PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. STS 1/8 mile times
  2. Eng combo & help with missing parts
  3. Checking Options on Forced Induction
  4. fuel pump install???
  5. 166k miles on lt1 is Supercharging a bad idea
  6. Vortech loosing boost
  7. Supercharger tuning questions please...
  8. whats the best heads for a procharged 355
  9. would 30#ers be enough for this ...
  10. OK guys, school me IAT, boost, O2
  11. Eaton Root style Blower coming soon...
  12. Stock Hub double keyed.. will it hold? YSi-trim
  13. LT1 Turbo Headers Done!!! **PICS**
  14. Garrett GT40 & GT42
  15. thinking about going FI
  16. pump gas + boost, what is the max?
  17. Easy Question about intercoolers..
  18. Carb enclosure?
  19. ? about Procharger intercooler
  20. Vortech aftercooler installed now ss hood won't close.
  21. Vortech Ultra-Grip Pulleys & Blower Overspeed
  22. Question for turbo guys?
  23. Where to buy rubber couplers?
  24. Sts Kit Questions????
  25. Vortech How much boost?
  26. Need help with building a boosted Little M engine
  27. Approximate cost for just parts?
  28. Can I rebuild my supercharger?
  29. put me over the 500rw mark
  30. Reichard Racing Ultra Grip pulleys
  31. Speed Inc.-Single Turbo-348ci -844rwhp 813rwtq-stock pcm
  32. How much RWHP to run 91mph
  33. How to measure blower pulley?
  34. Selling D1SC setup and LTs for LT1
  35. Do you guys think people would buy complete GT40,GT42, T70, T76 turbo kits for $4000?
  36. Getting Closer
  37. power coolers?
  38. Felpro 9966 headgasket?
  39. What brand STB with Aftercooler
  40. Whats the difference between Super T70 Turbo and Garrett T-70
  41. What would be a good blower for this setup???
  42. Installing Aftercooler this weekend - got ?
  43. ProCharger D1X ?
  44. So close yet so far away......
  45. weight and stall speed with turbos
  46. blow by question
  47. Proper oil to run with vehicle
  48. Finally rebuilt!
  49. Lower CR on stock bottom end (LT1)...
  50. How can you tell A/R ratio
  51. Head porting...
  52. Project Front Mount!
  53. UPDATE!! Fuel issue solved....dyno numbers @ 8psi
  54. check this out
  55. New set up, need help
  56. sts it turbo?
  57. what turbos do you turbo guys run?
  58. My Imala did 632.7 rwhp 690.6rwtq :-)
  59. Turbine housing A/R ratio question
  60. Cometic .125 gaskets, 48# injectors enough?
  61. Heads and FI
  62. Strange turbo...will it work well?
  63. Octane boost Good or Bad
  64. Winterizing a supercharged vehicle
  65. Locked up Turbo...
  66. eh question on emissions
  67. false knock???
  68. T-trim versus T-76
  69. Building a 383 need help quick parts are in.
  70. msd boost timing master/need help
  71. any body with a 93 camaro
  72. Front Mounted F2 On The APE Shop Car
  73. need T88 help
  74. How do you afford these mods?
  75. STS Turbo Results - 101 hp gain
  76. Turbos & Surge Valves
  77. Silly Question
  78. bought a T76 but exhaust side looks huge, can someone confirm?
  79. plastic panel in front of radiator and condinser
  80. T76
  81. Selling my Vortech S Trim
  82. Tunning the computer on 95 z28
  83. Turn up the boost???
  84. Couple SC questions
  85. turbo mounting flexibility?
  86. Seriously considering either a supercharger or turbo. Need imput
  87. Need more fuel..read why.What pump do you guys recommend....
  88. Holset turbo question
  89. check out this compressor map and tell me if it'll do
  90. preference?
  91. Where can I buy Supercharger Pulley's?
  92. Where to get belt for blower?
  93. LS1 cam for sale
  94. ATI Procharger 12lb pulley 8rib For Sale..Ebay Link
  95. Are blowers that inefficent?
  96. Vortech T-Trim For Sale/Trade
  97. Powerdyne S/C
  98. cam question
  99. Going to be selling my twin turbo setup, can someone measure under there hood?
  100. Need help with tune....injectors 99% duty Cycle....
  101. Procharger twin intercooler pics
  102. supercharger inlet
  103. blower oil feed line
  104. how much hp with a stock lt1, low compression, forged internals and turbo?
  105. Considering Twin Turbo's
  106. Anyone else carry the ASR relocation kit so I can put my t trim on?
  107. More than 11psi with an S-trim?
  108. Whats the highest boost I can do a 355??
  109. any have extra..
  110. What should I build to put a 15 pd procharger on???
  111. What Cam!
  112. Blown 1996 355 Z for sale.
  113. Dyno results
  114. Are my plugs to cold?
  115. PCM Programing Questions
  116. Realistic expectations and suggestions?
  117. Need help identifying injector rating. Another ? also.
  118. Anyone have bearing # for tensioner pulley on p600b setup?
  119. after blower install car sputters
  120. Relatively stock LT1 w/superchargers.....post dyno #'s
  121. Can I drive the car w/scharger belt off?...ie natural aspiration
  122. ATI procharger p600b FMU for sale...
  123. ok... i have about had enough.. vortech people inside!!
  124. P600b Just got ALOT louder whine?? What gives?
  125. ATI procharger 8rib 12 LB pulley for sale....p600b pulley
  126. LS1 Procharger Dyno Sheets.....I wanna see em
  127. FMU Questions
  128. Holset turbo for my lt1
  129. ATI 4.1" Blower Pulley For Sale
  130. Vortech Oil feed
  131. platinum plugs and procharger
  132. Cam Choice for a Turbo LT1
  133. blower installed need help
  134. A Peak Inside The Engine Of The APE Shop Car
  135. Looking for BIG power from a 396. Here is what I have ... what do I do now?
  136. Modding the fuel rail
  137. feed line bolt in pan has a leak
  138. Is more boost always better??
  139. Will a P600B work with this big stroker I have?
  140. Vortech photos
  141. Stock ATI BPV broke, what are my options for a replacement?
  142. What Timing controler should I use? Help!!!!
  143. dsm bov
  144. those who made your own log style headers
  145. Oil leak at P600b head unit from oil supply?
  146. Injectors and spark plugs question ...
  147. compression with a 383 and P1SC
  148. Anyone here have a lt1 blown or not 396 stroker??
  149. ATI to turbo
  150. Best way to change pulley's
  151. Engine life on 8 lbs of boost.
  152. what is everyone running and for how long
  153. Powerdyne Question
  154. Prices on Procharger Setups???
  155. what size injectors for a S Trim on a stock motor?
  156. Is 10mpg reasonable with D1sc after tune?
  157. Cam for emissions
  158. i keep blowing oil from my breather...
  159. Need 7.0" crank Pulley
  160. Cheapest FI stup?
  161. MSD 6BTM please help ...
  162. Eaton M112 VS Vortech
  163. what type pf plugs for SC?
  164. Paxton's NOVI-2000, good enough for 700rwhp?
  165. Question about 355 procharged??
  166. Paxton supercharger kit on an LT1
  167. ???What would you rate this setup???
  168. Custom Supercharger??
  169. Spring loaded tensioner for ATI TPI-89
  170. Paxton kit on an LT1?
  171. Installed Procharger supercharger belt/pulley squeek...driving me nuts!
  172. Driveability of 383 Blower Motor without a Blower?
  173. To o-ring or not?
  174. cylinder heads
  175. LT1 Turbo Kits?
  176. Proper 8 rib belt for Procharger
  177. oil leak
  178. Blower belt and Smog test?
  179. Ideal budget bottom end.
  180. Need recomendations for Fuel Injection system
  181. 55lb injectors too much for my application?
  182. Banks Twin Turbo Setup NOW for Sale
  183. What IATs are you guys seeing?
  184. Which is the better supercharger: Powerdyne or Vortech with intercooler
  185. 3rd Gen's with Intercoolers
  186. 396 stroker procharged??
  187. Wich one is the better Supercharger: Vortech or Powerdyne?!?!?
  188. Fuel system and boost/methanol questions..
  189. Ready for a blower!
  190. inter cooler for 5-psi vortech
  191. 93z chip tune before start up help help
  192. "Safe" to drive 200MI w/stock injectors & 8#Procharger?
  193. boost question
  194. Feelings on 304 vs. 321 stainless for headers
  195. water pump for the vortech aftercooler ??
  196. Anybody have the MAF after a front-mount?
  197. Stock Engine W/ Turbo
  198. 12second3rdgen
  199. as my Buttom end getting rebuild...i got a few questions
  200. How much do I have to do?
  201. Procharger setup with front mount
  202. procharger belt #
  203. Importance of mandral bending in FI setup?
  204. time to change to a turbo cam... (which one)
  205. the car has finally left the building heh
  206. Dyno'd my vortech yesterday
  207. ati p1sc w/ twin intercooler
  208. blow off valve recirculate or atmos
  209. P600B pulley removal on car?
  210. Intercooler for Powerdyne Supercharger
  211. procharger belt size
  212. who makes a good fuel pressure reg?
  213. Will this change help, hurt, or neither???
  214. What Do I Need To Run 8 Psi?
  215. Oil return, oil level sender hole
  216. Vortech S trim on a stock LT1??
  217. Are the Intercoolers for procharger the same on lt1 and ls1??
  218. Fuel question
  219. Opinion about my headers
  220. Just scored a T-trim aftercooled
  221. JL Turbo
  222. Fuel pump
  223. Lets help me pick a cam!
  224. Homemade Turbos? Possible?
  225. New Blower/N2O times from the Impala
  226. Get away with 38lb injectors on 8# ATI no FMU?
  227. Opinion: ATI Procharger on 96 LT1 with 100k
  228. Question About 04 Cobra With The F1a Procharger
  229. injector help please
  230. Most accurate boost guage...?
  231. ati procharger, 8 #'s good?
  232. Procharger and Vortech's Discharge point the same way?
  233. Procharger H.O. Kit w/ P-1SC
  234. question reguarding vacuum lines on a p600b
  235. ATI twin intercoolers for LS1 fit LT1???
  236. supercharger
  237. Will a f1 procharger fit a lt1 f-body?
  238. Installing p600b need injector/spark plug advice...
  239. 2 bar map sensor -will it work?
  240. What to expect, supercharged 355???
  241. Other questions....(STS related)
  242. Screw Compressors
  243. Junkyard single turbo
  244. Just got a quote for a vortech install...
  245. Potentially stupid supercharger question.
  246. BOV for SC?
  247. amount of psi
  248. looking at compressor maps in lbs per minute
  249. Need help picking a pump for custom ice/water setup ? ??
  250. Help me choose a turbo!!
