View Full Version : Forced Induction
- BLOWN & SPRAYED 383. Need Help!!!
- anyone got any FMIC pics?
- Turbo cam and aftercooler for sale
- New best
- will a new cam push the limits of my stock engine?
- Porting and welding the LT4 intake
- Advise me, Turbo Oil feed line size..
- Blower pistons-which ones?
- turbovette fuel system pics
- Disadvantages of NOT Using Hellfire Rings?
- turbovette update pics 11-9-2005
- Gonna get blown, looking for advice.
- Thinking about going OBX..Couple questions
- supercharged or turbocharged?
- no iat ???
- help with no start Volks Turbo beetle???
- Stock Intake/52mm vs. Ported LT1/monoblade
- LT1 shortblock questions
- New Best w/ STS kit...10's soooo close!
- dyno day results
- CMS Procharged Impala
- Custom YSi LS1 Kit up for sale
- who has 12 rib ATI pulley for sell??
- Supercharger Whine
- Callies Dragonslayer and Piston Q's
- Idle issues with this cam and a blower?
- Vortech tubing
- Need help with Turbo decisions for Forged LS2 Engine
- cone filter size?
- Procharger - venders welcome
- roots and nitrous
- Problems with SRP 31 cc dish 383 pistons?
- Where do I take the pressure reading?
- Priceless Z06 Kill!
- 224/236 blower cam for sale
- Supercharger vs. Turbo?
- Turbo on carbed engine?
- Advantage of Two??
- 383 w/Vortech build?
- O2 sensors locations? Tuning Issues? on Turbo cars...
- Anyone want a 7inch vortech crank pulley?
- spit'nsputterin' popping elbow off throttlebody
- For Sale:Awesome Billet Evolution Motorsports Bypass Valve
- Turbo Kit?
- ant dyno proof a 58mm is worth it?
- All FI people who have gone to the track...
- T74GTS 96 vette build up progress and pics.
- Turbo blankets??
- About to make a turbo motor...
- Anyone need any 42lbs SVO?
- LT1 S-Trim and aftermarket K-member guys inside. Question please..
- Turbo kit designs ... making a custom kit?
- Suggestions regarding turbo sizing......
- Help me out
- procharger manual
- I just bought a procharger and.....
- Twin Turbo
- Sts
- Tuning S/C TPI 3rd Gen
- winter tine with blower?
- Daily Driving w/ STS Turbo
- New motor and new turbo for STS system
- am i where i should be??
- 3rd Annual Forced Induction Meet - Nov 5th (MD/VA Area)
- Procharger guys, come in!
- ALL FI Cars please read
- cogged pulleys with S-trim?
- I fixed my surging problem
- Passed Smog Woo Hoo !
- 471 HP 560 TQ PTK kit at 7.5 psi stock engine
- MAF being coated in oil - what are you guys doing to fix this?
- Custom 321 SS bending
- Does this sound right
- procharger?
- Turbo cam 222/222 versus 226/226 cam (old was 224/236)
- What is the size of the GT67 STS Turbo???
- my t6 pt88 progress picz
- Borg-Warner Spec GM-4 turbo
- brake pressure with blower?
- Got back on the dyno!
- quick question
- How to supercharge my 3rd gen?
- throttle bodies...worth it with boost?
- Looking at a used vortech, how do I tell if it is a T-trim or an S-trim?
- Help tuning 95's PLEASE
- Need Blower Info
- Another fueling post
- S-Trim V1 sound clips?
- afpr needed?
- Thumb's up: Bell Intercoolers
- Nitro Booster
- Suggestions on bottom end rebuild
- If u are running the 224/236 114lsa come on in
- Just something that poped into my head
- GMR SPEED LS1 TURBO Very soon
- gains with 1.6 RR
- New dyno numbers
- Got some numbers from my EPW ported Trick Flow heads
- Methanol questions
- Anyone with a powerdyne on an ls1-
- Ok, anyone have good or bad experience with RKsport headers and FI?
- help planning boosted 355
- F1 install photos request
- Anybody using Fast Engine Management?
- which cam for p1sc supercharger
- 6 rib belt on an 8 or 12 rib ATI pulley??
- custom Intercooler from LS1speed.com ???
- How much rwhp do you guys have? with which super charger? Etc..
- Vortech Aftercooler for sale
- Help!! Turbo size
- fi pistons...
- Failed State Emissions with STS
- Mitsubishi TEO4H Turbo big enough for 6 psi?
- how much boost u seeing with p1sc stage 2
- motor for boost and N2o
- Is 700fwhp w/ this setup/application possible?
- F1r on an LT1
- Does anyone make a procharger crank pulley spacer for ATI damper
- How to get the drive line to live
- Say Goodby
- Boost and engine set up
- Question relating to Versafueler
- ATI Damper with SuperCharger
- Suggest a Keyed Hub
- Custom cam for my car, advice
- does anyone want to get rid of the stock bypass valve, D1SC
- New Z28 Owner - Little Help?
- Opinions on the cam
- putting a walbro 255 in--has a trex inline assistor...
- more cubes better for boost?
- Has anyone isntalled a STS kit on a bone stock LT1?
- Which supercharger to get
- How crappy is the powerdyne blower?
- Who has Accel Gen 7
- Traction Control relocation Kit
- This is making me crazy...help me figure it out
- Procharger pulley sizes?
- STS turbo
- Hmmm... Cutout + Turbo...
- diesel turbo
- ??? Do LT1 and other do to add fuel for FI???
- Where do you have your plugs gapped?
- cam motions recommendation for my car hyd roller
- updated pics of my twinturbo build
- 1st time with blower, have quick question
- Speed Inc. shop car video
- Manual blow-off/bleed valve for S/C's..?(ie boost control)
- How many guys are running Solid Roller 500-800 RWHP Motors
- Race fuel
- 9lbs boost on 15lbs tune questions
- What about this kit.
- Any SC cars running 15+ psi with stock PCM?
- New Weiand Roots blower for LT1??
- Powerdyne 6psi, how much ET drop?
- TT Goes down the Track
- LT1 ATI balancer/dual keyed hub
- Looking for used P1SC kit... Any ideas?
- Diesel website that has cheap exhaust parts?
- ATI or PTK ?
- Piston Question
- 1200hp, stock 6L crank???
- Researching Turbo's
- Between these chargers..
- Which injectors?
- Vortech WHAT!!!
- Another rear mount turbo thread...track times/video inside
- Air-to-Air or Air-to-Water?
- washer fluid?
- Can I Put The Ls1 Ati Procharger Ram Air Box On An 1996 Lt1 Ws6 Ram Air D1sc???????
- What is my car capable of?
- Just bought Supercharged Z28, got some ?
- Tial 38 MM wastegate spring upgrade?
- can i regulate down a fuel injected pump to run a carb
- What a familiar turbo setup this is (pics inside)
- Versa fuler F/S
- 224-336 and larger cams with M6+3.42
- FI guys with daily driver and cam
- Bypass Valve sound
- Dyno Time for 91mm
- Radiator and Cooling
- Question for guys with S-Trims
- Those with Procharger and ATI damper......
- Will a BOV Lower my IAT's at idle?
- spark plugs for s/c motor
- JET tech. superchargers
- Maf Code
- Would a Mufflex intake tube for the D1 fit the P1SC?
- has any1 ever rebuilt a paxton for a tpi?
- stock map sensor/2 bar map?
- conversion
- My blower is for sale
- High RPM breakup
- what oil with boosted s/c 383 lLT1 motor
- Need Brad Brands tube or similar ASAP. Please look....
- Running Lean
- Stock fuel injectors - 95 Z28. How many lbs?
- who is running delteq with there blower?
- 4:10 gears with a turbocharger
- Just dyno tuned the car with new SC
- holeset ht60
- s-trim blower whine?
- My SS is finally finished.
- How much power can the Vortech Aftercooler handle?
- what gear ratio best for turbo application
- for sale: sts turbo kit with FMIC
- never messed with turbos....help me shop
- Can my LT1 hande this?
- How much boost from a P1
- anyone else using this kit?
- Those with ATI Twin High Flow ICs
- Procharged Camaro on Ebay
- boostaholics tt 408 ss camaro videos
- sts guys
- Vortech V2 SQ-Trim?
- Where can I get a tune
- fuel pump...
- forged internals?????????
- FS: Alky injection
- 416 RWHP V6 camaro!!!
- ignition ?
- Can someone explain MAF before or after blower?
- how to change a air/air to air/water
- Are these heads good for sc application?
- Lloyd Elliott heads set up for supercharging
- Can we add a "Boosted List" like LS1Tech.com?
- Supercharger and Turbo Specials!
- boost
- New best
- what size injectors is everyone running?
- Need a good head gasket for 14 lbs
- Need help ASAP - balancer issue with Vortech
- Daydreaming
- Vortech SQ G trim? How much power can this support?
- Which blower for my setup???
- Crankcase ventilation problem need help
- turbo technology kit
- What are the benefits of running the MAF on pressure side?
- TB "Breather Hole"
- 93 - 97 procharger question
- 2 potential Vortech install problems - looking ahead
- carb turbo setup newbie questions
- My new turbo set up...
- tubing size
- Vortech install question - oil pressure unit
- Blow-through MAF problems, need suggestions.
- Need turbo LT1 pics
- anyone ever hear about a rootstype supercharger for lt1
