Injector Size For E85
Old Apr 22, 2008 | 10:52 PM
c0rey's Avatar
Hey im upgrading my whole set up here and so far here is what I have for a fuel setup. Im going to run dual intank pumps with the stock lines. I want to burn e85 all the time. Right now I only have 42.5LB injectors and Im looking for a suggestion on what to get. I want something I can grow into with the car. Going for 500-600 Hp running on the e85. Ive been looking and it seems the biggest Hi-Z (that I have seen) are motoron 60 lbs. If needed I can buy the converter box or ms 1 to control the fuel side of things.
Old Apr 22, 2008 | 11:30 PM
reamo04's Avatar
racetronix makes a 79# HI-Z that can be found on thunderracing.com
Old Apr 23, 2008 | 12:29 AM
1982z28with18s's Avatar
I'd just get some 96lb injectors and use the honda resistor boxes, you should be able to get both for around $400 used.
Old Apr 23, 2008 | 01:59 PM
c0rey's Avatar
I know that you are running the boxes can you give me some more info on them? What all does it entale to get them wired in? Where should I look for some injectors at?
Old Apr 23, 2008 | 03:14 PM
cause4panic's Avatar
Dont know if you have an afpr or if your fuel pump would like it but mototrons flow 60 lbs/hr at 43.5 PSI ( 3 BAR ) and up to 85 lbs/hr at 87 PSI
and mine idle like a dream on a completly stock motor lmao
Old Apr 23, 2008 | 09:41 PM
c0rey's Avatar
Ya undecided on what to do as of now.
Old Apr 24, 2008 | 12:39 AM
You take the pink wire that goes to power the drivers side injectors and wire it into the box. Then use the 4 wires coming out of the box and run to each injector. Then do the same for the passenger side.
Old Apr 24, 2008 | 08:01 AM
c0rey's Avatar
That sounds good. Is there a specific honda box to look for?
Old Apr 24, 2008 | 08:33 AM
I got mine from a buddy who is big into the honda racing world so I can't say. I think it was early 90's civics though. I'll ask him which ones exactly.
Old Apr 24, 2008 | 09:10 AM
blkchevyz's Avatar
you running into any starting issue with that? i was tuning a friends car we had to up his pressure only 10 psi to get the duty cycle down and its not a big fan of starting right now... but he's having some throttle body issue so that could be the issue to.
Old Apr 24, 2008 | 09:39 AM
c0rey's Avatar
Ya the converter boxes seem to be the way to go.
Old Apr 24, 2008 | 10:02 AM
blkchevyz's Avatar
aeromotive sells some regulators that reference boost, and raises it on a 1 to 1 basis... i assume that means 1 lb of boost equals 1 lb of fuel.
wonder if that would help when running a smaller injector. i wouldnt consider it a fmu but seems like it would be pretty stable and wouldnt make tuning that difficult.
Old Apr 24, 2008 | 01:32 PM
zero starting issues. only two constants i changed were minimum pulse width and injector constant. i do get a little lean tip in hesitation but i havent tuned it at all. and thats to be expected with any large injector.
Old Apr 30, 2008 | 03:06 PM
c0rey's Avatar
Any more news on what box I will need?
Old May 1, 2008 | 05:25 AM
http://www.hondata.com/techinjectorwiring.html
