Traction cont relocation kit IDEAS????
Old Apr 27, 2008 | 08:31 AM
bski224's Avatar
Got the STUPID traction cont kit in my way of install of a p600b Anyone know where I can find a relocation kit or delete kit for this. Its a 97z
Old Apr 27, 2008 | 10:21 AM
Funkybird's Avatar
http://blowerworks.net
They sell one. But its an outrageous price for 3 lines and 2 fittings. I just did this on a buddies car.
Old Apr 27, 2008 | 11:02 AM
chasmosis1's Avatar
I'm not sure about the Procharger setup, but I know for my Vortech I had to delete the ABS as well, but I also installed an FMIC which requires alot more room in that area. I used this system which deletes the TC, ABS and does a line-lock at the same time: http://www.sjmmanufacturing.com/cam_brk_lt1.html. You will need a 4-channel system to delet the TC.
Chas
Old Apr 27, 2008 | 01:04 PM
Boosted_Z28's Avatar
It was necessary to re-locate the cruise control module and the ABS modulator/motor pack when I installed my first Procharger on my car. Here are some pictures to give you a better idea of where they needed to be re-located to. I modified the mounting bracket for the ABS modulator and made an additional bracket to hang the unit on the frame rail. Hope these pictures help some.
Old Apr 27, 2008 | 01:53 PM
bski224's Avatar
Thanks guys. Good info. I think I will just try and relocate the bracket and move the abs to a diff location. The cruise cont is already relocated.
Old Apr 27, 2008 | 02:01 PM
chasmosis1's Avatar
Damn, that is nice Boosted Z28. I just looked at your garage and I was just wondering why you even kept the ABS?
Chas
Old Apr 27, 2008 | 03:04 PM
Chas
Good question Chas...I guess I was wanting to retain as much of the factory equipment as possible, but as the car has progressed to different levels, I'm much more incline to eliminate some of it. The two items I struggle with is the ABS/ASR system and the A/C. Ultimately, both will be gone, I just want it all to look right. Thanks for the compliment!
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
