Is this ABS or TCS ( in my way for procharger)
Im doing install of P600B on my 97 Lt1 Z28. On lower driver side frame rail there is a box with brake lines connected to it. Is that my ABS or TCS. I also have that stupid *** box on my valve cover is that TCS??? The unit will not bolt up with this in place, suggestions or ideas!!??? HELP
i ended up deleting my abs.. i wanted to keep it but there was no room. if you do remove it you should replace it with a adjustable proportioning valve. mine cost 40$
there may be room with your setup.. i have turbos witch require tons of piping.
