D1SC pulley for max boost without overspin.
Old Apr 21, 2008 | 10:10 PM
Randy Molkentine's Avatar
I am about to get a race gas tune on my LT1 with a D1SC. I currently am making about 11psi 627rwhp on a dynojet. I am just trying to figure out which pulleys to max out the blower around 6500rpm.
Thanks,
Randy
Old Apr 22, 2008 | 05:54 AM
rskrause's Avatar
Moderator
D1SC: 4.1 step up and 62,000 max impeller rpm.
(crank pulley diameter/blower pulley diameter)*4.1*engine rpm = impeller rpm
(CP/BP)*4.1*6,500=62,000
CP/BP=62,000/4.1*6.500
CP/BP=62,000/26,650
CP/BP=2.32
Any available combination of pulleys in a ~2.3:1 ratio will work. Were you feeling too lazy to figure this out???
Rich
Old Apr 22, 2008 | 06:43 AM
CP/BP=62,000/26,650
CP/BP=2.32
Rich
Well I know there are only certain pulley combos available and being such a common blower I am sure someone already has. Just figured it would be easier to ask then do the math and then divide different available pulleys.
Old Apr 22, 2008 | 07:01 AM
rskrause's Avatar
Moderator
Pulleys are expensive. Just start with the crank pulley you have and divide the diameter by 2.3 - voila! That is the new size blower pulley you need. Pick the closest, doesn't have to be exact as I am sure you know. A couple thousand impeller rpm north or south will not be an issue.
Rich
Old Apr 22, 2008 | 07:03 AM
Thanks. It looks like the 3.4 is available and will be pretty close to maxing it.
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
