 what size turbo?
  247. F.A.S.T users (Roadie, John), the car is running.
  248. vortec aftercooler question
  249. oil return line pics?
  250. ATI Hub Engagement on Crank
