Car bucking when going from Vac to boost
Old Apr 30, 2008 | 10:23 PM
Blownbird355's Avatar
Car bucks and MAF reads real high and car kinda bucks or stumble, we have ruled out bypass valve by trying another and disabling and blocking bypass with no change.
Old May 1, 2008 | 07:35 AM
Is more info needed?
Old May 1, 2008 | 07:52 AM
1982z28with18s's Avatar
Try a new maf? Maybe a tune issue? Has the car been running fine for awhile before this?
Old May 1, 2008 | 08:06 AM
jsetzer's Avatar
I don't have any experience tuning maf on a boosted car... but generally bucking is lean, our bouncing back and forth while going too lean.
Had a wideband on it while its doing this?
I had a bad plug wire that made the car run like crap when it hit boost, but fine before hand. Not really bucking but it was cutting out.
Old May 1, 2008 | 03:06 PM
Car was down awhile with Pcm issue did not do it before then. Different tune to but stock tune has been tried, Afr pegs rich cause maf gps goes
4xx. 2-3 diff maf have been tried but none new.
Old May 1, 2008 | 03:14 PM
c0rey's Avatar
FYI When my maf wiring went bad and it wasnt reading, mine leaned way out. Just something to ponder.
Old May 1, 2008 | 03:32 PM
Sparkz28ss's Avatar
My guess would be a bad FPR...
Old May 1, 2008 | 06:02 PM
I'd guess it's in the tune then, obviously a stock tune won't work at all.
Go back a few tunes and start from there. I had an instance where I changed only the idle in a tune and it corrupted somehow and when my maf would hit a certain point the car would cut out bad. Went back a tune and uploaded and it was fine.
Old May 2, 2008 | 08:13 AM
When I say stock tune not really stock but stock tables, Also car is fine WOT just under part throttle load. Another question is what kind of power will 48# inj handel in boosted form?
MadMav
Feb 6, 2015 11:02 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
Burn_Out
Aug 18, 2002 08:49 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
