PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Who is running F1 Prochargers on LT1's ?
  2. Ross Pistons
  3. centrifugal vs. roots
  4. Is it safe to boost...
  5. adventuring in turbos.
  6. What is stock pulley size for P1SC?
  7. Need some thoughts out turbos and piping
  8. intercooler on a 69 camaro?
  9. boost and a 50 shot?
  10. Meth/Water Injection or Intercooler ???
  11. Spark Plug Question
  12. Anyone using LT4 head gaskets?
  13. its official, I'm joining the ranks of the boosted
  14. Mufflex intake pipe and twin highflows
  15. What kind of average milieage are you guys seeing in your FI F-bodies?
  16. How do you tell a T-Trim from and S-Trim?
  17. Vortec issues....solve this mystery!
  18. Stockers to Pusher electric fans
  19. Help me pick a supercharger kit?
  20. do I have a blown head gasket
  21. Another one going turbo
  22. 383 SC issue
  23. Need Belt Size for Vortech
  24. Another Turbo Cam Question.
  25. Anyone interested in an Aftercooled Vortech Kit for LT1s?
  26. Finally
  27. what are you boosted guys running for exhaust?
  28. Whats up with SD-Concepts?
  29. Spark plugs
  30. WB users I have a question
  31. Needed:
  32. Lets Look at BLOWER CAMS Guru's
  33. Supercharger IAC reading?
  34. 383 s/c
  35. 97 Vortech install problem - Please help!
  36. Boost on a stock bottom end with alcohol/water injection worth it?
  37. Neep part number for Powerdyne large idler
  38. What makes COGs UN-Streetable?
  39. Water/Meth Injection Nozzle Placement Question???
  40. Overspinning the blower, how much is too much?
  41. Turbos for LT1
  42. I'm really digging my alkycontrol
  43. Any roots style blowers in the works?
  44. fuel system question for 383/Ai TFS/F1A
  45. BOV Recirculation causing MAF probs
  46. electronic boost controller
  47. ATI Twin Intercooler Setup
  48. Need opinions on fans for 95 formula lt1
  49. Gear choice with turbo?
  50. ATI questions...
  51. boost gauge mech or electric?
  52. boost a pump for a dd?
  53. Another F1-A has arrived
  54. Ported Intake on FI LT1
  55. Msd 6btm
  56. Will my methanol injection clean like seafoam?
  57. F1A In The Mail
  58. how much RWHP to go mid/hi 8s...
  59. Do I Need Cut Outs?
  60. Turbo install *nightmare* PTK / PTS LT1 front mount
  61. It's almost done!
  62. Its running again!
  63. T88 turbo kit
  64. Engine is toast
  65. edelbrock LT1 RPM airgap intake...?
  66. Supercharged LT1 vs APS TT C5
  67. Minimum mods to supercharge???
  68. Turbo oil return lines
  69. turbo pipe fab?
  70. Need to know of some good vendors
  71. Vortech rebuild
  72. My blow through 86 Z28
  73. Big filter guys...quick question
  74. p1sc vs. d1sc, streetability and a/c
  75. 383 short block
  76. FI camshaft
  77. Vortech V1 no boost
  78. More questions regarding Crankcase pressure?
  79. Front mount intercooler with a camaro bumper...
  80. ATI Pulley Size
  81. iroc w/procharger help
  82. AEM injector driver EST Grounded code?
  83. Need help from Machinist on the board for ATI hub
  84. Dual INLINE walbro pumps
  85. need help with single turbo LT1
  86. How well will a fresh LT1 hold boost?
  87. Relocating MAF question(s)
  88. Supercharging a OBD1 Speed Density car...
  89. Anyone tried this???
  90. Finally got my car to the track for the first time with the supercharger and slicks..
  91. Anyone have instructions for ls1 procharger
  92. Setup Dilema...your thoughts???
  93. Need info on the Vortech V1 supercharger
  94. Vortech Head units???
  95. By Baby don't like the heat..
  96. anyone have photos of a procharger installed on just the engine?
  97. Looking for a YSi head unit cheap as possible!
  98. Boost Controller Problem
  99. bypass to blow off valve
  100. Car running HOT with A/C on
  101. Need a good TUNER Recommendation in my area...
  102. New guy, w/pics
  103. BLMs stuck at 128/128 in closed loop, no correction!
  104. ATI Procharger cooling fan??
  105. Method of Pulleying Blower for Boost
  106. Thinking about selling my setup..
  107. Running Rich, MAF, Intake Leak, maybe just burn it!!
  108. Threw a blower belt today, anyone know how install a new one with a SDCE tensioner?
  109. STS turbo kits are they good?
  110. Finally! 1 yr later. She's alive!
  111. Timing, how much is everyone running?
  112. Cam suggestions for maxed out D1SC
  113. Bov Mounting!!!!
  114. Methanol injection users, need your assistance...
  115. Oliver ultralight billet rods?
  116. O2's & Ext Wastegate Placement Where?????
  117. Unable to track down odd noise from SC drive?
  118. Head Studs A Couple ??????????????
  119. Cometic Lt1 Mls Head Gaskets .51 Thick????
  120. Can somebody answer this question about a vortech crank pulley?
  121. Low boost with T-trim, any ideas?
  122. Anyone running ysi on t-trim kit bracketry only...no BB hub?
  123. Cam selection, need help!
  124. What's a BRAND NEW D-1SC head unit worth??
  125. Dyno'd the Z today...
  126. FI O2 sensor failure.
  127. Need some detailed
  128. On a hot day, what temps are you guys seeing?
  129. ATI just spun off my keyed balancer..help!!
  130. When to activate closed loop?
  131. Water/methanol users....
  132. Need 2 Pick A Cam Need Help!!!!!
  133. Vortech owners
  134. Two pistons broke on supercharged '96 SS. Why?
  135. Do it your self Water/Meth. inj. info wanted
  136. Another blower on stock engine thread...
  137. Stock Motor=Worth It?
  138. A couple supercharger questions...
  139. Help me build a boosted 408...
  140. Gates Belt Part number needed for D1
  141. Question: stock vs ported/aftermarket heads
  142. what spark plug for 9psi supercharged LT1?
  143. Ported manifold on ati p600b with 12 psi?
  144. Need help picking a spark plug for my AFR 180 heads...
  145. Which Electronic Boost controler?
  146. Blower Cam selection
  147. air to water or methanol
  148. P600b
  149. My Turbo LT1 Set-up Pics
  150. Supercharger questions
  151. boosted Summit Federal Mogul rebuild kit...
  152. Post your turbo set up
  153. Tell me your thoughts!
  154. Z28 LT1 Turbo set up question
  155. Consensus on MSD 50# injectors??
  156. ls1 turbo kit
  157. Where should I buy my new ATI system from for a 06 Vette?
  158. air to water questions
  159. meth injection
  160. Piston, ring and bearing info please...
  161. Can stock lifters handle boost and higher spring rates?
  162. Increase 1LB of Boost = ?RWHP
  163. quick ?
  164. will 1/4 mile times drop a lot with boost?
  165. T5?
  166. 87 octane in a blower car??
  167. FMIC or stay w/ Aftercooler
  168. difference between Vortech's YSi-trim (V7 vs V24)
  169. where can i get a t-trim rebuilt or find a reasonable t or ysi for sale?
  170. when should you o-ring your block
  171. What kind of numbers?? Maxing out stock injectors using FMU
  172. Max HP on optispark (OEM, MSD or other)
  173. Free Shipping On Precision Turbos...
  174. "beginning to consider" questions
  175. I Just Finished On the Dyno, Need Help!!
  176. front mounted turbo/supercharger
  177. STS turbo
  178. Track Boosting Problems
  179. Cutting the honeycomb for an intercooler...
  180. Dynamic Compression Ratio for Boost
  181. How important is DCR
  182. roller rockers???
  183. Post your front mount pics, WITH BUMPER INSTALLED
  184. Vortech Guys needs some help
  185. What fuel pressure regulator are you using?
  186. Well, my Z will soon be back out, and re-tuned on the dyno...
  187. procharger intake
  188. intake tube vortech
  189. Where to go for forged bottom end?
  190. Bang for buck with boost?
  191. 10.8:1 CR + s-trim maxed out
  192. Guestimates on Power
  193. Qtp 3" Elec Cut-out & Tube W/switch!!!!
  194. My Powerdyne with 1LE sway bar?!?!?!
  195. Just got on the dyno with my boosted 355
  196. eboost users step inside.
  197. procharger pullies
  198. Procharger crank spacer
  199. motor break in...
  200. What A/F Ratio should i tune the car for ON methanol.
  201. DIY Turbo Kit Finished *PICS*
  202. F-Body turbo kit for sale
  203. Pistons for boost, JE vs SRP
  204. Couple ?'s regarding vacuum lines & S-trim after AIR removal
  205. Twin Turbo Selection, Please Help!!!!
  206. D1SC on 383LT1
  207. tensioner pulley size needed for powerdyne
  208. Oil leak/AFR Heads and LT4 Valve covers
  209. Running Rich & Crappy
  210. Ati procharger should i retain egr and emissions
  211. Paging Roadie or 97WS6Pilot
  212. Putting my car on the Dyno this weekend...what will it make?
  213. lt1 tuning
  214. S-trim T-trim Noise
  215. Vortech V-1 S trim vs ProCharger P1SC
  216. SDCE questions
  217. Where to get P1SC pulleys?
  218. basic FI questions
  219. turbo vs. supercharger(LT1)
  220. procharger systems(LT1)
  221. what to expect RWHP??
  222. forecedinductions.com wtf???
  223. Upgrading Ati by pass valve?
  224. Max Power w/ Stock Unported Heads?
  225. need fast help crank snout
  226. Whistling after Motor/pulley swap.
  227. D1SC with stock bottom end.
  228. LT1 castings.
  229. What stock heads for blown 383 project?!
  230. Timing at wot..table is set at 20...datamaster shows 24...
  231. Anybody use a Trickflow Elbow?
  232. need help with blow by issues..383 BAND AIDS?
  233. powerdyne supercharger pulley needed
  234. Win some cash!
  235. Turbo cam
  236. Hub centric spacer needed?
  237. Heads, Pulley, Aftercooler, Head Unit?? Which option?
  238. Looking down the road
  239. How much u willing to pay for 1200hp turbo kit? Maybe for sale
  240. Need measurements from 95 crank hub to machine ATI damper
  241. Do I want SP or should I keep the MAF?
  242. quiet bov or bypass valves
  243. Pro Charger P-1SC or D1 for my application ??
  244. Fel-Pro 1074's good enough for my application?
  245. Third gen procharger fuel help
  246. Sound clips of Vortech race bypass valve??
  247. Is this a good deal for a YS trim Vortech?
  248. Have le1 heads + cam, want 450 rwhp
  249. How is this cam
  250. Boost w/ cam... Q
