Valve springs
Old Apr 11, 2008 | 01:19 PM
cause4panic's Avatar
Valve springs
Ok so the turbo, intercooler, v band, and two reducers that i need are ordered.
Will running 5-9psi(max max max) on stock valve springs produce any float etc? Any stability issues?
I have zero experiance with pushrod motors on boost.
Old Apr 11, 2008 | 01:24 PM
jsetzer's Avatar
How many miles are on those stock ones?
Answer is maybe. 9# they "should" hold if they are not tired and staying in the stock rpm range.
Old Apr 11, 2008 | 01:31 PM
Stock rpm range, prolly 110k on the motor. but It seems very healthy. Completly stock!!!!!
Old Apr 11, 2008 | 01:58 PM
jsetzer's Avatar
If you are on a budget it can't really hurt to try. Plenty of people have done it in the past. 5psi should be fine, above that may be hit or miss.
Old Apr 11, 2008 | 02:49 PM
So i would know they are floating by a sharp drop in power at X rpm correct?
Old Apr 11, 2008 | 04:17 PM
jsetzer's Avatar
Pretty much. The times I have seen it its like hitting a rev limit. On the dyno it would be a really sharp dive.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
