View Full Version : Forced Induction
- BOV location
- Any interest in builder turbo kits?
- What do you know bout this companies product?
- Any F.I. guys using the Impala SS stainless shim head gasket?
- Those'who have done the EFI 24X coversion (that are boosted), I have questions...
- 50/50 methanol/water or ethanol(denatured alc)/water ?
- LT1 love in GM High Tech
- LT1 Bank 2 running Lean!! Please Help
- LT1 Boost Customer Roll Call!
- looking for conservative ls1 turbo set up??
- P600b Qustions and Dryer Hose
- Thinking of going vic jr intake. What all do I need to consider?
- Thinking of Selling the LT1 Boost Shop Car kit
- gmhightech puts waste gate on supercharger
- LT1 Boost PT88 Build
- If my Electronic boost controller is set to 15psi, should I hear it open at 5psi?
- Twin 76mm on a LT1?
- Powerdyne rebuild #2 ...what to do..what to do ....928 Motorsports?
- whats the better block for me to build up? 2 bolt or 4 bolt lt1?i
- sbc turbo manifolds
- Pro Charger for LT1 BD-11
- supercharged stock bottom end ltx dyno results
- Boosting an LS1
- ltx vs. lsx forced induction builds
- LT1 Boost Customer build... again
- Installing BMR Tubular K-member for extra Turbo Hotside Clearance, not...
- lt1 remote water pump?
- WOT timing retard with DISC 95 383
- ATI damper for procharger 396
- 1993 z28 need how to turbo guide PLZ
- aftermarket ecm/ which one for forced induction? also what do i gain?
- 95 z28 front mounted turbo build
- Oil Cap leaking oil - Need special Oil cap with filler neck
- what is you opinion on the sts turbo kit thinking of a turbo build later
- Supercharger Setup, Help!
- Turbo build questions
- should i have different spark advance depending on 100% meth of 50/50 meth/water
- lt1, p600b, 11 psi boost, meth inj. what timing should I be at?
- guestimation of track times? f1a 383 18psi.
- Tuning a Twin Turbo 94 obd1 Impalla SS
- building only 4psi of 18... f1a... just rebuilt.
- what cam for lt1 with f1a
- catch can for my lt1
- bov needed?
- supercharger not making enough PSI?
- acl race series bearings
- ProCharger Video Challenge 1st place $5,000!
- what are all the sources of false knock on a supercharged 93 lt1
- Finally dyno'd my Camaro.
- injector size
- More boost!
- LT1 Boost news
- Procharger pulley size to make 8psi on a 383
- LT1 junkyard turbo advive needed
- Looking for some help on a new build: 355 LT1 with single turbo...
- Radiator relocation
- Canton oil return?
- supercharger vs turbo on 96 z28
- fuel pressure drop during boost - help!
- Fort Worth - Mechanic/Shop
- Best price on a procharger kit ?
- Paging mzgp5x
- Motor build; could use some advise/expertise
- Any of you guys here tried the Racetronix 80# High Impedence injectors?
- e85 or 100 octane?
- Solution for crankcase evac -Vacuum pump
- CA Chasis dual and single gear drives
- Save Thousands of Dollars - REALLY!
- LT1 with Procharger and Methanol injection kit... should I add nitrous?
- punch me in the face
- beware of the cone on F1 prochargers!!
- One catch can enough?
- Vacuum sorce from master cylinder?
- .96 or 1.15 a/r housing?
- Electric exhaust cut-out
- Plug gap with turbo and LSX ignition.
- 3 bar map, on a lt1 intake
- Almost back together! Back in black!
- Filter for Prochargers Bypass Valve
- Kooks = no oil cooler. Will I still be alright?
- Supercharger unit comparison
- 24X and boost, what spark plugs?
- Procharger oil (there is got to be something else i can use )
- LT1 with Ysi setup.
- car running super rich
- LOw boost?
- Essential gauges?
- New To Boost. Opinions Needed!
- LT1 rear mounted turbo please help?
- Intercooled or boost cooler
- Running oil lines to supercharger
- Belt Part # for 4.5 PSI Powerdyne
- 24X guys.
- LT1 Boost TT kit Build
- Procharger D1SC impeller?
- Anyone running nitrous with FI?
- New LTX twin turbo kit coming soon
- Valve train for TC78 turbo on 383?
- Fuel system for a Procharged 383?
- setup with FMU and BRT?
- MAF conversion?
- For you turbo folk...strange ebay find
- rwhp estimate?
- Which route on tuning?
- cam timing for 383
- Need few tunes to compare....
- Rebuild current shortblock or just buy another?
- Crankcase breather, may have found my issue
- Help with HP and TR Up-grade!
- Whats a good comprimise for C/R
- Fuel regulator change..what do i change in the tune?
- Intake Gasket Recommendations for High Boost?
- Another LT1 Boost customer build
- Question about head ports being smaller than the intake ports!
- T-trim with built bottom-end and stock heads...What kind of power will it make?
- White smoke underhood.
- supercharged cam selection...
- Dyno'd my car today
- Comp Cams 224 /236 .605/.624 what springs?
- Underhood turbo pics please...
- monoblade worth it?
- turbo teaser
- Have a good idea on how to monitor/capture data?
- Wastegate dumped into exhaust or vented to atmosphere?
- electric supercharger?
- i need your opionin on a turbo...
- 98 camaro what motors will fit
- Lots of boost, which crank Compstar Comet or Eagle ESP?
- Timing for 12+ psi
- Help finishing my 5 year old project
- Bosch bypass rating?
- Vortech Oil Feed Fitting
- Nitrous fuel line installation
- Anyone running a JEG's SFI hub?
- Which heads / how much boost
- E85 - Conversion
- paxton blowers on lt1's?.
- Tired of filling the bottle - 383 Blower Build
- Twin Turbo Question - Wastegates and Blow Off Valves
- Max WOT timing ?
- Nordskog A/F ratio Gauge
- fuel pressure drops to 40 at 5k rpm????
- Mahle -31cc 2618 proper quench shape?
- LT1 Rebuild for Boost-Piston rings?
- Turbo pipeing for t67
- No More Smoking!
- 4in. downpipe split into dual 3in exhaust pics.
- stock cam???
- Routing boost gauge tubes/wires thru the PCM grommet?
- Belt Slip
- new 928 motorsports impeller, now to lean?
- New track times, but also broke something!
- Recirculate bypass valve?
- LT1 D1SC Belt Slip OR Intake Elbow problem
- question about parts
- hole in piston??
- Part # for 2 bar GM map sensor
- 8's on a stock ls shortblock!
- Poor mans catch can...
- electric supercharger??
- Installing tubular K member with engine in the car?
- Where to get 2.75" idler pulley 8 rib
- Short in car video of 14psi in 4th gear from about 2K on up...
- Dropping engine out the bottom
- Fuel System Limitation beyond 9psi?
- Fuel Pressure per PSI increase?
- Do you see this? Tell someone you've got over 600 rwhp and...
- Using a bower cam with a turbo
- Oil drain fitting from vortech to oil pan ?
- Eng. bearing choices/new build
- bigger intercooler making me run more rich?
- Crankcase ventalation
- 60 # injectors to much for me ?
- turbo parts list?
- Intake Elbow Issue
- Is (uncorked) AFR normal?
- Who is using tr6 plugs, and what gap?
- September Sale on Turbo Kits...
- Need header advice, keep my RKSport mids or go to Pacesetter LT's?
- Another FI opti vent thread
- Pics of my 6.0L Build....
- Fmu ?
- Took my TC78/5.3 to the track, 9.43 at 145
- Wideband install ?
- Injector Sizing (yet again)
- Need help
- MikeGyver's Turbo 383 Build.
- Turbo Cold Side Piping Question
- I'm retarded. Tell me why.
- GT45 Turbo ?s
- LT1 Boost Customer dynos his car
- formula intercooler pics ideas
- Super or TurboCharged Camaro????
- Turbo keeping ram air?
- Finally started
- 383 t-trim
- Vortech Supercharger questions
- Couple of teaser pics.....LONG build finally ending
- Want to remove plastic cover in front of radiator (cross flow for intercooler)
- Runnin hot
- How much boost on pumpgas?
- log manifold kit opinions
- log manifold? material?
- A Turbo LT1 owners work is never done...
- Vortech SC belt sizing
- Adding Walbro pump to my setup
- How fast on lt1 with 76mm turbo?
- Spark plug help?
- D1SC help
- 1000+ rwhp
- ? regarding Cometic gasket bore dia.
- Difference between BOV and bypass valve?
- crane hi-6 question
- Need some supercharger help with Lt1...
- New to this Forced Induction stuff
- Need a hand troubleshooting...
- 6.6l diesel turbo on lt1
- griffin radiator setup for lt1
- steam pipe
- How much hp and how fast have you been with your s trim?
- Which heads to make 650 rwhp
- Vortech SC owners, few questions
- Ebay mandrel bent 3" pipe shapes...
- still breaking up
- K&N or SLP
- Good tuners in NJ
- thoughts on this blower cam?
- FMIC on a LT1 formula
- fuel injectors shut off at 4400 rpm.Pleae help!
- 9.53 @ 133mph!! First time with setup
- best piston choice for daily driven s/c combo?
- Creative exhaust setup?
- LT1 T/A FMIC Guys
- finally got my heads off! is this where headgaskets normally go apart at?
- need some help with a rear mount turbo kit
- New turbo kit for the shop car
- What does it take to make 850+ rwhp long block.
- Need help w/T-Rex
- Longest Lasting Z28 w/Vortech
- When to change blower belt??
- Slow spooling twin turbo setup i need help.
- Copper head gasket not sealing?
- Intercooler question
- any loss by small plug gap
- Took the Turbo LT1 out for another 'evaluation' drive :)
- F1ACog Drive Build update
- House of Boost LT1 Set up
- What lifters and rockers for 6500+rpms
- 600B pulley options
- Another LT1 Boost turbo build
