85mm Ls1 Style Maf 5 Wire Calibration Needed
Old Jul 26, 2008 | 12:14 PM
npprej's Avatar
Hi, I am a newbe here and just started tuning on my 94z28
I have the tunercat program, although I have been working
on this car for years I have just acquired it from the original owner. I have installed many mods on this car over
the years for my friend it is at the point where I need tuning work. I have a P1SC dual intercooled system on the
car that I installed several years ago. The long block is stock with 49000 miles. My friend drove the car hard and
so far it has held up. I have reciently gone through the blower system replacing worn parts belt,idler,hoses. One
thing I did was move the MAF near the T/B pressure side
I installed a 85mm MAF with a adapter plug. I need a stock
LS1 calibration to get me started. Can one of you LS1 guys
help me out? This sensor seems more sensitive than the stock one. I used this one it fit my 4'' duct perfect, I have been running in SD mode with ve master and now I am ready to tackle the MAF. Any help would be appreciated this is my first post and have learned a lot from you guys already.
Old Aug 3, 2008 | 10:15 PM
JWS6's Avatar
monodax.com should have plenyt of stock tunes to look at
Old Aug 4, 2008 | 10:57 PM
chads97z's Avatar
here is what i have done when i used a 85mm z06 maf on my 1997 lt4...
i got the stock LS6 Z06 tables and noticed the frequencies sampled at different frequencies (Hz) than the LT1/LT4
using a program called sigmaplot - i combined all the frequencies used from both cars in column A (from lowest to highest)
in column B i put all the known flow rates associated w/ each Hz (basicly the data from the Z06 PCM program)
based off this data, sigma plot was able to calculate the missing values - i used these values and put them in my 97 ECM program and data logged for abt 50 miles
and it seemed to be pretty much dead on as per BLM readings until my engine exceeded 347 gm/sec - then it got weird
now - the bad
the stock MAF can read well over 450 gm/sec
the LS6 can read well over 600 gm/sec
the LT1/LT4 pcm cant read above 11216 hz
the LS6 pcm goes upto about 13000 hz
so the LS6 MAF sensor @ 11216 hz is reporting about 346.28 gm/sec (compared to 471 gm/sec on a LT1/LT4 maf at the same frequency)
so you loose the ability to read any flow rates above this
for this reason - i removed the MAF sensor (its for sale still) and went with a e85 speed density tune and it runs great
i can email you my LT1 file with this data in it
i will try to post it here as well..
Below is the flow rates v frequency for a 2004 LS6 Z06 405hp vette using the frequencies sampled on a LT1/LT4 PCM
software used: sigmaplot and mathcad
"LT1 Edit Dump of Table -- MAF vs Frequency calibration
Filename = d:\Documents and Settings\czg045\Desktop\LS6 MAF Tune 1998.LT1
Frequency (hz) 1488 1616 1744 1872 2000 2128 2256 2384 2512 2640 2768 2896 3024 3152 3280 3408 3536 3664 3792 3920 4048 4176 4304 4432 4560 4688 4816 4944 5072 5200 5328 5456 5584 5712 5840 5968 6096 6224 6352 6480 6608 6736 6864 6992 7120 7248 7376 7504 7632 7760 7888 8016 8144 8272 8400 8528 8656 8784 8912 9040 9168 9296 9424 9552 9680 9808 9936 10064 10192 10320 10448 10576 10704 10832 10960 11088 11216
Flow Gm/sec 1.44 1.77 2.11 2.48 2.89 3.34 3.82 4.38 4.97 5.62 6.32 7.08 7.89 8.75 9.67 10.64 11.68 12.80 14.01 15.33 16.77 18.35 20.05 21.81 23.61 25.48 27.46 29.55 31.73 34.02 36.44 38.99 41.71 44.59 47.63 50.84 54.26 57.72 61.37 65.19 69.19 73.34 77.65 82.11 86.75 91.55 96.53 101.67 107.01 112.53 118.22 124.09 130.15 136.39 142.79 149.31 156.06 163.02 170.17 177.55 185.18 193.14 201.37 209.82 218.60 227.66 237.03 246.67 256.55 266.73 277.19 287.95 299.00 310.36 322.02 333.99 346.28
Old Aug 4, 2008 | 11:02 PM
chads97z's Avatar
monodax has no LT1 edit files - and why does it seem people on this site are against sharing tunes?? i even offered 20Gigs on a ftp server just for people to share em - no one wants to share, but many people request em... weird
Old Aug 5, 2008 | 06:14 AM
cause4panic's Avatar
chad, can sigma plot be used to smooth out 3d graphs such as ve tables? My ve tables are a little choppy in some areas and i think a smoothing software would do wonders for me.
Thank you
trying not to hijack
Old Aug 5, 2008 | 10:11 AM
mdcaprice's Avatar
Some bins can be found here
http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
Jim
Old Aug 5, 2008 | 01:30 PM
chads97z's Avatar
Thank you
ya - can do that - though im not an expert at it yet
Old Aug 13, 2008 | 01:38 AM
npprej's Avatar
Hi,I have been away for a little bit, thanks for all the info!
I have a lot of tuning to do,I am learning that the MAF tables are a large influence on the cars driveability. I need to change my headers first I have hooker sup comp
now. I have LT pacesetter to install no more slip tubes to leak so my BLM'S will be closer together.
I have a AEM Wideband setup has anyone tried to feed the PCM a signal to both banks from the aftermarket WB kits AEM has a narrow band output option in the harness.
Has anyone used the 100mm MAF from Lingfelter?
Thanks for the help!
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
dpw21562
Jan 6, 2015 12:03 PM
Jul 4, 2005 05:00 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
