PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35
  1. Will these heads work w/ my setup?
  2. opinions on pistons for a 355 and where to get
  3. LT4 Knock Sensor
  4. how much boost with 9.5:1, also need advice on my next build
  5. Turbo guys need this shirt
  6. Can I vent my bypass valve to the atmosphere???
  7. Procharger question
  8. maf massager
  9. Big frame (industrial) T-76 for sale
  10. Big enough injectors for my setup?
  11. 8.97s @ 152 mph
  12. 6 psi kit on heads and cam engine
  13. lets talk "keeping things cool"
  14. New motor New Dyno #'s ......
  15. Throttle problems
  16. less power with low compression, can it be made up with more boost???
  17. Who has the longest time/miles on their blower set up?
  18. S/c?
  19. Info on CR with a YS-Trim?
  20. Turbo/Supercharger Help needed ASAP
  21. kenne bell
  22. Magna Supercharger for c5
  23. WTB ati d1
  24. need parts for a V9 kit 98 LS1
  25. Ok got another new toy to play with :)
  26. building motor for 500-600hp
  27. What turbos are made for a LS1
  28. Front mount IC question
  29. Turbocharger installed for under $3,000.
  30. FS: custom CAS intercooler
  31. Is there a CARB Turbo?
  32. supercharger advice!!!!!
  33. What do I need to safely run 8# ATI on stock LS1?
  34. Q's About ATI P600B
  35. Video of my procharged 69Z28
  36. breathers necessary on s/c'ed motor?
  37. Are you sure 42" belt is correct length for belt?
  38. Twin Turbo
  39. What pulley for a 383 w/ ATI P-1SC
  40. Rich or any other blower experts ......
  41. HOw much power does a supercharger give ya?
  42. I need to make contact with someone familiar with carbed RAJAY turbo setups
  43. heeeeeeeeeellllllllllllllllppppppppppp
  44. Twin turbo question
  45. how dumb would it be to put a blower on an 90k mile lt1?
  46. What can I do to stop the plastic pipe on my Vortech from popping off?
  47. Powerdyne 9psi pulley?
  48. Pics of a very nice twin turbo LT1 Impala SS....
  49. Question for anyone running Procharger F1 on a 4th gen.
  50. Dyno numbers for the JY twin turbos
  51. D1 pulley question
  52. SD sping loaded tensioner
  53. Attn: yellow Z28
  54. Need part # for ATI belt with 8# pulley
  55. Difference between D1 and D1SC
  56. Need Turbo advice.. lots of questions for u pros
  57. Screw ball bearing turbos
  58. Boom #9
  59. Guages install
  60. Intercoolers: Air-to-air vs. Water-to-air
  61. Boost goes up to 3# then goes away...WTF?
  62. 450rwhp then boom!!!!!
  63. Forced Induction cam?
  64. forged speed pro's
  65. S- trim
  66. Engine Buildup Help!!
  67. Forced Induction
  68. Greddy Type-S BOV
  69. Good enough cam for now?
  70. 8 PSI supercharger on a stock 97z28
  71. Ls1 cranks
  72. What compression would you run??
  73. stops pulling at 4000 rpm's
  74. turbo system done for $812.00
  75. SC'd 3800 question
  76. Low Imp Injectors
  77. 8# ATI reliable on LS1 Engine?
  78. Turbo and timing, reliability ???'s (intense)
  79. TPI 383 ATI build up recommendations
  80. street/drag superchager
  81. Powerdyne ?
  82. CC306 too much for blower?
  83. turbo technology oil drain-back problem
  84. Can you run water injection instead of an inter/after cooler???
  85. How loud is a D1?
  86. anybody successfully used SC and small shot of nitrous?
  87. Any of you running 3 plug ranges colder?
  88. Hot cam vs. Xe 218/230 114 vs 224/236 114
  89. Need some advice and suggestions from you guys
  90. Looking for a Turbo Tech LT1 turbo manifold.
  91. How much horsepower can a stock block handle if?
  92. T88 or 91mm+382Ab LS1+?
  93. AC Delco R42LTS Spark Plug ???
  94. Vortech Aftercooler
  95. PVC pipe after the s'charger? (pressurized)
  96. Cam question?
  97. new procharger question
  98. What would cause this????
  99. Maxed Maf?
  100. T76 Q-trim for turbo sale
  101. 2 grand nat turbos on LT1?
  102. 10 PSI , intercooled, stock bottom LT1 on ebay
  103. Engine problems...need help
  104. How effective would this single turbo be?
  105. Vortech E-trim Has anyone used it?
  106. Turbo Tech kit....is this alot of HP??
  107. aftermarket computer
  108. How much horsepower can a stock LS1 block handle?
  109. fuel pump
  110. where do i get a cog setup for my procharger?
  111. New motor smokes... alot...
  112. ATI install and pulley questions
  113. Turbotech kit with solid Moroso motor mounts
  114. All the pics i can get for FMIC setups plase
  115. electric water pump ok for FI lt1?
  116. Pulley combo's...
  117. anyone install intercooler under driver side headlite?
  118. Running take piping: ABS is completely in the way... need help
  119. Could using a FMU and an Inline Pump w/o a S/C Cause stumbling under loads
  120. Torque Converter Brand for Hi-po Setups?
  121. rotate my racegate 1/4 turn?
  122. SuperCharger??
  123. 2 Many Blowers!
  124. Boost on hyp. pistons
  125. trouble with fmu
  126. Sidepipes and Knock Sensor
  127. Low lift vs high lift?
  128. Tranny Cooler & Intercoolers Fitment
  129. LS1 twin turbo
  130. Vaccum pumps, ......agian
  131. Did i do this right?
  132. Finally got some chassis dyno numbers for the ProCharged 540
  133. Why higher LSA on cams for SC engines?
  134. At what point is it necessary to upgrade?
  135. Where to buy a power pipe?
  136. Spark plug Q I can't find in search
  137. Installing a P-1SC any hints.....
  138. people using Turbo Tech kit and headers.
  139. cog belt setup for prochargers...
  140. Pontiac folks with Procharger...need help with filter getting wet
  141. Who makes the best ignition?
  142. O-ring
  143. Anyone looking for a pair of t-66's?
  144. Problem with Crane?
  145. Whats my S/C Z worth??
  146. What short block for FI
  147. Water pump problem - Vortech Aftercooler
  148. 67-69 Ss
  149. gn motor in a 4th gen f body
  150. ATI bracket drawing
  151. Who needs a Turbo for a project? for sale.
  152. Whatsup with the Powerdyne Cobra Head solid intake tube???
  153. 600rwhp?????
  154. Summer supercharger sale!
  155. Turbo parts?
  156. Gear ratio opinions?
  157. Adding a turbo?
  158. 210cc vs 220cc for my app
  159. vortech vs procharger mounting differences ??..
  160. Cam advice?????
  161. Optimal timing with water/alky?
  162. Intercooler sizing
  163. what is a good price for a used powerdyne???
  164. AFR's Hydra-Rev Kit. Anyone use it?
  165. is it just me, or do these hooker LT's hang mighty low?
  166. looking into getting started
  167. Thermostat ?
  168. motor
  169. weird ignition problem
  170. Where do you get Vortech Cog info at ?
  171. Ive got BOOST but NO inlet tubing
  172. Hard intake tube for P1SC?
  173. T trim does appear to have belt slip now
  174. good blower for a daily driver?
  175. Stupid Question
  176. Cam Selection
  177. some rambling if you're bored..
  178. 711rwhp 745rwtq
  179. Which Fuel Injectors?
  180. Nitrous with blower...
  181. Spun bearing = confusion 355/383/396?
  182. T-Trim Only making 5lb Boost
  183. Need Help...
  184. New to FI would like some suggestions
  185. how to hook up Racegate
  186. One mean turbo
  187. Help me pick my next mod
  188. a few pics of my custom Formula single turbo kit....
  189. Difference in trims?
  190. Supercharger w/ a nice whine to it
  191. 385 stroker, Rod hitting oil pan ?
  192. Do you need a large Turbo?
  193. Going supercharged
  194. What the hell is going on with these pistons
  195. Holley roots type
  196. anyone running an F1 procharger on thier LT1
  197. header efficency
  198. How loud are T-Trims?
  199. Twin Turbo setup
  200. Program for new supercharged motor
  201. Adjusting BOV
  202. lifting the heads?
  203. Pulling my hair out trying to find gates blower belt! Where to buy?
  204. What are my options for inter/after cooling my s-trim setup???
  205. Twin vs single turbo- where, when and why
  206. Boost off the line
  207. Holy oil temp!! Turbo guys
  208. Just another reminder to those who are CONSIDERING a twin turbo kit....read inside!
  209. What to do for a new fuel system????...
  210. vortech superchargers
  211. Oil pressure problem
  212. Will not pull past 4000 RPM
  213. How does a FMU recalibrator work?
  214. Short block assembly or stroker..
  215. Camshaft Question
  216. extra intercooler
  217. Why are there so many fast turbo stangs but not f-body's
  218. New plugs and still have a random HARD miss....
  219. ATI PRO CHARGER on 89 IROC
  220. Twin turbo headers
  221. Need help with crankcase pressure?
  222. Cams for Turbos
  223. P1SC Question
  224. Turbo charger help
  225. whats the diff between turbo, ,and superchargers
  226. What is your set up (turbo guys)
  227. Paging Scz28!
  228. shopping for blower
  229. Need help choosing turbo kits
  230. Weiand 140
  231. Spark plugs and gaps.....lets hear it...
  232. shaft rocker valve cover search continues
  233. Stock heads with turbo?
  234. Car runs crappy on 9 lbs. of boost
  235. Cometic or Wire-Lock Head Gaskets?
  236. Turbo kits for big block 69 Camaro?
  237. "Melrose t-top" valve covers hit shaft rockers
  238. Powerdyne internal belt?
  239. Nitrous and alky
  240. Thinking of going turbo please help
  241. Running way to RICH???
  242. turbo guys - part throttle boost?
  243. Overspinning the S-trim
  244. free conversion program
  245. Clips of your blower car?
  246. Battle of the Boost - Turbo vs. Centrifugal vs. Roots
  247. HELP > Blown ring land on Procharged LT1 > Options?
  248. Z28 runs bad after solid intake install
  249. Anyone runnning Speed Pro Powerforged Blower Pistons????
  250. Running out of fuel, fuel pump?
