Found my problem (crank case venting)
Old Apr 12, 2008 | 01:08 AM
reamo04's Avatar
so, the other day i started my car, drove it around the block,a nd then smelt oil
Thought it was the turbo drain, welll, did it again today, and its pushing oil out of the seals.
So, my question
1) just install a breather on the passenger side valve cover
2) Take the passenger side "breather tube" and disconnect it from the TB, then run it with an oil seperator and connect it to the inlet side of my turbo?
Old Apr 12, 2008 | 08:06 AM
Boosted_Z28's Avatar
I'd suggest you research this some before you decide. There has been a lot of discussion regarding this issue with a F.I. motor. The bottom line seems to be choosing a breather system that is adequately sized, as some people were experiencing similar problems after they installed what you were describing above. This was due to the fact that the system was working, but it just wasn't adequate when in higher boost levels. If in doubt, run a -10 line from each valve cover to a vented catch can. Try searching in this section a little and you will find several discussions on this topic.
Old Apr 12, 2008 | 09:28 AM
jsetzer's Avatar
Let me know what you find out. This could be my problem too.... Got oil pretty much everywhere. Its not leaking from the intake or valve covers....
Old Apr 12, 2008 | 01:12 PM
reamo04's Avatar
boostedz28, i searched and found that most people do the two things i mentioned.
The -10AN lines though, on the passenger side would that come out of the "breather hose" area, then i'd have to tap the driver side?
If nothing else, I will run the Mr. Gasket exhaust setup
Old Apr 12, 2008 | 03:05 PM
The problem that some have experienced with either installing a small breather into the valve cover, or installing an oil seperator into the 3/8" existing breather tube, is that it is not adequately sized for the amount of pressure created in the crankcase when the motor sees higher boost levels. In cases like this, one answer is to attach (best acomplished by welding, but can be installed other ways as well) AN style fittings to each valve cover and then running a -10 line from each v.c. to a vented catch can. This eliminated any oil from being pushed out of the motor and/or blowing out seals.
Old Apr 12, 2008 | 07:23 PM
600hplt1sm's Avatar
I have had alot of issues with oil as well, I tried the breathers and it helps a little bit but the breathers get saturated and still mist oil out on the valve covers. I just installed 2 new valve covers and ran 5/8" line from the passenger side valve cover and the pcv valve out my intake into a air/ oil seperator and too the inlet tube on the blower and i have seen a huge difference, and i have no breathers at all now.
Old Apr 13, 2008 | 04:37 AM
reamo04's Avatar
well right now, the most boost it will see is 10psi on this build, and modifying the VC's is a PITA since i have to take the passenger side header off to get the pass. VC off
Old Apr 13, 2008 | 02:00 PM
roguedriver's Avatar
I'm supprised nobody has caught this yet, but your problem is that you have your passenger breather hose still going to the throttle body. That needs to be either a breather or to the inlet side of your turbo. Basically, your pressurizing the daylights out of your crankcase with it still hooked up there. Cap it off at the TB. I even had to use a small wire to wrap around the flared end once capped off cause i kept blowing the rubber cap off causing a nice big vac leak. I'm running from the valve cover to a seperator to the inlet side of my charger and also a breather for an oil cap. I haven't seen any oil in the seperator either. Give it a try.
Ken R.
Old Apr 13, 2008 | 02:04 PM
reamo04's Avatar
roguedriver, thank you.
I just needa get an oil seperator, where are you guys finding them at?
Old Apr 14, 2008 | 08:20 AM
jsetzer's Avatar
Buddy just bought a nice looking one on ebay for cheap, I'm going to go look myself.
Old Apr 14, 2008 | 08:56 AM
The SRZ's Avatar
Try these guys. It's what I'm using and it works flawlessy and pics up all the crap. Or you can go to home depot and pic up a cheap unit that may fail under heat.
http://www.conceptualpolymer.com/new_page_1.htm
Old Apr 14, 2008 | 04:08 PM
I'm using one from Lowe's. It's just a water seperator from a compressor system. Nice part about those is you can see if your sucking any oil. Mine has been clean and free of oil and no problems with it at all.
Ken R.
Old Apr 14, 2008 | 07:24 PM
boosted-lt1's Avatar
reamo04:
My Vortech system was setup to run a tube from the valve cover to blower inlet. This would in-effect evacuate the case under boost (high pressure in the case and low pressure at compressor inlet)
I can't speak for efficiency of this setup but it 'works' for Vortech (at least I assume this was the stock Vortech setup)
-Scott.
Old Apr 15, 2008 | 08:02 AM
slowlt1turd's Avatar
I'm going to run just a cheap compressor filter from the valve cover to the suck side of the turbo and see how mine does. I may have already trashed a seal or two. Looks like either the rear of the pan or the rear main for me.
Old Apr 16, 2008 | 12:03 PM
reamo04's Avatar
well, the way i did it would have worked, but the hose is too close to my pipes and keeps melting. Looks like I am going to have to ditch the PCV system all together and just run breathers or something on the valve covers.
