procharger belt
Old May 14, 2008 | 07:51 PM
ss97dml's Avatar
procharger belt
where can i get a 12 rib 43" belt from besides procharger? they have them but want $83 i tried napa,autozone,advance,murrays and carquest with no luck
Old May 15, 2008 | 08:18 AM
mzgp5x's Avatar
I got my 12 rib from NAPA. Some have used two 6 rib belts.
Old May 15, 2008 | 12:56 PM
mdcaprice's Avatar
I was never able to find one anywhere but ATI. I ended up buying mine from finishline performance. It was a few dollars cheaper than straight from ATI.
Jim
Old May 15, 2008 | 06:46 PM
Sparkz28ss's Avatar
start digging...
http://www.gatespowerpro.com/Comerge...TOKEN=51303512
Old May 15, 2008 | 07:11 PM
Sean94Z's Avatar
This has been discussed many times on here. Gates only makes the 43" 12 Rib belt for procharger. Some people have used a 14 RIB Belt and cut 2 ribs off. Some have used 2 6 rib belts.
Old May 15, 2008 | 07:34 PM
CALL911's Avatar
I have also heard of people saving a lot by just going with 2 6 ribbed belts.
Old May 15, 2008 | 09:06 PM
ss97dml's Avatar
thanks
Old May 18, 2008 | 08:11 AM
ss97dml's Avatar
do they slip at all?
Old May 18, 2008 | 09:03 AM
CALL911's Avatar
If you are refferring to the 2 belts side by side, from what I understand, they slip no different than the one large belt.
Old May 18, 2008 | 11:57 AM
Lisa33's Avatar
We have used 2 6rib belts for 3 years now, no signs of slipping (rubber dust)
Have broke one 6 rib on those years.
Old May 19, 2008 | 12:58 PM
94SLUG's Avatar
You cant.. Only procharger I have have called every company known to man with no luck! I have a 42 12 rib same problem. You may be in luck I think I have 2 43 12ribs I will pm if so... Will sell cheap..
AviatorDave
Dec 19, 2016 06:35 PM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
