How much flex is needed for turbo exhaust?
Old May 7, 2008 | 08:26 AM
jsetzer's Avatar
I finished my exhaust last night.
Turbo is up @ where the coil would be.
Downpipe goes below the steering shaft
3 bolt flange back by the front of the transmission
cutout
cuts under the tranny mount to the pass side
chambered muffler dumped before the axle
It hangs by 1 normal rubber hanger from the rear by the axle and I used a piece of flat steel (strips of metal from home depot) welded to the exhaust and bolted to the body on each side of the tunnel in the old cross brace holes.
It fits pretty snug. It will move a little bit but I am worried I might need a flex pipe @ where my cutout is or to drop the flat steel for another rubber hanger or two.
Old May 7, 2008 | 08:59 AM
km9v's Avatar
Just get a muffler bearing.
Old May 7, 2008 | 09:08 AM
jsetzer's Avatar
Oh and poly motor/tranny mounts so things don't move around much.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
blac94Z
Jan 22, 2015 11:19 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
