Root cause of throwing belts?
Old Mar 26, 2008 | 04:25 AM
The SRZ's Avatar
Exclamation Root cause of throwing belts?
I've searched on here but there seems to be conflicting stories as to why.
Procharger of course. Belt has been fine since installed and idling for the last yr or so. Finally get it on the road for some testing and never exceed 2500rpm's. Never see boost either. Then all of a sudden parked in the garage I blip the throttle for a friend and the next thing I know--I lost 1 rib on the 12 rib belt and the belt has walked over the front part of the crank and blower pulley.
I recheck everything (don't have an alignment tool--I know) after pulling the belt off. Clean the belt up and take the rest of the rib off. Install, double check to double check, fire car, idles perfect belt appears to be fine and blip the throttle...nothing. AS SOON as I turn the key off SNAP! Another rib! WTF? Now remember this thing has been on the car for the last yr w/ no road time and just idling etc w/ out a single hiccup...even after I had a custom pulley spacer machined as I screwed up the stock piece.
I check everything over again and this time pull on the belt to watch what the tensioner is doing and it appears it's going up and down based on my pulling but there also seems to be east west motion to the tension arm/pulley every so slightly. Why a would a perfectly brand new F1 S/C do this? How in gods name do you fix it? I've tightened the belt, adjuster bolt, locator nut & mounting bolt especially the mounting bolt tight as all get out as this is what appears to keep the arm from doing the east west motion.
Really need some input. It gets tuned today in a few hrs and if the belt snaps again I'm going NA until I get this SOMBEYOTCH figured out. Thanks guys.
Silas,
Old Mar 26, 2008 | 11:44 AM
The SRZ's Avatar
Thumbs up
Fixed.
Had to put a spacer on the idler pulley. Don't know exactly why it shifted but it did. All is good for now at least and I got some street tuning done. Saw 3psi and that was it. LOL That 3 felt good though. Sat it'll be on the dyno for 3-4 hrs getting it worked out. Here's shooting for a conservative 650-700rwhp.
Old Mar 26, 2008 | 01:11 PM
blown383's Avatar
Gald you figured it out. Usually when belts are thrown its because of misaligned pulleys...or Procharger's crappy design. I was going to suggest getting the SCDE tensioner. Good luck on the dyno!
-B
P.S. Are you keeping the blower? I thought you wanted to go turbo?
Old Mar 27, 2008 | 12:24 AM
The SRZ's Avatar
-B
-B,
It was definitely the idler pulley. I'm getting ready to add another spacer tonight after work to center the belt on the pulley. Crank and blower pulley is perfect but I'll be back stateside for a week and pick up an angle reader just to be sure. I called SDCE about their product and downtime and they said it'll be longer than a week because the season is picking up again. I remember Ben waiting over a month for his. I asked how much for a new bracket and tension and they quoted me 835.00. That's a lot of coin for it but I may just pony up if mine doesn't hold up well.
Yes I do want to go TT but I'll keep this for now and see how it does. I was frustrated for so long and to see progress--I just want to enjoy the end product...so the S/C stays. It felt good to be in the seat again.
When are you going to be done w/ yours?
Silas,
Old Mar 27, 2008 | 01:22 AM
blown383's Avatar
Originally Posted by The SRZ
-B,
Silas,
I guess if you buy a whole new bracket from them along with the tensioner...its gonna run you $800.00. I remember my tensionser cost $400 but I sent them my bracket.
As for my car....well my daily driver died on me last week and I got pissed so I ended up buying a new car! LOL!
I'm going to try to at least get my motor into the car before the end of summer. Maybe if Im lucky the car will be running come Christmas time.
-B
Old Mar 27, 2008 | 08:15 AM
mzgp5x's Avatar
My experience... I had problem with belt alignment walking. Pulley drive was aligned within 1/32". So, I noticed that when the drive load went to unload (engine rpm deceleration), the tensioner would deflect alot allowing the belt top side to come loose.
Thus, the cause of belt misalignment and walking off the pulley. The ATI tensioner system does not have a fixed stop. So, I made a simple one from delrin. Located on the belt top side/ tensioner arm, and, mounted to the WP mount bolt/ fastener.
Now the idler belt tension device can only unload about 0.060" from the tight side. It worked. Also, it allowed me to dial less idler tension load on the belt which results in less cantilevered load on the engine crank-shaft. Less reversed bending and reduced fatigue failure potential. An Engineer's solution.
The ATI tensioner has it's flaws, but an $800 dollar solution is to high a cost. Hope this helps. B. (97ss - 383 - D1)
Old Mar 27, 2008 | 11:54 AM
CALL911's Avatar
Silas, glad you got it figured out! I'm not a big fan of SDCE's pricing or customer service, but their tensioner setup is a good one.
Just remember that going boosted (this includes the Turbo guys as well) theres always going to be bugs to work out once you start. Just be persistant and patient, and keep at it, and you'll get it dialed in soon enough.
Best of luck to you this weekend on the dyno. Be sure to take video of it and post it up as soon as you get back as we are all anxious to see how it does!
Old Mar 27, 2008 | 12:18 PM
The SRZ's Avatar
Now you know you gotta post pics after that suggestion. I'm a picture kinda guys.
Yeah Ben you are right about patience. Try 3 yrs. It's all good. I've got the camera ready so I'll have something. I really don't expect high numbers just a good conservative tune. Once I throw the meth on in the states then I'll go for the gusto. Hell just driving it now is more than a thrill for me...I can't imagine what the boost will be like.
Oh and 96 injectors are some drinking ****'s. Just at idle I ate up 5 gallons in 30 mins or so it seemed. It's running much better now and my so called tune was WAY off. LOL
Old Mar 27, 2008 | 04:01 PM
CALL911's Avatar
5 gallons from a 30 minute idle! Yeah, your car needs tuned something fierce! I know guys with 1000 RWHP, and they are not NEARLY that bad on fuel.
I'm with you though on the tune. Just tune it till' it's dialed in, and "it makes what it makes". I never was one for eeking every last pony out at safety's expense.
Old Mar 28, 2008 | 12:32 AM
The SRZ's Avatar
Ed from HpFactory is here from Va Beach, he got them dialed in but it's still rich at idle but not 10.4 rich more like 13.5 rich. LOL. I'm idling right around 850 rpm's and could go lower but my vac is horrible. 6-8" inches of vac. I remember w/ my tune I'd initially when I 1st started the car over a yr ago I was seeing 10-13". The engine was broke in prior to shipping but I hope I didn't kill those rings--that would suck the big one. The car pulls good and the brakes appear to be fine. My just have to find room for a vac canister...where I have no clue...well yes I do. Requires relocating the factory PCM and ditching the the bulky piece of what's left of the AC. May be a winter project since I'll be in sunny Fl.
Got that other spacer on last night too so the rib is centered on the idler pulley now. I'm getting faster and faster working on that thing. Had the belt off in under 10 mins...before it was a pain and took me an hr. LOL
Old Mar 28, 2008 | 08:37 AM
CALL911's Avatar
Your rings should be fine. I was running around with my AFR on my wideband reading 9.5-10 at WOT for a while until I got it tuned, and you know how it turned out then I would worry about running that lean though (13.5). Not bad for cruising around or at idle, but if that is your AFR while your in the boost, then you are well into the danger zone. I would be worried with anything leaner than 12.0 personally.
Old Mar 28, 2008 | 03:11 PM
The SRZ's Avatar
Well after not driving the car for the last 2 days...I got to start it up and she didn't want to fire. I got it to run but it didn't like no cold start up. Wouldn't move under it's own power until she was warmed up AND under any load my AFR's were reading 9.5-10. She needs a lot more work. She ran like crap and doesn't like any throttle and the minute I let off the gas she reads instant 13.5.
I have to drive 2 hrs to the dyno and I'm not sure I want to risk it. Just my luck and I fly out Sunday to Panama City for a week.
I think I'm just gonna ship it INOP and be done w/ it and have it tuned at Hartline Performance as I have been in touch w/ Cal for the last 2 mos.
Old Mar 28, 2008 | 03:57 PM
CALL911's Avatar
With as big of a change as you have done to it, un-tuned it sounds like it is running like it should be for its condition. Only 2 hours on 9.5-10 AFR will be okay. I drove mine 13 hours and over 700 miles just in the trip I took from Indiana to New Jersey last spring with mine that rich. Not to mention I drove it a bit in Indiana prior to that trip, and then some more in New Jersey before I finally drove it back into PA to get it tuned. 13.5-14.5 is where your AFR should be at when your out of the throttle or just cruising down the highway. If you are reading past 13.0 when you are in the throttle, thats when I would get worried.
I honestly think you'll be okay to drive it to the tuners Silas. It needs a tune something fierce. I know it is running like crap now and you are overly worried, but if I can drive mine as rich as I did for as long as I did and was okay, you can surely drive yours that fat for the small 2 hours.
One more thing you might want to check is that everything is sealed up properly between the blower and the throttle body. It almost sound like you might have some kind of vacuum leak, and you have to stay in the throttle to keep it running. Just make sure all the hoses and lines are clamped up properly. You probably just need a tune.
Old Mar 28, 2008 | 04:46 PM
The SRZ's Avatar
You must've ate up A LOT of gas if you ran it like that. I ate up 5 gallons I'm sure of it traveling less than 30 miles. As far as leaks it's sealed up tighter than a drum. All I did was add a spacer to the idler pulley and that's it.
My cruising AFR's are 9.5-10 and if you did that for 13 hrs then surely I can do a lously 2...I just hate cutting it so close when I have a flight and my wife is terrible w/ directions (no GPS...haven't gotten around to buying one) so I'm gonna have to sleep on this one and see how I feel in the morning. Thanks for the confidence though.
Old Mar 28, 2008 | 07:23 PM
CALL911's Avatar
Good luck dude. Let me know how things turn out.
