- Pulleing up the S-trim.. what would be the gain.. or losses???
- An impressed newbie
- How's this for a reliability check
- Oil feed line
- SC Engine rebuild
- Any safe/easy mods for supercharged 3.8 GM motor?
- Eaton RUNS!! LOUD PROBLEMS WITHIN..
- Aftercooler dyno numbers and other stuff
- Oil leak with high volume oil pump
- D-1sc kits
- Compression Ratio Advice
- spa dual gauges
- what injectors for boost????
- Boost Gauge Question
- Twin turbo car finished!!
- Rear End for Twins
- Newbie advice on Procharger..
- dual spal 11" fans?
- Fuel management with LT1 turbo set-ups
- Cog pully set up forD1SC ?
- Need ATI 2 core specs
- Boost Controller For-sale
- PLEASE help...safest tuning for s/c
- ????'s about procharger
- Mods to d1sc to make 15lbsof boost on built motor.
- Eaton M112 LT1 Project near completed.
- t-25
- Can i take blower belt off and floor the car?
- Lt1 + Vortech....?
- anybody who has put a turbo where is didnt belong please inside.
- Building LTI turbo, need some info
- Need your advice please
- ATI ProChargers ???
- Compression ratio question
- Electric Supercharger kit?
- Will the NOS Fuel pump from holley work with a Vortech S-Trim??
- Car cuts bad after S/C install help!!!
- Is this possible????
- Can someone tell me a good s/c set up!
- More air to the rad by removing fog lights?
- Will a Volvo Intercooler work with a S-trim
- Vortech pulleys 6.66 / 2.95 how much boost do you see with them
- Some Supercharging Questions
- My near future plans - will I get to 550 rwhp???
- anyone use PVC pipe for a hard pipe (procharger)
- Looking to upgrade to d1?Quick!!
- interesting info for anyone running accel fuel injectors
- FINALLY some more updates on the turbo car
- Blower Piston / Wrist Pin Question
- Ignition break up under boost
- Billet 4130 LT1/4 balancer hub
- blower cam
- Anyone Successfully Running An STB W/The Aftercooler Setup?
- blower for my 91?
- I'm hitting a wall at 4800RPM???
- wtb procharger for 93 z28
- Single turbo setup is up and running.
- Turbo cam?
- Knocking on 6th gear
- Why no noise?
- Supercharger Videos/Soundclips
- 383 LT1 w/ P600B & Nitrous
- anyone have one?
- How much timing are you guys running at WOT?
- Turbo Selection Help
- Twin screw supercharger
- By-Pass for 6PSI Pulley........
- Any Pros and Cons with using Toluene?
- engine layout and tune please :)
- Please help with engine rebuild!!!
- Anyone use the Tech Edge Wideband?
- Question for you blown guys
- After S/C install motor quits after 4k RPM Help!!
- Anyone use an engine tie down chain/strap?
- ProTurbo kit installed on LT1
- Entry level blowers or turbo kits
- Never let a new motor overheat
- My Orange tube replacement...Pics inside!
- Well looky looky what I found...
- Just bought two Rajay turbos and installation kit for sbc, will it work on LT1?
- New Pictures of PTK's Turbo Kit
- Car whacking rev limiter.....
- S-trim guys- with in please
- Fans for intercoolers?
- turbo cam for sale
- Finally got car back...
- Vortech pulleys and boost... Need advice
- procharger?
- gen 6 dfi help?
- ? on a 383bottom end we just put together
- New Powerdyne 6 psi install w/pics
- Who has delt with SD-Concepts
- FMU working?
- Who runs an oil cooler
- What happens when the MAF Maxes? Symptoms?
- Rochestor(sp?) 50lb injectors?
- Car still running hot!?!?
- Just got a turbo
- Aftercooler Water Pump
- 95 lb/hr injectors are streetable!
- TBI+supercharger?
- Whats needed for a 12rib setup?(procharger)
- My project is getting boost, What do I need for fuel?
- Powerdyne pulley?
- Vortech Aftercooler guys.. chime in
- fuel rail pics with -AN fittings
- Good price for Procharger
- Weiand 6-71 Street Supercharger
- Knock retard from blown header gaskets?
- low oil pressure after s/c install
- D1SC guys...need some info
- Who uses copper head gaskets?
- Blower belt?
- New Motor
- If I were to stumble across $8000-$9000
- Where to find 4" tubing
- Dyno results are in!!!!!
- How much fuel pressure S-trim
- My Project is almost completed.
- P1sc Oil Change Questions
- Has anyone fabbed up a solid intake tube for VORTECH S-trim?
- Anyone running SPEC stage 4?
- anybody have experience with magnacharger for ls1 c5.
- Tubing question
- What clutch you running?
- Supercharger special!
- How do you make sure a vortech pulley is tightened???
- Anybody have a 6# vortech with my mods???
- PTK kit has arrived
- Composite head gaskets?
- 2 weeks and almost 2k miles...
- whats the cost of having a tech install a supercharger
- Slight High RPM break-up! Is it MSD BTM TIME?
- low-cr 383 LT1 pistons
- Best price on a Walbro 340M??????
- what will i need to do??
- Looking for reccomendations for FI piston rings
- How are emissions affected with FI?
- Can I get some links to the Walbro fuel pump installs???
- Need FAST Program for 83 lb injectors
- Need source for silicone hose connectors
- Exhaust Gas Temperature
- 3.42 to 3.73 worth it on Supercharged Z
- roots supercharger app?
- Fuel pump?
- T88 turbo Q's
- Couple of weird knock questions... this post will become useful.
- 6lbs
- Supercharger Application
- Who is using a MECHANICAL FUEL PRESSURE gauge???
- Solid Intake for D1SC
- Help! Rattling sound from procharger p1sc at idle?
- Inline Pump Q...
- Supercharger Question / Dilemma
- Racetronix Twin in-tank pumps
- Fastest on a p600b?
- Tapping tank?
- CR on a 383
- Big injectors
- ATI in-line pump
- Tune Time
- Writing Report on Superchargers: Need Help
- functional air scoop with SC?
- Should I or shouldn't I.....
- Miss and SES light at 4800 RPM
- Will a GMAF make any diff on boost?
- Finally they updated the build-up on the BMR project car....
- What sized screw fitting is going into the fuel line T-Block?
- For sale : Polished Mondo Bypass valve
- F1 R on LT1.......
- Piston selection for 350-355
- YS trim and brackets and vortech Aftercooler
- Exhaust gaskets (Jordon???)
- RKrause ... you have mail
- What shold Fuel Pressure be set at with a stroked/blown LT1?
- Where to start to learn about turbocharging?
- someone tell me about the ATI procharger
- Supercharger help!!!
- Updated LT1 single turbo pics
- Supercharger??
- ATI Install
- How fast does my car have to be before....
- Improvements to Vortech Aftercooler?
- Building A Shortblock for a Blower
- Turbo cam?
- Turbo Tech kit, what BOV??
- t-bo on a ls1
- who uses powerdyne supercharger on their LS1
- LS1 and Turbos...
- v6 turbos...
- Another new best for my Powerdyne SS
- Mondo bypass valve flange ?
- Accel 36lbs. Injectors fine???
- Are these specs good as a blower cam...
- Another dyno disaster........questions...
- I think I may be close to joining "The Club"
- At what boost level is O-ringing the block neccessary?
- 42# vs 50# high Z injectors for drivability?
- ARP head studs on LT1 question ???
- Need help w/ Propane injection.
- Anybody know what's up with the BMR Fabrication 4th gen 8 sec. turbo F-body project?
- Any setups like this for LS1 Camaros?
- Is this OK?
- Recomendations
- Thoughts on Paxton SN-93 Supercharger?
- Knock retard gurus, please step inside
- Help LOW BOOST !
- 383 Advantages
- Two serious questions, need help please.
- FAST tuning
- have had blower on car for 3 years need some advice for stage 2 rebuild
- CW or CCW rotation?
- Cam with Supercharger Help!
- Supercharger for third Gen
- Max boost from a P1SC on a 383
- Gapless rings for a supercharged engine?
- Question on Performance of 8psi
- Question about single turbo setups...
- Can you manipulate the pully combos to start making boost lower???
- Problems with Aeromotive Adjustable FPR? Anyone else have this??
- Important advice for those with Vortech's and shorties
- Twin Turbo+TNT=Crazy?????
- new intercooler pix posted
- nitrous express n-tercooler kit?????
- Daily driver LT1 with froced induction???
- New Best for my Powerdyne
- Racing a turbo car…
- YS Trim induction pictures...need help!
- Propane = richer?
- Procharger question.
- Running 42 lb injectors, is a PCM reprogram necessary to get it to run right?
- TurboTec RW#S w/T76 and....
- Oil in ATI intercooler??
- Anyone use MSD boost a pump?
- Inline fuel pump NOISE?
- Supercharging LT1. What all is required?
- New Lt1 Turbo Kit...
- Help ! LEAN !
- How do I SUPERCHARGE?
- q. on preping car for sc.
- MAF or Speed density for 4.5PSI powerdyne kit
- BOV valve? Anything special needed or will antyhing work?
- Ls1+ati 8#
- LT1 Turbo Kits???
- Anyone ever use this intake on thier ATI or Vortec blowers?
- Injectors and HP
- Removing ASR
- Install Problem
- Going to lose cats/will it change fuel del. lean?
