Vortech YSi users, a question for ya......
Old May 29, 2008 | 12:51 PM
bad95formula's Avatar
I did a search and couldn't find too much info on this. I plan on going to a YSi trim when I build my 383. I dont think I'll be going to an intercooler because I don't want to cut up the front end of my car. That leaves me with an aftercooler type setup. I've seen the threads on whether or not the vortech aftercooler can support a YSi trim. I'm wondering if anyone knows of a place that will custom fab an aftercooler setup that will support the high boost levels the YSi can put out. Any suggestions?
TIA
BTW, this is on an LT1
Old May 30, 2008 | 05:55 PM
ak95ta's Avatar
here they are, but they are spendy.
http://www.precisionturbo.net/interc...tegory_id=3052
Old May 30, 2008 | 08:49 PM
engineermike's Avatar
The Vortech Aftercooler will support quite a bit of power. I kept mine at first when I switched to a turbo. I made nearly 700 rwhp with it through a TH350. However, I did measure about 2 psi pressure drop through it. I later put in a much larger custom Bell unit and made the same power at less boost.
Mike
Old May 31, 2008 | 10:01 AM
Vortech396's Avatar
Mike,
Which intercooler did you purchase?
My Aftercooler core is leaking and I need a replacement. Is your Bell intercooler in the same location as your Aftercooler was?
Old May 31, 2008 | 01:40 PM
Originally Posted by Vortech396
Mike,
I now have a custom-made Bell unit that's about 2.5x the size of the Vortech aftercooler. I relocated it down to just behind the air dam and below the radiator.
Mike
onefastgta
Mar 19, 2015 10:10 AM
Moshbmx1
Feb 17, 2015 10:51 AM
maybe2fast
Feb 5, 2015 05:14 AM
Jlo
Feb 3, 2015 09:41 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
