Turbo Long Block is ready at last
Old May 3, 2008 | 10:56 PM
DirtyDaveW's Avatar
Well, at long last, the long block is ready. My Turbo engine builder, Mr. Jim Pitcher of Chatham, New York emailed me last night (5/2/2008) to let me know, the Beast is done! Jim is locally renowned for his engine work on shorttrack racers and came highly recommended. Jim is very meticulous and spared no effort on getting everything just right. The file-to-fit rings have the correct end gaps for this turbo application, the former two bolt main has been converted to a splayed four bolt main using ARP studs/bolts. He pressure tested the water jackets after the four bolt conversion to make sure we don't have any unexpected hydration problems after she's fired up. He balanced the entire rotating assembly. He degreed in the custom Bret Bauer Cam, got the valve springs height uniform and set to Brets specs, measured and ordered custom hardened pushrods, bead blasted the heads and intake and clear coated the intake. He also welded a -10 bulkhead fitting onto my Canton Oil Pan for my T76 Turbo's oil return line.
Specifications:
Size: 355 cubic Inch
Block: 2 bolt converted to splayed 4 bolt. ARP Main Studs/Bolts. 4.030 bore.
Crankshaft: Balanced Forged SCAT. 3.45" stroke
Rods: Forged 5.7" H-Beam, ARP rod bolts
Pistons: Custom Forged Diamond
Calculated Compression Ratio: 8.8:1
Heads: Ported Stock LT1 flowing 275/195 at .600" lift thru 2.00/1.55 Stainless valves
Cam: Hyd Roller, Custom Bret Bauer Turbo Spec
Rings: File to fit Total Seal AP series
Timing set: Comp Cams 9-3145 true roller
Fuel Injectors: 60# MotoTrons
Throttle Body: Stock 48mm
Head Gasket: Tried and true FelPro 1074
Oil Pan: Canton Road Race fitted with -10 Bulkhead for Turbo oil drain
Old May 3, 2008 | 11:20 PM
93v8clone's Avatar
looks good
Old May 4, 2008 | 10:52 AM
IROCThisZ28ForLife's Avatar
hey can you send me his contact info, im looking for a builder in ny and about how much it ran you...
Old May 4, 2008 | 12:15 PM
DirtyDaveW's Avatar
Jim Pitcher is his name. His email address is:
jpitcher@taconic.net
His phone number is: 518-275-5944
Zip code is : 12037
Old May 4, 2008 | 04:37 PM
crazycat's Avatar
My engine builder will have mine done in a few weeks. I have a set up that is close to yours. How much h.p are you shooting for ? what part of n,y are you located ? Iam @ Lake George n,y. Who is doing your tuning for you ?
Old May 4, 2008 | 06:42 PM
DirtyDaveW's Avatar
Zip code 12037. Fairly close to Albany(about 30 minutes south of there). I told Jose at ForcedInductions.com and Bret Bauer(the guy that designed the cam profile) that, with all I have done, I wanted (at least) 600rwhp. Running 12-14psi, this setup should net that. On the tuning, I contacted Bryan Herter of PCM4Less with my whole setup. He sent an LT1 edit file to me that has everything I need, at least as a baseline, while keeping the MAF and stock MAP. I brought it up in my LT1 editor and it's got a lot of changes so I'm sure It will be close. Bryans done a lot of turbo LT1 tunes.
Old May 4, 2008 | 06:44 PM
DirtyDaveW's Avatar
What about you? What turbo? Single? Twins? Ball Bearing or no? What is your hotside? Logs or tubular? What are your HP goals?
Old May 4, 2008 | 08:37 PM
4SFEDZ's Avatar
keep us updated!
Old May 4, 2008 | 10:13 PM
DirtyDaveW's Avatar
I sure will!
On order right now...
LTCC... shipping 5/8/2008
http://www.bailey-eng.com/LTCC.html
PLX wide band, controller, gauge... shipping 5/8/2008
http://plxdevices.com/products/dm100/smafrcombo/
Old May 4, 2008 | 11:38 PM
crazycat's Avatar
Iam using a gt 4594 76mm, t6 1.19 housing turbo,( Iam hoping this thing will spool. my hot side is tubular. engine build is a 383 all forged, splayed 4 bolt,ported trick flows, cam is the new xfi 280, Iam hoping its not to big, my builder thinks it will be fine. My goal is 700 rwhp. I am doing every thing my self so the builds not going real fast.
Old May 5, 2008 | 08:44 AM
cause4panic's Avatar
Might want to get rid of that fram oil filter.
For all the nyc people looking for a good machine shop, might i suggest.
sk speed
merkel racing engines
Old May 5, 2008 | 09:18 AM
DirtyDaveW's Avatar
Lol, yeah. He just put one on there to cover it up I guess. I'm a fan of Wix 51060's, not Fram.
Old May 5, 2008 | 06:33 PM
boosted-lt1's Avatar
Beautiful engine!
Reminds me of mine, way back when, although your's is built much better.
What do you plan to do for tuning?
-Scott.
Old May 5, 2008 | 10:41 PM
DirtyDaveW's Avatar
Thanks! Bryan Herter from PCM4Less provided the base Turbo Tune. I have LT1 Edit and will dial in any refinements after that. I am ordering a PLX wideband kit on Thursday to help me get the fueling just right.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MBonZ28
Jul 30, 2002 11:42 AM
