Aftercooler leaks water into intake!
Old May 26, 2008 | 03:15 PM
Vortech396's Avatar
Unhappy Aftercooler leaks water into intake!
I could use some help from you guy's.
First my heat exchanger leaks now this.
Long story short my Vortech Aftercooler had a 2" crack in the front of the case. It was between the 2 inlet tubes. Not too sure what happend. Maybee water froze in it during the winter.
It would leak water if I turned the pump on. So I took it to a welder to get the crack welded. I thought all was fine. Ran the pump looked inside and sure enough it was pooling up water inside the Aftercooler!
Crap what the hell do I do now?
Any help would be appreciated
John
Old May 27, 2008 | 02:01 PM
97WS6Pilot's Avatar
I would just get rid of the aftercooler and get a methanol kit.
Old May 30, 2008 | 07:52 PM
Vortech396's Avatar
97WS6Pilot,
Thanks for the reply. I was looking at a methenol kit. haha
I would like to get this fixed though
Old Jun 1, 2008 | 11:39 AM
Blownbird355's Avatar
Hell just add methanol to your cooler wtr and you still have both!
Old Jun 1, 2008 | 12:18 PM
OBE1 95Z28's Avatar
Welding up the outside of the aftercooler case doesn't do anything to fix the "radiator" that's inside the case. Not sure that you can get access to fix the internal leak.
Old Apr 15, 2009 | 01:49 AM
ss#1230's Avatar
i'll sell you my aftercooler....
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
alex5366
Feb 17, 2015 10:43 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
