View Full Version : Forced Induction
- 2 Bar Map + stock pcm - seems to work fine
- Turbo/Compression Q's
- LS1 vs LT1
- 611 rwhp 695 rwtq D-1SC w/cogs
- Plug Suggestion for AFRs and Power Adder
- What oil to run in blown motor in CA??
- Good Crate for Blower?
- Opinions on blower cam
- What are these ports?
- Newbie To boost, got some simple questions
- procharger
- lt1 with V2
- f1 sc
- Questions on my Components for my S-Trim install?
- NGK TR6 what gap?
- The beast is out of its cage ... :)
- S-Trim 383 Pulley Sizing Question
- Turbocharged vs. Supercharged
- quick Procharger question
- Basic turbo question????
- FS: Vortech T-trim
- various mods vs. forced induction
- any progress with a ptk tubo kit
- Turbo update
- Turbolocity Twin Turbo Kit
- People with over 9psi at 3k-4k what plug?
- Miss above 4,000 rpm's
- What fuel injectors 5-600 RWHP?
- Walbro 255 intank
- LT Hookers versus AS&M Shorties with FI
- powerdyne?
- How to build your own turbo kit?
- Tire Smoking ATI Supercharger specials!!!
- Supercharging a stock LT1...
- Fuel System Recommendations
- Add mild cam to low boost stock motor or leave stock cam in while replacing lifters?
- help me with shopping list, building turbo LT1
- Rear mounted turbo?
- New to FI
- Alright then how much boost for a daily driver?
- Is there a way to size a TB for a blown application?
- Pics. of Procharged 454 in my 80 Z28
- Water/alcohol Injection is for you!
- ZZ4 Crate w/ Blower
- supercharger
- supercharger install
- best clutch for daily driven turbo LT1?
- Which Turbo Kit Would YOU go with?
- price of a T04
- Reliability of a SC LT1
- Good Deal??
- New Turbo Company building custom kits
- 8 rib pulleys for sale, 7.85" crank, and blower pulleys
- Anyone try Megasquirt?
- Help
- all my FI stuff is for sale, tons of it
- Any way to get a centrifugal s/c to build boost more quickly?
- Boost is falling off.
- if anyone is looking for a gen7 dfi kit...
- Twin screw like this for the f-body.. very good option!!!
- Ls1 turbo options?
- boost and rpm
- boost and rpms
- anyone dealt with...
- d1-belt problem-help
- Alright teach me about forced induction!
- Best supercharger
- Where'd this extra pound come from?
- would a mustang T trim HU fit my brackets ?
- SC belt measuring ???
- Need to learn about forced induction
- Procharger and head\cam selection
- Preference for a turbo setup
- Does anyone sell just the headers for a turbo kit?
- how much boost is the stock vortech bypass valve good for ?
- Which rear end gear ratio with high boost ?
- Exactly what Turbo would be good for an LT1
- Ati P600b
- any downside to running bigger injectors than u need ? (96#)
- I neeed 100LB injectors or close
- single or twin
- pics of a screw type
- Vortech & Procharger ?'s
- stock LT1 + turbocharger
- which bypass valve to run with 20 psi T trim ?
- how much hp with 50#ers ?
- Wich pulley size for my 383 ( P1-SC)
- Comp Cams tells me this cam for my setup???
- Anyone have any big injectors for sale?
- Just bought Procharger!! :)
- ACCEL gen VII blower tunes
- upping boost, fuel system questions
- 3rd gen LT1 w/ATI procharger
- Do I have to remove my blower/brackets to install my cam??
- How does stroking an engine affect boost limits and detonation
- Need help! Crank spacer stuck!
- buying a LT1 turbo kit
- Question about Turbos
- new supercharger, odd problems...
- Blown LT1/LT4 Engine Management Forums
- Runs bad in the rain
- How does this cam sound for a turbo?
- exhaust size ?
- Lets say i had a turbo. What else would
- So what can you tell me about turbo cams?
- SFMU or Tune the OBDI or get a FAST?
- Tires spinning, or clutch slipping.
- electric supercharger???
- Weiand/B&M 142/144 blowers???
- Does the STS Kit come with a BOV?
- 224/236 vs. 227/239
- Turbo questions
- BTM required with boost?
- Boost and Spray??
- Blower pulleys = what works?
- Should I upgrade from an S trim to a T trim?
- Pulleying up... do I need a new bypass valve?
- Engine Runs horrible
- where to get an lt1 turbo kit?
- Need help
- IC: Efficiency Vs Flow
- Woaho!
- Ordered a new cam today
- how to reclock an S trim ?
- When is step up to billet recommended
- Supercharged AND Turbocharged?
- small block headers compatible w/ LT1 heads?
- Unconventional Turbo Setup?
- Where to purchase parts for air/water intercooler?
- How loud does a 4" mufflex get on a blown setup
- Idle problem/ low end miss
- 6 or 8psi on a P1SC??
- Alittle over 400hp from the Suburban
- Purchase a supercharger and receive 10% off your next purchase!
- p1sc need help
- 3rd gen T72 Turbo kit update
- 9psi
- Twin turbo exhaust housing A/R
- Air/Fuel ratio
- ATI D-1SC custom 8 rib kit for sale.....
- Cam for blower motors
- Looking into...
- Just got in new maf
- Procharger 3 Core Measurements.
- Z28tt Progress Pictures!
- selling my msd 6al BTM
- superfueler question...
- single intercooler
- Traction ctrl removal
- Will this get me past 500 rwhp...
- Mr Gasket #5716 "Ultra Seal" Head Gaskets
- Where are you guys mounting your gauges at?
- I LOVE my P1SC
- first time at the track for MSM69Z28
- How much boost can I safely get with 10.0 : 1 compression??
- If I have no vacum lines, where do i hook up my boost/vacum gauge???
- supercharged lt1
- supercharged lt1
- Boost guage doesn't move, and Fuel cuts out.
- NEWBE STS Turbo Question
- how low of a c/r can i make with 52cc heads?
- supercharger
- help me pick a custom cam for my new setup (thinking about a high lift cam)
- o ring the block or felpros with good head bolts?
- anyone use cometic MLS gaskets?
- Where to buy low z injectors?
- How much boost should I run and at what compression?
- LOOK At this sleeper turbo set up!!
- modding plugs
- Need help with supercharging issues.
- Accel shorty plug??
- 383/D1SC pulley experts please help
- turbo spool quicker unhooked?
- Is the STS kit emissions legal
- Do u guys think could work?
- PTK cross-tube question
- in need of a new clutch pressure plate flywheel etc..any sugggestions
- Good head unit?
- anyone wanna trade for my 224/236 cam?
- vortech head unit
- T88 turbo kit..
- N-E 1 notice a difference in HP between Borla Plates (10+psi)
- Need K&N for procharger
- Supercharger and Daily Driver Wheres the Limit?
- Vortec bracket
- supercharger ?
- Here's another place to get stainless header pipe
- 18+psi BOV
- boost on stock 3.8
- any1 got vid's of supercharged lt1s on net?
- Used Procharger/superchargers
- Anyone powershift into 5th?
- whats a good turbo cam?
- Spark Plug question...
- Quick Procharger Pulley question
- Who make the best boost-a-pump
- Vortech YS fit/application question
- My PTK setup is almost done...update for those who care
- turbo or supercharger...
- Paging SleeperZ about the PT88 LT1 that goes 8's
- T3/T4 Turbo? LOL
- Adjustable boost with S/C?
- Electrical Problem...Please Help!!
- pics of my twin turbo iroc
- ati prices dropping!?!?
- help me with my new blower setup (converting from NA+N2O)
- The LS1 ATI kits have just got better!
- STock LT1 with a Turbo, 552 rwhp 630 rwtq video inside...
- Tensioner issues = munching belts
- after/intercooler help
- ATI SuperDamper and Supercharger Pullies
- twinturbo ss
- One of the BEST ATI Dealer/Distributor just got better
- 9.006@159mph = fastest and quickest LT1!!!!!
- ???????help
- Source for mild steel header parts?
- Crank pulley sizes for a Vortech setup.
- Went To The Dyno Yesterday And......
- WHy can imports handle more boost
- How do build a reliable S/C LS-1
- Why not 355?
- Mounting a BIG intercooler on a 4th gen?
- Pro Turbo Kits
- starting an engine that's been sitting
- machining hub for key
- TT setup
- Bottom-end build on smallblock V8?
- easiest supercharger
- Supercharged Virgin - durability?
- Supercharged LT1 Rebuild
- Denso plug/ electrode mod ?
- Intercooler Question...
- Individual parts vs. Kit
- BLOWN V-6 vs. LT1
- Turbo Ideas Please.....
- Any of You ATI P-1SC guys have a 12# pulley laying around?
- Problems with Blow Off Valve
- Horsepower is flatlined from 4,800-5,500. Need opinions
- New single Turbocharged SBC 3rd gen Im working on pics w/in
- Cold air induction on an S/c motor....
- what cam should I go with?
- Total Seal gapless rings?
- what brand piston rings to use?
- Interesting dyno numbers today
- Do 8# IC rides last longer?
- What turbo or turbos are you using?
- turbo cam??
- P1SC Installed
- Vortech, Aftercooler & Mondo Bypass pics ???
- tuning D1sc with 57#
