PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35
  1. Roots SC on LT1
  2. TS04's, 60-1's, 62-1's??
  3. 3.8L turbo
  4. 5.3L supercharger
  5. Twin turbo picts
  6. Any videos-ATI S/C in an LT1?
  7. 3/8" vortech mounting plate?
  8. ls1 procharger on an lt1?
  9. WTF sucking 255 dry at 5000rpm..I thought this would be good for 500rwhp. Options
  10. Single turbo system progress (pics)
  11. Do you need to add extra oil every change if you are tapping the oil pan???
  12. New best Powerdyne ET despite horrible traction
  13. Any BOV recommendations?
  14. Can anyone here help me get in touch with Shalin Patel?
  15. Roots Blower + Nitrous?
  16. turbo
  17. how much boost from this setup?
  18. What to expect from combo
  19. Selecting a Blower Cam
  20. How is everyones car coming along this season??
  21. T-trim vs. S-trim
  22. whats the biggest cam that can pass smog
  23. Supercharger & Nitrous
  24. Help me choose a blower cam and parts...
  25. Best Compression Ratio????
  26. Lt1 Supercharger For $200.00-read This!!
  27. Moving the MAF sensor with an ATI kit? (intake or pressure side?)
  28. What is your MPG on the highway with 50# Injectors?
  29. autometer fp guage?
  30. Blower Belt for sale
  31. Garrett t04 turbo
  32. cut out area between foglights?
  33. Can stock bottom end handle this.....
  34. Superfueler Users
  35. 840hp/770tq
  36. Where to get tuning in the south?
  37. Building a RACE only Forced Ind. Motor
  38. Ready to install billet hub, but it wont clear
  39. Looking for a head unit
  40. Spark plug brand and gap size with Supercharger and MSD????
  41. '04 Lightning intercooling System
  42. Acceleronics and 72#/hr are great!
  43. New Vortech and ATI prices for April!
  44. Woooohoooo!!!!!!!
  45. ATI or 383/427
  46. George Baxter's badass blown '97 SS Camaro?
  47. Is there something like too much boost???
  48. Tons of questions :)
  49. Twin turbo update
  50. headers glowing
  51. Cost of twin turbo
  52. water pump replacement
  53. Just purchased D1, have timing question and pulley Q?
  54. supercharger on a stock engine????
  55. FAST tuning help!
  56. ATI fuel system questions.......
  57. Procharger Intercooled Supecharger (Experiences)
  58. Ignition Help on LT1 v/Vortech
  59. Well, it lives, kinda!
  60. Spark Retard without increase in Knock Count?
  61. How much boost on a stock engine...safely!!
  62. Dyno Techs or Thermo Inclined People IN HERE PLZ
  63. Will the 355 get me there?
  64. advance or retard (cam install for turbo)
  65. Powerdyne BOOST Level ?
  66. advance or retard (cam install for turbo)
  67. Only seeing 4lbs of boost??
  68. Turbo Request Today
  69. What is the Inlet size for a D-1SC
  70. Too late to super charge?
  71. Turbo Tune in greensboro Nc??
  72. ATI or Vortech. Please Help me Decide
  73. stumbling in the upper r's
  74. Supercharger tuning
  75. s-trim guys inside please!
  76. Forged pistons
  77. Spark Plug Gap with P1-SC
  78. Yet another question on my Powerdyne install...
  79. Anyone Measure Power Gains with Vortech Aftercooler?
  80. I just flashed a new prog with burst retard programmed out...
  81. ATI question
  82. Having temp probs...
  83. Procharger crank pulley question
  84. How Do I Know if my bypass valve is working?
  85. Procharger COG Setup
  86. Stock balancer how good
  87. Installing a Powerdyne... a couple of quick questions.
  88. In the middle of Hooker LT install, Need help
  89. Those with Ultra lite or Carbon fiber gages, please help me decide.
  90. primary tube size ???
  91. Vortech Supercharger Drive Pulley, 2.95", 8-Rib, Fits 1993-97 GM LT1 5.7 F-Body
  92. Lt1 Scanmaster code ?
  93. Can Toluene and Marvel Mystery Oil cause white smoke from exhaust?
  94. What? F3R is CHAIN Driven?
  95. 2 bar map sensor and maf limitation??
  96. 1 or 2 intercoolers
  97. Who has made a Vortech power pipe (solid intake tube) with PVC tubing???
  98. explain a reverse rotation blower
  99. Kenne Bell Boost a pump and fuel system ?'s...where at? How much? etc.
  100. Has anyone changed the location of there Twin Intercoolers
  101. Turbo or S/C?
  102. Dyno #'s with ATI F1 and Turbo 400
  103. 39lb/hr SVO Injectors $199 (8)
  104. Boost/vacuum readings?
  105. Maxed Out MAF???
  106. turbo prices
  107. Alky Injection??
  108. FAST tuning questions
  109. not that simple, but someone should know
  110. New turbo kit is out.....
  111. Fuel system
  112. Using stainless Weld-els for turbo header fabrication
  113. Has anyone run a supercharged on alchohol motor with brodix -12s?
  114. Spark Plugs with P-1SC
  115. Aftercooler worth it with Vortech?
  116. Turbo pics!
  117. 355 buildup turbo project...questions
  118. Exhaust sound for a 383 w/ a Vortech...
  119. Inj rails support ? HP
  120. Difference between Vortech S trim and T trim?
  121. LT1 Whipplecharger Kit from Hesco?
  122. F*ing Crank Hub
  123. do i want one heat reange colder plug with turbo?
  124. 60-1 hi fi kit
  125. all people with the twin intercooler ATI
  126. Blower vs. Turbo, High vs. Low pressure.
  127. Is a 218/234 on 112 lsa a decent blower cam?
  128. My V-1 S-trim is a bit noisy... not the whine...
  129. sub 0* water air intercooler coolant
  130. new intercooler on its way :-)
  131. LS1: twin turbo vs. blower vs. stroker
  132. Turbo Q's
  133. Where to get vortech aftercooler cheap?
  134. IAT temps NONE intercooled.. please post up
  135. Questions about tuning ATI
  136. SBC superchargers
  137. looking for roots blower on third gen??
  138. Grand Prix GTP supercharger
  139. CO2 injection
  140. T-04 Turbo suitable for single turbo setup?
  141. Do I Need The Bypass Valve
  142. It's Home!!!!
  143. TurboCharger Idea
  144. ATI #7 kit what injectors are u guys using?
  145. HP predictions?
  146. Anyone run cogs?
  147. Fmu ?????
  148. Hey Jordon, How much longer till that beast hits the street?
  149. I only get knock retard when I shift hard or punch it suddenly...
  150. Paxton Supercharger Questions
  151. Turbo Headers/Manifolds?
  152. quick question for powerdyne guys
  153. Head Gasket Sealing
  154. How to remove ASR
  155. "Which is better?" question.
  156. Procharger oil change in FOUR HOURS!
  157. Air flow ?
  158. Turbo M6 boys - which gears ya running?
  159. GN motor swap starting to shape up...
  160. Nitrous problem. Won't rev over 5100rpm???
  161. Anyone put in a turbo timer?
  162. fuel pressure regs for high boost applications
  163. Where to get the best price for a D1 for lt1
  164. New Best : 5.98 @ 116+ Mph
  165. intercooler sizing question
  166. turbo/super
  167. Stock bottom end supercharging Qs
  168. turbocharging vs supercharging
  169. Fact fuel pump w/boost pump, replacing fact with?
  170. question about converting a NA car to turbo...
  171. Need to know if this Toulene is pure ASAP please
  172. Sequential Turbos
  173. Powerdyne 4.5 going to 6 question
  174. How much timing are you guys running and how to retard it?
  175. supercharger/turbo ductwork suppliers?
  176. 396 D1 17PSI A few questions on fuel details inside
  177. Who makes the best intake gaskets for LT4 heads?
  178. ATI 8 rib P600B 8# blower belt
  179. 383 Cam Question
  180. engine block O-ring ???
  181. 20-25#'s or up boost ???
  182. Turbo guys - Heat Management Products
  183. Ready in two weeks!
  184. IAT Temps
  185. Turbo gaskets?
  186. inter cooler upgrades
  187. Not Street Legal (POWERDYNE)
  188. Powerdyne ??Help !!!!!
  189. Supercharger prices that will blow you away!
  190. fuel pressure
  191. Anyone one here running 8.5 to 1 compression
  192. YS Trim information...
  193. Ati boost pump relay, gone bad?
  194. help on installing Hooker LT's
  195. will a procharger for a rausch mustang fit on a lt1?
  196. 450rwhp '90 C4 - what would you do to for the fuel system?
  197. Polished Vortech Kit on Ebay!
  198. To All members!! Need help concerning GWP!
  199. what sounds better, turbo or supercharger
  200. T-trim head unit worth ???
  201. Anybody knows a good sport at Vortech to talk to ??
  202. 355 vs 383 for turbo application
  203. Is Axis Industries no more?
  204. Help on LS1 Twin Turbo
  205. turbo kits????
  206. bigger boost with bypass valve
  207. Overspinning a BD-11A
  208. Help on putting crankshaft hub and Hooker LT on
  209. Blower Cam to pass emissions
  210. boost gage
  211. WTB: 6LB Procharger pullies
  212. Vortech YS-trim ???
  213. ?turbos (kind of tech) ?
  214. supercharger for 81 z28
  215. pro turbo kits.. thumbs up!
  216. prochargerpower.com new website
  217. Turbocharged/Supercharged L98 Corvettes?
  218. Vortech crank Pulley?
  219. Started Updating webpage
  220. EGR Block off neccessary w/boost?
  221. Link to FS powerdyne 7" crank pulley ($155 shipped)
  222. What kind of price($$$) for a 383 stroker built for a lot of boost(SC) on an LT1?
  223. 4L80 Trans
  224. Wastegates - Tial or Turbonetics?
  225. This is ProCharger stuff does not make any sense.
  226. Turbo Questions! ?
  227. Ever wonder how a 91mm would fit in a 94 Camaro ? Pics inside.
  228. Turbo Sizing
  229. Valve cover removable with procharger installed??
  230. Where can i get Internal Powerdyne Parts, namely the Input Shaft??
  231. which supercharger comp. cam works best for mainly street, some strip
  232. Start of twin turbo project
  233. Holley Stealth Ram MPI
  234. TB bypass in SC application
  235. Best Cam For My Combo???
  236. Anyone Have A Lt1 Edit File For 12psi Vortech W/50lb Inj.
  237. Need tuning advice...
  238. Reverse Rotation Procharger?
  239. Quick Q about blower kits
  240. Tempature question on intake air?
  241. Fuel System
  242. AVC-R install
  243. How much does 1 pound of boost raise the CR?
  244. wtb: bypass valve or blow off valve (u say potato i say patata)
  245. ATI P1-SC Unit Comparison.
  246. Speed density and supercharging...
  247. Electric Supercharger for LT1's ?????
  248. Anybody using an INTERcooler with a Vortech blower?
  249. what size pulley do you use on your D1?
  250. attn: Brady_96Z
