PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. EGT Meter Vs Pyrometer
  2. Vortech owners, quick smog pump relocate ?
  3. Worth running low Z injectors?
  4. What Size Intercooler to use for a Front Mount?
  5. Block fill, leave main caps on?
  6. Where to buy parts???
  7. Traction Concerns w/Future Setup
  8. STS turbos and ATI superchargers - we can help with both!
  9. Turbo Exhaust Gas Temperature
  10. Project Turb Hoe
  11. What brand forged piston/ring for 12psi, compression?
  12. How much power can a stock engine take?
  13. Given my MOds will my car handle a SC
  14. Making LT1 ECM "see" boost
  15. Vortech owners, whats the best method
  16. Fuel pump
  17. 1st Supercharger Install
  18. Whats the loudest supercharger they make?
  19. Paging Jose from Forced Inductions
  20. Stock fuel pump flow #'s
  21. Stock Headgaskets with 6#'s of boost???
  22. LT1 Paxton questions?????
  23. My car is GONE.............
  24. Wastegate DUnp Question
  25. new Vortech on a 350 TPI
  26. Can someone explain water/methanol injection?
  27. Is there a blower cam out there thats??
  28. need some pro apinons
  29. would a t76 work with a T.technology single LT1 kit
  30. Can I run two 6rib belts on 12 rib setup. Belts driving me crazy again.
  31. T76 or T88 New set up please advise
  32. can u do u both???
  33. sts turbo on a stock engine how long will - --
  34. Heads questions for the pro's
  35. Maxing out MAF sensor
  36. DIY Rear Mount Turbo - Need some input
  37. Chain drive for vortechs?
  38. a few questions
  39. vortech v-trim ??
  40. Got 6" rods in my car.. Should I have gone 5.7"?
  41. STS Turbo Questions/Problems
  42. Pro Series fuel pump
  43. Keep my hotcam or buy a blower cam????
  44. FMU or Upgrade injectors????
  45. Is a BOV open during cruising?
  46. Is a 48mm tb hurting me?
  47. HOW to INCREASE bOoSt
  48. Motor destroyed...
  49. Can you use a wastegate as a BOV???
  50. considering selling my old eaton stuff
  51. Gauging interest Got some big injectors
  52. whats the max timing i wanna have?
  53. newb to superchargers
  54. How much boost on a stock motor????
  55. 12 rib better than 8
  56. Got a question about which cam to use
  57. Aftercooler replacement water pump?
  58. driver not builder, needs thoughts/answers to ??'s
  59. Supercharger or Turbo?
  60. Blow off valve on supercharger?
  61. People with ATI big block hub in here.........
  62. Can a stock short block take 500hp???
  63. Also in Parts For Sale....Procharger FMU ebay link...
  64. Race Gate Springs
  65. Should I sell my LT4 heads for TrickFlows
  66. several questions
  67. Stumped on Paxton disassembly
  68. Compression/Boost limits on high octane?
  69. racetronix fuel system question
  70. Siemens Deka Injector size?
  71. Why are some supercharged cars so slow?
  72. Power predictions
  73. How wide is a 12 rib setup?
  74. Need help identifing a turbo.
  75. How do you take blower pulley bolt off?
  76. best sounding blow off valve
  77. STS Kit do you need a intercooler?
  78. Turbocharger?? Need Help I'm lost
  79. go with cometic or felpro 1074
  80. Is a supercharger worth it w/my current mods??
  81. Cant seem to find this belt.. 392K8. Where can I get one?
  82. A supercharged 350 or a naturally aspirated 415?
  83. Supercharged LT1's with a higher stall..question inside...
  84. Need Blower cam for 800 RWHP Combination
  85. More power TURBO OR SUPERCHARGER???
  86. 615 rwhp dyno vid
  87. Need Help Asap!!!!!!!
  88. having a hard time deciding which blower cam
  89. Does anyone have a 12# 8 rib Ati p600b pulley laying around?
  90. My fuel system
  91. Head gaskets
  92. Whats the smallest 8 rib blower pulley you guys have used with no slip?
  93. Do I need a new tune after I drop a supercharger on?
  94. Turbo charger with hot cam
  95. Took a ride in an STS car
  96. tining issues blower vs turbo
  97. Which size turbo? Chevy Colorado I5
  98. WTB parts
  99. Twin high flow intercooler worth the upgrade?
  100. ATI Blower Pulleys
  101. Air fuel for boost and methanol?
  102. Total TT setup
  103. intercooler inlet/outlet
  104. Do I need better valvesprings?
  105. Daily Driver: Heads/Cam or STS Turbo ???
  106. Crazy idea, inter/after cooler?
  107. What name brand injectors are better for FI?
  108. What mufflers you running and does your car pop on decel
  109. PTK Gen 2 Kit
  110. What kind of numbers can a blown stock bottom end LT1 put down?
  111. Post pics of blow off valves..
  112. What is a 76mm Turbo head unit worth barly used
  113. A few questions about pullies and balancers.
  114. Video of me hazing the tires at highway speed
  115. what size injectors
  116. Turbochargers and heads
  117. Got boost? Video clip of the 'Bird.
  118. 9.6 video
  119. ATI new 8 rib setup Final results
  120. how much power can be made with stock heads
  121. Downpipe Size and Max HP
  122. Anyone need a small turbo??
  123. powerdyne thoughts
  124. 396 stroker or 355 procharged??
  125. pb600 vs s-trim
  126. D1sc or F1 ?
  127. LS1 + YSi + Strut Bar Brace
  128. Pushing the limits, need advice.
  129. Double Roller timing chain and ati superdamper
  130. SC tune?
  131. Gauges with one ????
  132. Stone Mountain Racing Wastegates?
  133. Can you safely run an STS kit on a stock low miles LT1?
  134. Is this the fastest Lt1?
  135. Please post pics of your fuel line routing
  136. How do you drive?
  137. 1/2" head stud conversion?
  138. turbo vs Supercharger in a 355LT1
  139. Help with some boost issues.. Pullied for 14 only seeing 10..
  140. Intercooler Thought
  141. help with guestimate.
  142. Stock shortblock with P1Sc how much can it take
  143. what would everybody recomend?
  144. What kind of combo / horspower can I get with 7k budget??
  145. What to do?
  146. Re-Building LT1 7K Sound About Right?
  147. Opinions on these pistons/rods for turbo
  148. powerdyne 6#
  149. 9.7 @149 6-speed LT1 video
  150. fuel help
  151. stock oil pan
  152. Where to get Mandrel Bends??
  153. Lowering the CR
  154. Supercharger?
  155. Tensioner problems with vortech V2
  156. Is it possible to get over 600 rwhp on stock bottom end with this set-up??
  157. What should I run in 1/4 with this set-up Predications anybody
  158. what kind of 1\4 # for vortec
  159. Price of 355 LT1 = price of 348 LS1... switch platforms at rebuild time?
  160. We're now carrying STS Turbos!
  161. For Sale Vortech YSI supercharger for LT1
  162. would this fit?
  163. Turbo LS1 Dyno Results
  164. bolts on the crank pulley keep coming loose
  165. Where to buy missing parts
  166. 3'gen 3-core IC dimensions?
  167. 5 lbs of boost with 10.8 to 1 compression?
  168. PTK 76GTS track results
  169. 54cc heads with a blower?
  170. How fast with the T56
  171. Blown Seal?
  172. source for single turbo headers?
  173. Wtb Blower
  174. Intercooler on a Trans Am?
  175. Vortech S-Trim, Methanol Injection
  176. ATI new 8 rib setup results
  177. Boost????
  178. Will this set-up handle 12 pounds of boost yes or no???
  179. ASP pulley
  180. Looking for partner in US
  181. Vacume line blew off the bypass valve.. bad?
  182. Cogged Vortech Guys, What Size Pulleys?
  183. S-trim and p600b ?
  184. Procharger - just change the pistons??
  185. Blown 93 Camaro FS......
  186. ITS GT80R turbo for sale
  187. Some updated pics
  188. Please Help. Advice on this set-up 355
  189. Advice on a cheap budget 355 induction set-up
  190. new to fored induction
  191. new to turbos
  192. Best charger for my high mile stock LT1
  193. New to Forced Induction
  194. Hard Intakes Vortech
  195. 355 LT1, should I get the P1SC or D1SC
  196. Timing
  197. Sts dyno numbers
  198. What do I need done to handle 15 pounds of boost??
  199. Finished blower install, ran good till tranny let go
  200. Please help me need advice on next summers build up budget
  201. Fuel injectors and stock pcm
  202. PTK Turbo
  203. running supercharger oil line?
  204. Compression ?
  205. 2.055/1.625 valves in LT1 heads
  206. Will this digital wideband work with our FI cars...
  207. Knowledgable blower Guys
  208. What are some of your mistakes
  209. Question about Turbo Debate I had
  210. New Times for STS equipt Z71
  211. What motor for a Vortec SC?
  212. How fast is you FI 355
  213. p600b orange inlet tube
  214. Maf on Pressure side of Twin High Flow???
  215. Custom turbo headers
  216. Those with sheetmetal valvecovers and/or breather tanks, need pics of your PCV system
  217. Jet Stream™ Electric Supercharger
  218. Turbo photos
  219. Need Vortech belt size please...
  220. is this to big for my motor setup?
  221. How much to rebuild a turbo???
  222. LT1 Blower Chambers
  223. Where to look for a good supercharger
  224. Front mounted intercooler
  225. How much boost can a deltagate actually control?
  226. Powerdyne BD550 Head Unit
  227. ATI superdamper big block hub vs regular
  228. Do you need to zero deck the block
  229. stock bottom end? bad idea?
  230. What will stock fuel lines/rails support
  231. ordered a supercharger
  232. Help with intake ducting ideas...
  233. Who is upgradeing
  234. stock bottom end, but hogged out heads?
  235. turbo fitment
  236. Little off topic but..
  237. What did a 383 cost U guys$$$$$
  238. Anyone thinking of making ?
  239. hotcam and turbo?
  240. Heads for LT1
  241. What Blower for forged 383?
  242. Final touches, almost DONE!
  243. would 150 shot be enough?
  244. Spark plug question
  245. Turbo LT1
  246. Experiment results with modified inlet pipe
  247. 9.8 @ 149
  248. Went to Dyno today, # seem high for stock heads and cam
  249. Overlap? Search didnt help...
  250. PTK LT1 results for those that were interested
