1999 vs 2000 exhaust
Old Feb 4, 2011 | 02:24 PM
dshaw42085's Avatar
Could anyone tell me the difference in the exhaust systems on the 1999 and 2000 model Z28 Camaro? I'm looking to purchase a Dynomax off road y-pipe. However, it is only listed for the 1998 and 1999 model.
Part number is 88027.
It can be viewed here:
http://www.jegs.com/i/Dynomax/289/88027/10002/-1?CT=999
Old Feb 5, 2011 | 01:09 PM
dshaw42085's Avatar
Re: 1999 vs 2000 exhaust
If no one can answer this question, then could you direct me to a solution for my problem. The flange directly in front of the driver side cat is cracked where it bolts to the manifold. I need a solution that doesn't involve buying another cat. I have some other issues with my exhaust system and was hoping to take care of all of them with a y-pipe.
Old Feb 12, 2011 | 08:51 PM
dshaw42085's Avatar
Wow, I don't know what I would do without you guys.
Old Feb 12, 2011 | 09:35 PM
I know this is the "Exhaust" forum... but there's not a lot of traffic. We are in the midst of realigning the forums to try an make things better.
In the meantime, I'll move this to "LS1 Based Engine Tech" in the hope that the increased traffic there will help you find a solution. On the other hand, I don't think your sarcasm is going to help you get assistance.
Old Feb 13, 2011 | 09:02 PM
9T8W66's Avatar
The difference between the `98-99 and `00-02 exhaust is the manifolds and Ypipes.
`98-99 cars have the tubular style manifolds with one cat (left one) bolted to the manifold and the other is under the floor.
The 2000-up cars got new cast iron manifolds and relocated both the cats to being right off the manifolds.
Sorry not sure if the Dynomax O/R Y-pipe will work or not.
Old Feb 14, 2011 | 06:34 PM
AL SS590 M6's Avatar
Moderator
That pipe won't fit a 2000 and up. Bassani makes one that fits well.
Old Feb 16, 2011 | 09:33 AM
Chrome383Z's Avatar
Where do you live? I'd strongly consider Pacesetter headers along with the TSP ypipe (improved) or TD. May not be able to though depending on emmision testing and whatnot.
Old Mar 23, 2011 | 05:53 PM
dshaw42085's Avatar
With some more searching, I found that Dynomax also made the same pipe for the 2000 and up model, so I ordered it and installed it. The fit wasn't super, but it doesn't leak so it's good enough. All three of the exhaust studs on the left manifold broke. Fortunately my father was helping me and he used a trick he learned from some guy he used to work for. Heat up the manifold around the stud with a high temp torch, then stick a candle to the top of the stud. The wax runs in the threads, and they screw right out.
Alien
Jun 27, 2015 01:13 PM
shroyvin56
Apr 3, 2015 08:15 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
jayvar
Feb 2, 2015 10:00 PM
Brake_L8
Jan 20, 2015 09:44 AM
