Which H20 pump, CSR or Meziere?
Which pump do you prefer for higher HP boosted applications? I read somewhere that the Meziere flows a little more than the CSR, but the CSR is less expensive. Thanks!
Not boosted right now but I have an old CSI(CSR) on its 6-7th year.
I can pull the trigger out of the hole and make a full pass. By the time I get back to the pits she is at 180*.
On the street it never gets over 180* even in hot weather.
Here are a few things to consider with this info.
Block is rocked to the plugs
BeCool Radiator
250RWhp shot out of the hole...yes all at once.
180* by the time I get to the pits
BeCool Radiator
I went through 2 stock pumps in five years when I first bought my car in 96. I've had the current Meziere HD Pump in since 2002 with no problems. I put alot of miles on my car since it is a daily driver. My supercharged car gets hot when it is over 90 degrees outside and I idle for longer than 10 minutes with the AC on. If I turn the AC off it will go back to normal temperatures. Never tried the CSI but any electric is a big improvement over the stock pump.
I have not had to replace the Meziere yet but it will be a breeze to replace if it ever goes bad. It just pulls right out of the front of the waterpump housing.
When you install the Meziere make sure you buy a painless wiring harness and solder and shrink wrap all the wires to protect them from the weather.
So is the Meziere HD the better choice over the standard Meziere. I am looking to make 600+/- RWHP and keep the car on the street more than the track. So cooling is a must. Which is the better choice for mostly street use?
