which oil scavange pump are you guys using
I've come to realize that there is not enough difference in height of my turbo drain and oil pan. The car starts out fine no smoke, then after a few minutes it begins smoking badly. My guess is that the oil is not draining fast enough. I was going to put a restrictor in the feed line, but wouldnt it be safer for the turbo to put a pump on instead to get it to drain fast enough?
