PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35
  1. Emissions Legal Turbo Manifolds
  2. superchargers
  3. Stock MAF or MAF ends?
  4. suggestions, crank pulley bolt loosening:LS1 D1sc
  5. Need help with Accel Injectors
  6. Oil Out Of Dipstick ?????
  7. Vortech oil line restrictor
  8. supercharging a v6
  9. odd sound
  10. vortech 6 pound reliability question need help quick
  11. LS1 SUPERCHARGED leakin oil from unknown spot PLEASE HELP
  12. How much power should i expect from a supercharger?
  13. what fuel injector size should i use?
  14. need help..
  15. Supercharged 3.4?????
  16. Bottom end questions .
  17. Looking for Advice on Intercooler - Buy Vortech or Custom?
  18. Mechanical problem preventing my car from making boost...
  19. is this turbo too small
  20. supercharger???
  21. procharger 8# on stock engine
  22. Air Intake Question?
  23. More airflow or just a thought...
  24. Turbos not draining fast enough?
  25. Hotcam/Supercharger?
  26. is this fpr good for forced induction?
  27. Serious buyer looking for good used S-Trim
  28. guys w/a4 and supercharged inside please
  29. LT1 turbo cam choice
  30. stock lt1 shortblock and strim 6psi dyno within
  31. garret twin turbos. question
  32. Anyone need a check valve
  33. Need new motor Please Help!!
  34. what SC kit has these install symptoms
  35. Where is this oil leak!!!!
  36. dosent anyone run this pully combo
  37. Can anyone help with what I think is a fuel problem??
  38. 12:1 compression to much for a 12psi procharger?
  39. any pics of Vortech Mondo valve installed ?
  40. Oil return hose help
  41. Whats a good turbocharged engine Combo?
  42. No boost after intercooler install...
  43. PTK has released some pricing and info on the LS1 F-body kit..
  44. belt size vortech 3.125
  45. Turbo Technologies Kit
  46. pcv again
  47. Where can you buy procharger pulleys?
  48. Pictures of a supercharger motor build up
  49. Piston Tech
  50. New Boost Gauge = Fuel Efficiency
  51. Dissappointing results.
  52. engine rebuilt for boost
  53. any trouble shooting pros need help
  54. can i calculate boost from pulleys?
  55. Spark plug question
  56. strim pulley r&r
  57. Any one fimilar with ATI PROCHARGERS???
  58. Best price for CP pistons? Thoughts?
  59. ls1 turbo
  60. STS Kit
  61. Vortech Aftercooler question
  62. Would you buy a used P600B w/high miles?
  63. V-1 vs. V-2...whats the diff?
  64. Connecting the BAP to the electric WP
  65. A WORKING Electric Supercharger!
  66. Turbo charging
  67. ATI Mustang question
  68. Vortech Oil Feed Hose
  69. Does runner length matter with forced induction?
  70. A little Help Please
  71. Supercharger with innercooler
  72. Post your boost and kind of fuel
  73. Car smokes out the breather but.......
  74. MAF pressure side=rich?
  75. Supercharger Help
  76. FMU Removal.. (?)
  77. ATI car won't stay running
  78. Found cracks in torus, best way 2 weld?
  79. Stutter at 5000 RPM and I'm supercharged
  80. New STS Turbo Install
  81. Jet-Hot coatings for turbo manifolds, housing
  82. To O-ring or not to O-ring, that is the question
  83. Proper comp. ratio for pump gas turbo motor?
  84. 115 or 116lsa for 224/236 xe high lift?
  85. AFR target w/ 25# Boost
  86. Can I run a 4.5psi SC with little problems?
  87. Anyone spraying a boosted motor?
  88. Front mount intercooler on a trans-am...
  89. Changing from 30# to 42# injectors??
  90. Paxton Charger Installed - What Upgrades Do I Need Now!? HELP HELP!!!!
  91. 240 datsun lt1 turbo buildup... ?????'s
  92. pulley on paxton hard to spin??
  93. Blitz IC pics
  94. Source for 4 bolt main caps
  95. Supercharger guys... Got your stock Crank hub laying around?
  96. Whats wrong with my car (White smoke)?
  97. Timing Question on Vortech Setup.
  98. WTB good used Vortech or ATI
  99. Measuring pulley??
  100. too much of a pain or not ... ?
  101. Surging during cruise (CL)
  102. At what point are head studs necessary?
  103. is this a good buy
  104. Dimensions of largest possible air filter w/ vortech blower.
  105. which fuel pump will work ?
  106. go get a blower or to not
  107. New 5# ATI supercharger (LS1)
  108. Put a blower on a '95 Z28?
  109. FDelphi (MSD) 55, 65 or 75lb Fuel Injectors - Low Impedence?
  110. Methanol Injection with S/C
  111. H2O injection...
  112. New Motor loading up - Overfueling - Please HELP!!!!!
  113. How do you clock a Vortech blower???
  114. boost gauge hookup??
  115. Newbie ?: How will Powerdyne affect stock reliability?
  116. 2 fuel pumps or only 1
  117. crank/pulley belt part number for 6psi powerdyne
  118. Which FMU for twin turbo?
  119. FS: 3.125" vortech pulley
  120. ATI Procharger on ebay
  121. ATI intercooling questions
  122. all 3192/3196 users
  123. What radius bends for piping?
  124. making more power using fmu than with bigger injectors?
  125. Kenedy Dynotune
  126. got any turbo LT1 videos?
  127. Superfueller injectors... (?s & WTB)
  128. P1SC...pro and cons
  129. JE Pistons
  130. Help...
  131. fuel injectors
  132. TUrbo HEaders...
  133. superchargers and cam combo's
  134. Vortech questions
  135. crankcase ventilation on boosted engine...
  136. MAF readings under boost and at idle?
  137. MAF on pressure side
  138. Where to buy cog setup?
  139. Power Estimates.. i know everyone hates these threads but..
  140. Loading up at low rpms!!!!
  141. Blower or Juice (that is the question)
  142. Ribbed-belt slippage estimate - calc's within
  143. Oil drain mounted below oil level w/scavenge pump?
  144. paxta-map fueler calibration?
  145. Newbie, Turbo questions
  146. blower heads
  147. 55# injectors
  148. Sound clips of mondo BOV?
  149. lookin to get a supercharger
  150. Need a little help with twin turbos
  151. T or TT?
  152. Couple of Supercharged LT1 ?'s
  153. MAF location and boost.
  154. 6btm and autometer tach
  155. Best fuel injection system for centrifugal supercharger???
  156. Some S/C Parts Questions
  157. powerdyne ...tensioner q
  158. New turbo #'s and pics
  159. Dyno blues
  160. Cam/blower Question
  161. Turbo boost controllers
  162. Turbo guys, your going to LOVE this....
  163. monoblade sticking problem
  164. Is it possible to use the hooker y instead of the mufflex y with their 4 "
  165. blower pics needed
  166. 383 Question?
  167. LT1 Supercharger
  168. 1000hp C5 Vette
  169. Turbo or Supercharged
  170. cheapest, best, most power blower?
  171. How much psi will this push?
  172. Anyone boosted with nitrous?
  173. 2 psi then nothing WTF??
  174. which one??
  175. Could use some thoughts on T-70 setup:
  176. Will this cam work?
  177. HT3B turbo information
  178. Alcohol Injection Results
  179. woohoo, my turbo showed up
  180. who has a boost gauge? help me!
  181. Bracketry costs
  182. Need help Powerdyne People??????
  183. Alcohol Injection
  184. rskrause....need suggestion on blower cam, long but detailed.
  185. blower forsale ati lt1
  186. maf to pressurized side
  187. boost gauge connection..
  188. Which plugs to use w/ Supercharger
  189. Will EGR work ok under boost?
  190. where does the maf go with the sts kit?
  191. pyrometer on cyl 7,8 = no burn??
  192. Boost gauge question
  193. Reality Check Needed!!
  194. Hypertech Maf table vs. Stock??
  195. where to buy 12 rib
  196. First Dyno #s and Converter taking a dump.
  197. PCV oil seperator
  198. Pod Gauges, who makes nice looking units?
  199. update on our kit
  200. should i
  201. paxton msd 6-btm for sale
  202. moving mass air meter!!
  203. procharger oil restrictor
  204. Anyone need a front mount IC?
  205. LPH to lb/hr convert?
  206. how much power can I produce with an LT1 Edit running speed density?
  207. knock retard on a turbo
  208. 1000hp Lt1
  209. procharger help?
  210. Cool install
  211. Ls1 Procharger Question
  212. what crank pulley are you guys using?
  213. Installing NX kit next week advice needed
  214. No more proturbo kits
  215. Breather or back into intake?
  216. Dyno Graphs
  217. What Fuel Presure should I be Seeing??
  218. Great heads, quickly?
  219. Source for rubber couplers?
  220. Cryogenic cooler instead of intercooler?
  221. High impetance 60&75lb injectors
  222. Procharger pulley size?
  223. induction/ram-carbed
  224. does any one knows if ati refunds the money if i get back the Supercharger?
  225. Pro-M MAF
  226. Turbo 101
  227. SC and nitrous, is it safe?
  228. underdrive puley/balancer and SC question
  229. Tuning for boost, timing/fuel, also wideband Q.
  230. All using low impedance injectors
  231. Supercharger+headers
  232. Belt slip... please help, oh wise gurus
  233. Stupid "How much hp..." question inside, beware!
  234. Turbo technologys LS1 turbo kits any good?
  235. Twin fuel pump pictures
  236. Question about P600b install!
  237. D1 blower and CSI pump. Do they fit?
  238. install the DFI or stick with lt1 edit?
  239. BAP vs Twin in tank.
  240. programming my 91???
  241. Too much compression for a SC?
  242. Turboed 3.8 dyno numbers
  243. Twin intercooling?
  244. 150 MPH in the 1/4 AND streetable. Possible?
  245. I've been quiet....
  246. Blow off Valve upgrade?
  247. calculating boost
  248. Paxton install on 3rd gen
  249. Need Help with Linkage on a Roots blower
  250. which is better?
