View Full Version : Forced Induction
- Anyone used the electric AIR pump as a vacuum pump for Crank case evac?
- Wheres the best place to buy procharger pulleys
- Ngk Tr6....vs....ngk Tr6ix
- Supercharger and BARO
- Surging after s/c install
- Over heating
- Powerdyne User Within
- Home made STS
- Throttle body necessary w/ boost?
- running alcohol instead of fuel what would be needed?
- what plugs to run on lt1 with procharger
- blow by
- turboing an ls1. 346ci, 408ci, 427ci??
- EGT Question
- ATI 8lb 8 rib pulley needed
- need help with fmic placement in 96t/a
- Pics of my work in progress.
- turbo or supercharger
- deal or no deal. Vortech
- LS1 / LT1 Vortech YSi trim part #
- LT1 or LS1
- P1SC guys inside please...
- Need Fan help
- Turbo Experts in here please
- Plugging a hole in vortech elbow
- Anyone running an F2 in anything?
- More boost = another dyno tune???
- Can a bad ground cause accelerated corrosion in the Opti?
- valvecover breather idea...
- YSi trim 7" and 2.85" pulley combo... how much HP?
- LT1 Vortech T-Trim start up video
- twin turbo work in progress pics
- Trade ya for a 12lb pulley!! Anyone?
- Dumb Question...
- Vortech with an STS...Am I Crazy?
- Catalytic converters with FI
- Looking for a 7" crank puley...
- 6lb pulley needed
- Anybody running the Vortech Aftercooler setup with JBA headers????
- Bypass valve question
- ? on pulley change and running lean
- need pics of intake with D1SC w/ twin intercoolers....
- One more turbo LT1
- whos running an A1000 pump and how is it holding up working for you?
- Clutch preferences.... cam/blower cars
- Last video of my car before the supercharger...
- How much to supercharge LT1?
- The Great Sparkplug/Forced Induction Debate!
- Intake Tubing for S-Trim
- Are 42lbs injectors sufficient w/10lbs boost?
- D1SC and Pulley Ribs
- My Turbo build parts?
- What do you think?
- catch can
- Doing more work on the turbo kit...
- Building Blocks and it ain't lego's
- Max lift for beehives?
- Turbo LT1 Corvette Finally On the Road!
- Those with LT1, D1SC cars, where do you put your MAF's?
- Wonder if this would be worth trying????
- bypass valve install?
- Sell the SS with SC or not?
- MAF and S trim ?
- Possible to setup an s-trim, juice, and meth?
- Gen 7 and Mallory ing NO START ?
- Anyone have a 7" crank pulley forsale (Vortech)?
- Reading my spark plugs
- STREET CAR; supercharge a 355,383 or 396?
- Turbo kit, fab or buy?
- Passed smog again!
- Racetronix pump + 50lb injectors good to?
- Cam
- Dyno is done
- powerdyne questions
- walbro pump runs but isn't pumping.. any ideas?
- Finally got it down the track *video*
- Vortech install question
- to STS or not
- question on horsepower, and how much fuel to get there.
- Turbo Kit done, with Forward headers!!!
- Dyno vid, T74gts vette, 96 LT4 Vette
- 9G turbos
- Reading Dyno Graphs
- Has anyone ran custom ducting to their intercooler?
- A-trim makes 446rwhp
- tapping P600B for dual oil return lines
- what turbo charger?
- Which ignition box for my 142 blown 327 67'---
- Need pics of installed P1SC with 2 core intercooler
- Making room for turbo... PICS!
- Belt Part number
- Tight or loose Bearing tolerances
- supercharger question
- 55 psi fuel pressure at 8 psi of boost???
- Huu!! Finally getting my car together
- Progress on my turbo system
- Which Radiator?
- Lt1 383 Crank for 6" rods?What cam too?
- Big HP guys. What's your exhaust setup?
- 224/236 114lsa + Boost results?
- turbo m6's, what gear do you run??
- What's YOUR fuel pump of choice...???
- Boost with vented opti?
- O2 sensor mounting location
- Forward headers done!!!
- 97 z with procharger, runs rough until MAF is unplugged
- Help Procharger Question
- Question for HOBBS switch users...
- Block Filler- when does it become a good idea?
- Stock internals, a few suggestions needed please
- Preparing for Forced Induction
- Break-In for a new S/C motor
- anyone change the MAS on a powerdyne
- Tech questions about Procharger D1R for the experienced peeps
- Solid roller for an LT1
- powerdyne pullie sizes
- Maximum boost capabilities 3Forged 355 vs.383
- Vortech with no FMU
- Best spark plug for supercharged 383 w/ AFR heads?
- powerdyne air intake keeps blowing off!
- some problems after SC install
- 10 MPG..do I need a new PCM?
- ok crituique this build up
- Anyone have SDCE instructions for an LT1
- STS Users
- Disappointed after Boost Gauge Install
- Vortech Tuner Kits Available!
- crankcase pressure
- Forward headers almost done
- Whats everyone using for plug wires?
- Finally doing it, need a little advice
- How to lower compression without changing pistons?
- fuel pump options
- STS question about headers and air intake pipe
- Question about heads for a turbo system
- Detonation At 4000-up
- Going to the track.
- 40mm wastegate.. ok for 355 ~12-14 pounds?
- Turbo C4 corvette finished and running... WOW!! I am very happy!
- Help me fix my leaky Vortech. Inside please...
- Dual Intank Pump Y-blocks?
- STS Kit
- Critique my 355 Build-up
- FI at it best
- Blower Cam!
- Carbed 377, T76 dyno results
- Turbonator???
- boost gauge
- Measuring Impeller speed
- How important is..
- Forced Induction Timing Tables
- D-1ATi, A4 what gears
- How important are heads on an FI setup?
- No Roots?
- 355, 383, or 396?
- HELP! Just blew head gasket
- Cam choice?
- More Parts Or Smaller Pulley?
- Procharger oil return and canton pan?
- Horsepower?
- Powerdyne Question.
- PE vs RPM table used in open loop?
- ideal boost and compression ratio?
- Nitrous
- 9 or 10 lbs
- BY-pass valve?
- WOW...6.5deg of retard...HELP!
- pics of lt1 turbo manifolds! i need some!
- Engine Help
- How many of you guys run the car in open loop?
- air to water intercooler question...
- Lost boost?
- anyone more then 600rwhp with a p600b?
- big fuel problems!!!!!!!!!! help
- New to the world of boost...
- Bypass valve dumping to atmosphere on MAF car
- how many psi on stock motor
- How to adjust BOV
- Going turbo: Who makes the best single kit
- Pic's of my latest project (377/T-76):
- Forced induction with high compression
- Who has the best deal on a Procharger System?
- Cometic head gasket for ZZ502
- How low can I pulley a T-trim? Stock motor?
- Getting a NOVI 2000, do I want the regular or reverse rotation?
- tuning for vortech
- Who out there has more than 600 RWHP on their LT1 PCM?
- Boost
- The things you find on ebay
- Nitrous Express Ntercooler & BOV
- Electric Supercharger... any thoughts???
- Tuning for boost with stock pcm?
- Oil change on the blower?
- SPREAD THE WORD ATI P1sc stage 2 kit *NEW* EBAY LINK
- Updated pics, it'll be alive this week
- whats a safe max oil temp?
- Powerdyne racer rebuild anygood
- Emissions question
- max nitrous on pm rods???
- weight didtrubution
- Can someone explain to me how a FMU works?
- Rookie header question
- Cam recomendations for supercharged application
- Vortech bypass alternatives
- ATI D1 oil fitting?
- help please!
- max psi?
- quick ? quick answer. procharger users please post
- Whatelse should I get for a Vortech S-trim
- 15psi pully 11psi actual boost
- What size turbo(s)?
- Things moving along
- Guys making in excess of 700 RWHP
- Ohhh Noooo
- Vortech's YSi vs Procharger (equivalent)
- Anyone have there pulley bolt break on a P1-SC
- supercharger help!!!!!
- Anyone running the powerdyne?
- Initial turbo planning (PTK), looking for comments
- boost and cometic head gaskets
- 4" pipe
- Supercharger questions
- so close.. update pics 1996 turbo LT4 vette
- SES light after p600b install and madz28 tune. any thoughts?
- Anybody do an F1R on an lt1 yet?
- How often do you guys change your plugs?
- Procharger problems
- Coil overs with double adjustables?
- weighing out nitrous or turbo
- Aftermarket hood, Airbox(RamAir?)?
- Need help with acessorie Brackett's and Procharger.
- Running too rich - will I get my power back???
- ATI ProCharger Price Increase Coming Soon!
- header fab advice needed
- turbo or super?
- Is it nescessary to vent both valve covers?
- Backfire at idle
- MR gasket head gaskets
- Vortech S-Trim or ATI Procharger P-1SC?
- procharger users - pcv lines help
- turbo vette update pics 4-11-06
- Anyone have their spring tensioned pulley go bad on LT1 P1-SC
- Turbo kit on ebay. CHEAP....sounds fishy
- question vortech s trim
- Oil coming out of BOV...vortech supercharger guys inside please...
- D1-SC and V-Belt Setup.
- weird wideband readings and spool problems
- What is Lambda?
- ATI LT1 boost equation
- What's my compression ratio?
