LT1 2 Bar Map Sensor Part number?
Old Jun 13, 2008 | 07:01 PM
DirtyDaveW's Avatar
Anyone have the part number/vendor for a 2 bar MAP sensor suitable for LT1 Forced induction?
Old Jun 13, 2008 | 08:27 PM
mdcaprice's Avatar
2 Bar Map Sensor:
GM part # 16009886
Wells part # SU-129
standard part # AS-4
91-93 GMC Syclone & Typhoon 4.3 turbo
87-90 Pontiac Sunbird Turbo 2.0
84-86 Sunbird (actually any J-car) turbo 1.8
886, 012, 539, 609, 701
Old Jun 13, 2008 | 08:43 PM
DirtyDaveW's Avatar
Wow! Thanks for the info!
Old Jun 15, 2008 | 02:36 AM
96SilverRam's Avatar
MSD part # 2312 (summitracing.com) 2 bar map sensor
Old Jun 21, 2008 | 05:42 PM
Bryan 94 Z28's Avatar
Stupid question, but only need a quick answer: if I were to get a 2 bar MAP sensor, can I use LT1_edit to reprogram the PCM to actually utilize it? Yes/No?
If yes, I shall get one. If no, I will not, as my tune with the standard MAP sensor works decently enough for now.
Old Jun 21, 2008 | 07:21 PM
akafred's Avatar
you need to loose the maf and do a ton of changes to get it to work properly.. read the 2 bar thread in the pcm programing section lots of info in there.
also you would need tunercat to set the baro reset. you could get someone to do it for you or send you a modified 2 bar tune
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
ro2207
Dec 1, 2014 01:02 AM
