can you reverse wire a fan?
I've come to the conclusion that my driver side fan wont fit b/c of the turbo flange. Could I take that one off and put it on the front of the radiator and reverse the wires to make it push?
Since the motor is 12vdc, theoretically you could reverse the wires and make it spin backwards, but the fan is molded to pull only, not push. If your car still has AC, then theres something else that will screw you. I know there are some slip fans out there that the turbo guys are using. Do a search and you can find out the info that you want.
http://web.camaross.com/forums/showthread.php?t=585977
https://www.camaroz28.com/forums/sho...d.php?t=585977
u can wire it backwards. i mixed them up when i did my fan switch and couldn't figure out why my fans were barely cooling the engine. i walked around the nose of the car to have my shins blasted with hot air. i figured out the problem lol
NICE lol, thanks for the real world experience, going to give it a shot today.
Jul 4, 2005 05:00 PM
