Think I ran into a problem (drain related)
Old Apr 8, 2008 | 10:13 PM
reamo04's Avatar
so, had the car running this morning with eveyrhting assembled, etc.
After about 2 minutes, i believe i smelt oil, so i shut the car off.
My drain is basically horizontal, i think there might be a slight down slope, not sure yet.
My drain is a 90* fitting coming off of the bottom of the turbo, and i am pretty sure everything is parallel to the ground, i knwo the drain doesn't go up, its either perfectly horizontal or has a slight down slope.
Do you guys think my drain is my problem, or maybe i have a leak somewhere or maybe im just paranoid, who knows.
Old Apr 8, 2008 | 10:28 PM
jsetzer's Avatar
Look for leaks,
check the level - as long as its not empty it shouldn't hurt to idle it a bit
honestly the drain needs gravity, quite a bit of oil is flowing through there and it needs to be able to run down out of the turbo. One way to test would be to use a catch can below the turbo and just drain straigt into that... but if its flowing very much this would be a bad idea because you could drain your pan in a hurry.....
Also if this is the first time starting it there will be all kinds of crap that burns off the exhaust etc.... I say run it a bit more
Old Apr 8, 2008 | 10:39 PM
reamo04's Avatar
yeah, my problem is, theres not really any way i can give it gravity unless I use a pump
guess i will check it by having the hose off of the oil pan and hold it where it is and see how it drains.
Old Apr 9, 2008 | 04:16 PM
boosted-lt1's Avatar
If the drain is parallel to the ground by design, what happens when you encounter a downgrade in the road of a couple of degrees or more?
If it's a street car especially, you might experience 25*(???) grades in the road. Not sure what max road gradients are allowed to be but you would want to design to 5-10* in addition to max gradients (tolerance stack )
-Scott.
Old Apr 9, 2008 | 11:30 PM
reamo04's Avatar
yeah, im going to try to find a way to get it a little higher. Hopefully I can get it done, otherwise, i have to redesign all my hot parts
Old Apr 10, 2008 | 12:12 AM
reamo04's Avatar
well guys, got it figured out how to do it.
Just need to get a welder from my buddy again and get my brace redone.
My problem wasnt anything with my piping, etc. it was that wwhen i welded my brace, i welded on the wrong side (welded bottom instead of top) lol
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
robcarnut
Mar 20, 2015 03:40 PM
Sandersen511
Jan 13, 2015 03:49 PM
jd13
Jul 30, 2002 10:35 AM
