Boost/pressure closing AC door?
Old May 13, 2008 | 12:23 PM
Pampered-Z's Avatar
Does anyone have problems where under boost the AC seems to stop working in that air stops coming out the dash vents. I'm thinking that when intake vac turns to boost the pressure is closing the AC door. If I install a check valve to stop boost from feeding back into the line would that cause issues?
Old May 13, 2008 | 09:30 PM
'97 30th Anniversary Z/28's Avatar
http://shbox.com/1/vac_check_valve.jpg
I don't know if 93's are different
Old May 13, 2008 | 09:56 PM
SC/TA's Avatar
I have went through 3 check valves in the last year. I am not sure if anyone makes a stronger one but if you find one post where you got it.
Old May 14, 2008 | 06:48 AM
97WS6Pilot's Avatar
No problems here. The check valve works fine. Dash vents work fine.
Old May 14, 2008 | 01:09 PM
Pampered-Z's Avatar
Great! thanks all!
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
z28cam1993
Sep 9, 2015 04:08 AM
