View Full Version : Forced Induction
- Interesting day on the dyno and alcohol injection
- Lopey idle on a turbo car...is it feasible?
- twinturbo lt1 solidroller
- What compression ratio do you want with forced induction?
- Will 987 springs handle this cam?
- Kenne Bell Twin Screw LS1 supercharger
- vortech and intercooler
- Need advice...want a turbo setup
- how much can a 4 bolt block take?
- What valve springs do I need?
- Injector Size?? Need Help
- Timing help
- Head Gasket help?
- new to Forced induction... got some questions?
- 500rwhp what would it take?
- Smog Help
- How much boost can a -34cc piston take??
- Can I hang around here?
- Water-to-Air aftercooler. Thoughts for vortech guys.
- LS1 ATI Procharger Kit for Sale!!!
- aeromotive question
- Cog Drive with fluidamper?
- changed direction(goin stealth)
- Which keyed hub for Eagle crank?
- Stock Pulley
- Turbonetics vs. Garrett T-Series
- does anyone use the turbanator?
- Why does idles hunt from 500 to 1200?
- Good for a laugh! 65 mustang TT project.
- injectors
- 224/236 low lift on a 112 vs 114
- Got a couple of questions......
- need help
- When does the SC actually start too make decent boost ?
- A Vette, but TURBO..... :D New Pics
- I've decided to go with this cam...what do ya'll think.Particularly Rich
- fuel pump ?
- stock turbos that could fit a 97Z28?
- Another question.
- Turbo questions
- Would someone make a guess how much boost...
- How much boost do you typically loose....
- SUPER fitting
- help needed
- When i floor it, it stumbles!!!
- torque converter for twin turbo
- 87'CAMARO Vortech Supercharger
- Fmu Kit
- Supercharger information sites?
- turbo project(finialy got started)
- Which crank for blower?
- S Trim Guys
- 1985 Camaro z28 supercharger/turbocharger HELP!
- Stenod Performance Twin Turbo Formula Videos!!
- Anyone using a 1LE elbow on a s/c setup
- how much more daily driver friendly is boost over n/a?
- fmu
- Changing direction in F.I. Cam/ heads upgrade (request advice)
- what size is the oil feed plug on lt1 blocks?
- Cam
- head gaskets
- Timing Curve Characteristics w/ Turbo Engine?
- Stock 48MM TB vs. BBK 52mm TB
- 5psi, fmic, what upgrades
- Will a Supercharger blow off valve be heard with...
- Question About BOV FOR turbo systems
- Opinions on PTK turbo kit
- Any vids or sound clips of a Vortech S or SQ S trim?
- Anybody running a High Compression Forged LT1 Supercharged setup ?
- Looking for pics
- Turbo question
- pic of a turbo installed
- Pump gas runs
- fuel question for turbo
- Guide to FI shortblock buildup - shortblock questions
- Just broke in new motor and have some ?s
- TURBO INSTALLED!!!!! V6 is ready.......
- which type of forced induction??
- STS Turbos will be 50 state legal!
- cutout with a sts turbo kit??
- Limit of Alcohol Injection's ability to control detonation
- Possibly adding an S-Trim - pan tap question
- Dyno results ! Now what ?
- FMIC install on lt1 Z
- ATI radiator fan spacers?
- Smoke when boosting?????????
- Question for Rich Krause.
- Severe Backfire due to Methanol???
- More new pics of twin turbo buildup, getting close!!
- lowering compression
- Concerned about cam bearing wear (pics inside)
- Holley Stealth Ram IM
- finding aluminum or S.S. intercooler elbows and pipe???
- FMIC now or later
- Turbo Engine Buildup
- Procharger P-1Sc install ?s
- Informative Turbo website
- Water Injection Questions???
- Is this a decent blower cam for a 355?
- fuel system for STS
- I got this idea for a turbo with longtubes...
- Has Anybody used a MSD crank Trigger with a Procharger?
- joined the FI group
- Monitoring for Knock
- Timing question..
- Fuel question
- The right supercharger
- Any thoughts on this?
- ls1 sts on lt1 Z
- Injector/ fuel delivery requirements
- Guess on how much HP this combo would make?
- Looking for supercharger asap
- Want to supercharge but....
- Supercharger or Turbo
- Z28 DIY Turbo Build - Pics
- twin turbo
- Need help with damper problem.
- Desperately seeking TUNE for a 383 Vortech Supercharged Motor
- Single Turbo Setup Question
- Turbo folks, explain me this ....
- mixing and matching Vortech to ATI ???
- running a MAF under pressure
- Lets talk FI tuning: Speed density for LT1
- Quick question(not very technical)
- Proper Bypass Valve operation.
- Those who liked this turbo system...
- Direct Driven Supercharger?
- ATI bypass valve (vent to atmosphere only) questions/info
- Idea?
- thinking of superchargeing t a
- Blown Blower questions
- FMIC on LT1 TA
- Proof STS and rear mounted turbos work
- Can anyone identify these intercoolers?
- Lt1 supercher?
- fluid dampener, spacer for pulley
- Breaking in motor with D1SC
- boost guage operation ?
- where to get a alky kit ??
- more pics of the buildup ...dual walbro pump pics
- procharger
- New 383 wanting to S/C
- Blow Off Valve for procharger on 95 z28
- bosch #42 injector part #???
- 03 cobra versus LS1 single turbo!
- how much boost
- In & out fitting, Vortech ques?
- Bosch BPV question after MAF relocation.
- how hard would it be?
- Could use some advice (exhaust)
- Dissappointed in Aftercooler during Summer months
- with turbo....
- Well I decided to Sell the D1 Kit i have so if anyone intrested...
- Bad Oil Leak In Turbo...... Help!
- Going Batty with DCR
- Coolant temperature for blown motor?
- Anybody rebuild their own supercharger?
- new times, hot cam procharged
- 8 lb's with meth. injection
- Small nitrous shot or alky/meth injection
- Ok whos using a D1-R on a LT1?
- T70 O trim way too small???
- New best
- Cons to using methanol
- will alky injection prolong cast pistons life?
- D-1 and coil location.
- 8 rib blower belt
- I just received my custom cam from More Performance
- another procharger question
- Convince me to go fi
- Lt1 roots supercharger
- Any tips on oil changes?
- A/F Ratio vs. Boost
- kb-121 hypers
- Turbo LT1 - Check it out
- Is this a good turbo cam
- procharger question
- Check this out
- Keyed hub and balancer question
- ic core's...
- Remote Turbo Setup?
- Mounting the Crane Hi-6
- STS Turbo
- SS progress pics
- Looking for Lonie Pavte?
- Supercharged 383 Stroker
- Help on selecting a ATI Pro Charger.
- Best pistons,cam for a turbo application
- New price for t-trim with everything that you could buy for a supercharger
- Supercharger/Motor Suggestions
- T- trim w/ Aftercooler for sale..
- STS Turbo in rear?
- Turbo for LT1
- Exhaust questions
- More TQ. w/ 598 cu in & 6 Lbs or a 509 & 8 Lbs???
- FS: Vortec S Trim SC Kit-LT1
- car bogging in mid range
- Choking Off the Power
- wanting to trade nice fast seadoo for sc. kit for lt1
- where can i find....
- Piston Rings For Turbo
- green air filter?
- Those with Mallory's hyfire VI map sensor inside please
- LT1 Vortech guys inside Please
- Cprrect me if i'm wrong on this compression ratio calculation
- Piston Rings For Fi??
- Could this 90* hold up "suck side"
- Head flow #'s for boss' 67 camaro 383 T74
- Programming out hesitation on tip-in? (big injectors)
- Blown dual intank fuel pump folks..........
- Relocating the waterpump?
- Boy, did I pick the wrong turbo cam
- Open the combustion chamber?
- Looking for a new Forced Induction moderator or two...interested?
- Fastener and injector question.
- Rebuilding engine for the future
- Looking for companies that offer front mount turbo kits for LT1
- Running rough...FMU went bad?
- STS block tapping....
- Supercharger Computer Tuning
- Maxing out Maf sensor
- 94 lt1 vortech T-trim oil pan fitting
- How much boost with aftercooler
- Powerdyne question
- Turbo Questions
- Lt1 STS owners a couple of questions for buddy.
- Pt88 Lt$
- Vortech Sucks!!!!!
- 97 WS6 Trans Am 3 Core Intercooler Location?
- Question about t-rex pump for vortech and meth/alky
- Used Turbo Source?
- supercharger question!!
- Vortech Trex Pump
- Can too much timing retard case misfires?
- My PTK T88 SS
- What fuse to use on inline fuel pump and MSD6BTM?
- Those who have used superchargers and nitrous, which did you prefer and why?
- FS PTK gen2 turbo kit LT1
- Bran New CUstom set of ROSS FI pistons For Sale *pics*
- What Gears To Get??????
- pulley combo
- F/S Custom blower cam
- Wide Band Commander any good?
- Who here has ordered a ptk kit?
- procharger vs vortec
- Vortech setup needs ideas
- where to buy meth
- Homebrew Alky Injection Kit - Pics
- Who all makes a complete LT1 turbo kit
